Old 05-07-2006, 09:46 AM   #5056
Originally Posted by Ali Graham
I didn't take any pics, I thought the nosying was rude enough!!!
You can see the steering blocks on the pic of his car on this page: http://www.cmldistribution.co.uk/new...iew=0000000187
Basically, a hole has been drilled right in front of the std holes on the steering blocks, and the the special steering rack is further forward sot hat when the links are in this position, they are perfectly parellel, i.e at 90* to the chassis. I was told this is to achieve more lock. The hpi c-hubs seemed a straight fit too me
As a close personal friend and team mate of Chris's he sent me the following pic of the steering arrangement on his car.
As you can see he ran old style MR4TC castor blocks, the balljoint drilled 4mm closer to kingpin and used the ackerman plate produced for the Japanese Nationals which has holes further forward. Also a 0.5 mm shim to reduce the lock slightly to minimise the wheel wobble and chatter when they are cranked over so much.
Schumacher
Team Sorex
EA Motorsports
Speed Passion
East Coast Bodies
John Pape is offline   Reply With Quote
Old 05-07-2006, 01:30 PM   #5057
tcfree's Avatar
can u please tell me what rod ends chris has on his car?
tcfree is offline   Reply With Quote
Old 05-07-2006, 01:43 PM   #5058
Send a message via MSN to Zacharopoulos
i was ready to ask the same thing!!!
An done more question!!! What is this???? In the red circle???
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Zacharopoulos is offline   Reply With Quote
Old 05-07-2006, 01:46 PM   #5059
Sleighty's Avatar
Stick on weights with carbon decal
A1-RC.com
Team Scream
Xray
Sleighty is offline   Reply With Quote
Old 05-07-2006, 01:47 PM   #5060
Greg M's Avatar
The suspension mount looks like it is the rear one too?
Greg M is offline   Reply With Quote
Old 05-07-2006, 02:16 PM   #5061
tcfree's Avatar
I think now after looking thay are off the new yokomo MR4BX buggy? i may be wrong.
Old 05-07-2006, 02:23 PM   #5062
@sleighty: Thanks , i thought it was a drill at the chassis!!!
@ Greg M : I don't really think so!!!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Old 05-07-2006, 02:36 PM   #5063
Greg M's Avatar
Why does it have an "R" on it then?
The suspension mounts on the BD are normally the individual ones marked "F", his is a one piece by the looks with the "R".
Old 05-07-2006, 02:38 PM   #5064
Running the rear suspension mount on the front gives inboard toe out.
Dan Hughes is offline   Reply With Quote
Old 05-07-2006, 02:40 PM   #5065
ar eyou talking about suspension mount or the block??
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Old 05-07-2006, 02:40 PM   #5066
Greg M's Avatar
I have a mate with a JRXS and he runs in board toe out and reckons its made the car alot better and I was going to try it, but the rear toe blocks won't fit on the front. I hadn't tried changing the back mount, so will have a look at that tonight.
Old 05-07-2006, 02:43 PM   #5067
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
if you look at that pic it's not a rear toe block from the BD
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 05-07-2006, 02:47 PM   #5068
It is but the old style from the SD
Old 05-07-2006, 02:51 PM   #5069
Greg M's Avatar
I was actually looking at making a custom block for the front mount to try and get the same effect, but changing the rear block is easy.
From what my mate tells me it gives a big improvement mid corner and exit. His car is the fastest at our track my a huge amount and the car can out corner anything!! A guy with an Xray 05 tried it yesterday and loves the change as well and his car is now hooking up alot better.
Old 05-07-2006, 03:06 PM   #5070
tcfree's Avatar
Thats the 1! very nice 2
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
