Old 05-08-2006, 10:45 AM   #5086
Originally Posted by pops
You would have to file a mm off the bottom of the old suspension mount. I just tried putting the older taller one piece mount on the front and it does give you a little extra toe out. But, it looks like if you filed a mm off the bottom to reduce the height the belt would rub on the underside of the mount. The picture supplied looks like there is a 1mm spacer under the mount? I am running the new solid SD-300FR with 1mm spacers and it was designed to clear the belt on the BD. This came out with the new SD-300RF for the rear of the car. The old style are not being produced anymore, this is a part that is being changed with no new part number.
Thats the ticket, he was running a 0.5 shim under all the mounts on the car to raise the roll centre to induce some roll, thus grip and steering. Stafford is quite technical and low grip.
Schumacher
Team Sorex
EA Motorsports
Speed Passion
East Coast Bodies
John Pape is offline   Reply With Quote
Old 05-08-2006, 10:49 AM   #5087
Originally Posted by Rowdy
So putting the "new" SD-300RF in the FR position on the car, will result in a slight inboard toe out situation. This must be because it is slightly narrower than the SD-300FR, is this correct?
How/why will inboard toe effect the handleing of the car? Do you have to set the outboard toe to its original setting, or just run with the slight increase in overall toe?
Will the SD-300RF fit directly to the FR position without modification? I understand that this will effect roll center and will need to remove 1mm in order to restore factory roll center settings.
Yes inboard toe out, increases reaction on steering, not a huge amount though. You have to reset overall toein.
The blocks will fit straight on the front, but you will have to run 2mm worth of washers on the car front mount and ideally 1mm worth of spacers on the car rear mounts. I would'nt recommend this as it raises the roll centre too much.
Schumacher
Team Sorex
EA Motorsports
Speed Passion
East Coast Bodies
Old 05-08-2006, 11:59 AM   #5088
will the bd rear mounts work as the same as the one piece mount.
thanks
mwoods is offline   Reply With Quote
Old 05-08-2006, 12:13 PM   #5089
Greg M's Avatar
Look what I started...
The mounts are out of stock here and are on back order with Yokomo Japan. I'll have to try and track some down.
Greg M is offline   Reply With Quote
Old 05-08-2006, 12:50 PM   #5090
Ask about the part because the older solid mounts are being replaced by the newer ones. Those parts will not be available as they change to the new designs for belt clearance.
pops is offline   Reply With Quote
Old 05-08-2006, 12:53 PM   #5091
Greg M's Avatar
I just found some and ordered them...
My brother is a fitter/turner, so doing any machining won't be a problem. I was close to getting him to make some mounts, but this was easier.
Old 05-08-2006, 01:19 PM   #5092
Does anyone know someone who makes a modified steering rack that allows you to mount your links further forward?
DOTMAN is offline   Reply With Quote
Old 05-08-2006, 01:41 PM   #5093
rocketron's Avatar
Trader Rating: 16 (100%+)
hey dotman
make some room so i can PM you getting a msg you have no more space.................
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 05-08-2006, 01:51 PM   #5094
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
J Pape
YGPM
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 05-08-2006, 03:23 PM   #5095
thanks for the info, let me see if i have this correct, i should change to the one piece blocks, and if i use the sd-300RF part on the front rear it will give a little inboard toe and give a little more turn in. so i need to order two of the SD-300RF
Turtlemaster is offline   Reply With Quote
Old 05-09-2006, 01:02 AM   #5096
understeer is offline   Reply With Quote
Old 05-09-2006, 01:03 AM   #5097
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
Originally Posted by understeer
Hello. I just got a bd and am wondering what the droop screws are to be set at.
I noticed you posted in the Hobby Habit thread, for that track around about 5mm of droop front and rear is a good starting point.
v0rtex is offline   Reply With Quote
Old 05-09-2006, 01:27 AM   #5098
Old 05-09-2006, 01:31 AM   #5099
Thanks again vortex.
That is where I am planning to run the car! What about the spacers on the lower suspension mounts? What do they do?
You can change those to get different suspension geometries, kick up, anti dive etc etc. Leave them standard when you build the kit though.
Old 05-09-2006, 04:45 AM   #5100
Rowdy's Avatar
Does anyone have part numbers for the XB buggy ballcups and joints with the 2mm hex in them?
I looked on the yokomo USA site and it had ZC-207 and ZC-206 which are the standard part numbers. Does this mean the 2mm hex is just an upgrade to the existing parts?
Rowdy is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
