Old 05-09-2006, 10:44 AM   #5101
Originally Posted by understeer
Thanks again vortex.
That is where I am planning to run the car! What about the spacers on the lower suspension mounts? What do they do?
About 4mm droop front and rear is a good starting point.
The spacers under the suspension mounts control the roll centre (the amount the car can roll). Good starting point is none under the rear mounts and 1mm under each of the front mounts.
Schumacher
Team Sorex
EA Motorsports
Speed Passion
East Coast Bodies
John Pape is offline   Reply With Quote
Old 05-09-2006, 11:14 AM   #5102
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
would you use the same amount if you had diff in front or is this a spool/one way setup in the droop department
i use diff every where other wise i just destroy drive shafts left,right & centre
when i came second at carpetwars in it`s first year i ran then 1mm spacers under the front mounts , don`t now why i went away really , to many `other` cars i guess , got confusing in the end
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 05-09-2006, 11:52 AM   #5103
Yes, same droop whatever, run less indoors, around 5 usually.
Part no for ball joints:
ZC206LH large size
ZC206MH medium size
ZC206SH small size
You will need 1 packet of each to do complete car.
Schumacher
Team Sorex
EA Motorsports
Speed Passion
East Coast Bodies
Old 05-09-2006, 12:16 PM   #5104
MR JOLLY's Avatar
JOHN
ask chris which shop`s in the UK stock the ZM 413 hub`s , being very old stock for a very old car (MR4 TC)
tracking one down is a problem
reason i asked about the droop you usually get `diff out` mid corner if you run little droop
must setup sheets have like 4 rear / 5 front
does the LCG/BD like i bit more droop outside then the SD did or is it in the `feel` on the day scenerio
stewart i can see you looking .i`m testing this first on sunday ,.not you
Old 05-09-2006, 12:17 PM   #5105
MR JOLLY's Avatar
stewart my LCG built now
just setting up the Li-Po pack to sit init nicely
Old 05-09-2006, 12:19 PM   #5106
Send a message via MSN to Zacharopoulos
Please post some pics after doing that!!!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Zacharopoulos is offline   Reply With Quote
Old 05-09-2006, 12:29 PM   #5107
stewart i can see you looking .i`m testing this first on sunday ,.not you [/QUOTE]
ok Colin you do it first, we know you need all the help you can get
Stewart Bevan is offline   Reply With Quote
Old 05-09-2006, 01:24 PM   #5108
TRF415boy's Avatar
Thats the ticket, he was running a 0.5 shim under all the mounts on the car to raise the roll centre to induce some roll, thus grip and steering. Stafford is quite technical and low grip.
That doesn't make sense, raising the RC makes the car roll less.
TRF415boy is offline   Reply With Quote
Old 05-09-2006, 01:38 PM   #5109
MR JOLLY's Avatar
by putting shims under the sus blocks you are physically raises the CoG of the car (i think ) getting out of my depth here ,think i shut up
Old 05-09-2006, 01:40 PM   #5110
MR JOLLY's Avatar
ok Colin you do it first, we know you need all the help you can get [/QUOTE]
i`m catching up fast 2nd time on asphalt since sept 2005
as you lot put i need a `proper` car to keep up
Old 05-09-2006, 01:52 PM   #5111
Should roll more...
pops is offline   Reply With Quote
Old 05-09-2006, 01:56 PM   #5112
TRF415boy's Avatar
Originally Posted by pops
Should roll more...
Err nope. low roll centre = higher distance between the roll centre and the centre of gravity = more roll. High roll centre is the opposite so less roll.
Old 05-09-2006, 02:46 PM   #5113
no if you think about it the CoG has been raised so the weight is higher up and when the car leans the weight is higher up and pushes the car over more.
that probaly makes no sense so heres an example
think of it like a double decker bus (poor example i know but...) the weight is so high up the bus leans and is close to rolling in the corners. so raising the roll centre will give the car more roll.
HTH
Scott
Scott Taylor is offline   Reply With Quote
Old 05-09-2006, 02:57 PM   #5114
TRF415boy's Avatar
HTH
Scott
That's the funniest thing i've ever read on RC Tech The effect on the centre of gravity is so small, raising your bodyshell by one notch has 100 times more effect on it. Now read me well : lower the Roll Centre (no matter HOW) = more roll, raise the RC = less roll. Now, repeat after me
Old 05-09-2006, 02:59 PM   #5115
lol ok but why is it several people on here have said to you that its the other way around but yet you still seem to believe your right
yes it is a very small change but it is how it works.....
heres another example you get a pendulum (spelling?) and put the weight near the bottom and it wont lean as much as if the weight is higher up.....
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
