Old 04-19-2006, 02:16 PM   #4951
housey's Avatar
Originally Posted by Zacharopoulos
What do you mean straight steering posts?? I own the newest version of the single BD and has EXCACTLY the same steering plate , posts , washers under bell cranks etc!!
IS there any other difference??? Maybe i am stupid but i can't understand what are you talkingabout guys
just a joke between me and robfo mate, i bent my steering posts in a crash, and he likes to rip me to shreds about it from what i can see the masami edition steering is the same as the newer standard BD's, with a washer under the bellcranks
Chris Swallow - Team Yokomo - GM Racing - Ko Propo
Donny Racing - http://donnyracing.yolasite.com/forum.php
Poweeeeerrrrr!
housey is offline   Reply With Quote
Old 04-19-2006, 03:58 PM   #4952
Send a message via MSN to Zacharopoulos
Ok because for a moment i went crazy !!!!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Zacharopoulos is offline   Reply With Quote
Old 04-19-2006, 04:01 PM   #4953
Originally Posted by asw7576
ONLY If you are very clean person ( always clean car after race ), I guess is okay.
The life probably shortened too.
I clean my car after every practice !!! Which means every 4-7 batteries!!!
I think the bearings will be ok .... ha??
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Old 04-19-2006, 07:24 PM   #4954
joelt's Avatar
Send a message via Yahoo to joelt
One thing worth noting with the BDM (as compared to the BD) are the kit bearings. They both look the same on the outside, but that of the BDM's is a lot smoother.
. . . Haven't had the heart to tear off the metal seals yet though, so I really don't know why.
joelt is offline   Reply With Quote
Old 04-19-2006, 07:33 PM   #4955
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
It's because the car comes with precision bearings throughout the car.
v0rtex is offline   Reply With Quote
Old 04-19-2006, 07:40 PM   #4956
joelt's Avatar
You're right about the use of precision bearings. Would you know what exactly in the construction makes these run smoother? Do they use carbide or ceramic balls?
Old 04-19-2006, 07:43 PM   #4957
Not sure, im sure Pops could fill us in on that one
Old 04-19-2006, 11:35 PM   #4958
Jochim_18's Avatar
I believe the precision bearing is Metal shielded which is a lot smoother and freeier than the standard rubber sealed bearing that we have on the standard BD. With rubber or teflon sealed bearing there is contact between the bearings and rubber sealed this causes friction hense restricting the movement of the bearings.
Thats why ceramic bearing uses metal shield instead of rubber or teflon.
Old 04-20-2006, 02:35 AM   #4959
I don't care , i am going to remove the shield from the standard bearings but also from ceramic bearings!!!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Old 04-20-2006, 03:47 AM   #4960
Its not worth it. The gain from removing the shields wont be measurable, any minor gain you'll get wont last long if you still hit barriers..
Leave the shields in
Old 04-20-2006, 05:00 AM   #4961
I never hit the barriers!!!hahahaha
really i am in a level that i can run 5 minutes without hitting any other car or barrier!!!
Although i will think it again about the shields!!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Old 04-20-2006, 05:54 AM   #4962
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
you may be at that level, but what about the others around you....
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 04-20-2006, 07:22 AM   #4963
crabboy's Avatar
Trader Rating: 58 (98%+)
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 04-20-2006, 08:15 AM   #4964
Here in greece we separated the modified class into another 2 classes , World in which race the elit of the greek drivers and it is only 10 persons and national in which race the rest modified drivers!
So in World class we all are at the same level , so we don't hit each other very often and sometimes we don't hit each other at all!!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Old 04-22-2006, 09:26 PM   #4965
can someone give me an estimate on how much a used (but well taken care of) BD goes for? (w/o spares)
www.freerice.com
Help hungry people while learning.
smojoe is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
