Old 04-06-2006, 08:27 AM   #4876
Originally Posted by Cmotif
Is the MR4TC (non-shaft drive) back in style? Sorry I have been away since August. Last I knew, MR4TC SD was the way that everyone seemed to be going.
I have a couple of MR4TCs that are belt driven, including one SSG, and probably about 700 to 1000 in spare parts (retail price). Worth hanging onto, or is the new MR4TC-BD something way the heck different?
Thanks for any information that will bring me back up to speed!
The MR4TC is not back in style. It is several years old and technology has passed it by. The new BD is far more advanced than the older TC. If you are not racing, then you are fine with the older car.
pops is offline   Reply With Quote
Old 04-06-2006, 10:35 AM   #4877
JayBee's Avatar
Trader Rating: 31 (100%+)
Default WHEW!! This is work...
Okay fellas these are the hop-ups that are on the car as follows-
*frt. adjustable body mounts
*wide plastic front bumper
*P-DUB foam bumper
*SQUARE top bumper plate
*Associated 'BIG DAWG' CVD's (frt.)
*Speedtech Spool
*COOL CAN FAN
*EXCEL Delrin diff
*Ti-CVD's (rear)
*Ti-screws throughout the whole car
*Ceramic bearings (except for the outermost frt. hub bearings<- 1 on each side)
*3mm bottom/top decks
*Yokomo dish wheels w/Yokomo Hot Lap tires & 037F Inserts
*LOTS of blue & silver bits...
Let me remind you that the bottom of the chassis is scratched due to the fact that the car has only seen asphalt. Let me also STRESS that the car is clean but SHOULD to be given a look-over. I haven't touched the car in about 8 months. All I did was spray everthing with motor spray, brush it down and put it away. I'm a 12th-scaler now
The car is also coming with a brand new freshly painted unused Mazda 6 & 2 sets of Yokomo Hot Laps tires w/inserts mounted on HPI wheels.
I'm asking $425 SHIPPED plus the paypal fee....or better yet make me an offer
Now for the spares, there's alot so look around...99% is 'BRAND NEW UNUSED'-
BD-503 (2) -$4.75
ZS-508 (4) -$5.00
BD-189L (2) -$5.99
BD-516L (2) -$7.99
ZC-N4AFB (3) -$3.99
BD-300RL -$50.89
BD-300RR -$42.70
BD-300FL -$20.86
BD-300FR -$20.86
BD-300CA -$20.86
BD-300CB -$20.86
BD-202S (2) -$12.99
SD-414TA (2) -$5.25
SD-415SG (2) -$7.95
ZS-011EL (2) -$7.95
BD-300S -$4.75
SD-501R (2) -$2.50
BD-BBP (3) -$44.95
BD-671 -$25.99
BD-674 -$11.50
ZS-507 (4)- $2.85
ZS-508S (3) -$2.50
ZS-414 -$2.50
ZC-BH2655T -$2.99
SD-640TM -$1.00
ZC-206L (2) -$2.49
SD-009H (2) -$5.00
SD-009 (2) -$7.25
ZS-506 (3) -$2.75
ZS-507T (4) -$8.50
ZD-505T (4) -$9.99
ZS-010TP (4) -$2.75
BD-118T (5) -$5.75
BD-501SAS (3) -$15.99
SD-300R25 (2) -$15.99
BD-TSS -$35.99
BD-017G -$11.50
BD-018G -$13.25
SQUARE STY-9 -$16.99
SD-001FS (2) -$4.95
RS-04 -$3.99
RS-02 -$3.99
RS-01 -$3.25
RS-11 -$3.99
RS-12 -$3.99
HPI Diff balls A157 (2) -$10.99
RCScrews Stainless Steel screw set (2) #yok.011 -$18.00
EXCEL Diffs (3) -$19.99
In the small plastic bin-
Yokomo Shock sets LONG & SHORT -$33.99/28.99
RAYSPEED SPRINGS (12pair) -$4.50each
YOKOMO SPRINGS (10pair) -$5.00each
In the large plastic bin-
Speedtech Spool -$29.99
Alum. Spool -$22.99
Complete diff assemblies (2) -$21.99
One-way -$38.99
TC4 ALUMINUM CVD's (2) -$19.99
TC3 HD drive cups (for one-way) -$18.99
P-DUB Bumpers (3) -$9.99
Also in the large plastic bin are the front & rear arms which are all unused. Also all the c-hubs, spur gears, 0 and 1-degree steering blocks, ballcups, spacers, and 3-4 sets of CVD's and universals.
Make me an offer and we'll go from there... Have fun
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 04-06-2006, 10:57 AM   #4878
JayBee's Avatar
Default OOPS...
Here's the car... And 1 more spares pic...
Old 04-06-2006, 11:14 AM   #4879
Hi,
the Associated HD dog bones look really bling-bling.
Are they a direct fit? I'm not sure because of the bearings?
What parts did you use? I'm quite sure you posted it a few months ago but I can't find it.
Cheers
Chris
speedy-932 is offline   Reply With Quote
Old 04-06-2006, 11:22 AM   #4880
JayBee's Avatar
You have to shave the inside of the hub so the bowl of the bone doesn't rub and you also have to 'flatten' (file/dremel) 2 spots on the pins so they slide into the slots of the outdrives...
Old 04-06-2006, 11:25 AM   #4881
Hi,
thanks. And which wheel axels do you are using? I can't find them at Speedtech RC...
Cheers
Chris
Old 04-06-2006, 11:27 AM   #4882
JayBee's Avatar
The black steel CVD stub axles...if I'm not mistaken I believe they're from Associated...
Old 04-06-2006, 11:38 AM   #4883
Send a message via MSN to makytc4
JayBee
im using the sorex 24 prebuilds all round as are some others. i did move the droops on rear form 4 to 5 and improved it. make me think maybe the oil isnt stiff enough in car and is trying to react to fast. im runnign 1.2mm x3 hole pistons and 50wt oil
actually going outdoors with car at weeknd get some tarmac time with it. first time with bd 7x1 and 1.224 ib4200 should be good.
makytc4 is offline   Reply With Quote
Old 04-06-2006, 12:00 PM   #4884
JayBee's Avatar
For outdoor tarmac try Sorex 36's
Old 04-06-2006, 02:41 PM   #4885
H.Nilsson's Avatar
Default Tarmac
Originally Posted by makytc4
JayBee
Hallö try masamis set up from yatabe arena whit sorex 36 and 60wt oil front and 65 wt back I think this setup works on tarmac and on carpet as well but on carpet im running on sorex 28 or take off 22
H.Nilsson is offline   Reply With Quote
Old 04-06-2006, 03:24 PM   #4886
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
Jaybee did you intend on breaking that much!!!!!! Hahaha always helps to have confidence that if one car falls apart, you can build another!
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 04-06-2006, 04:06 PM   #4887
JayBee's Avatar
Nah I'm just a parts whore
Old 04-06-2006, 08:10 PM   #4888
Send a message via AIM to aoizip
jaybee: you got pm~
~Ming
aoizip is offline   Reply With Quote
Old 04-08-2006, 03:13 AM   #4889
BJ
Default BD Chris Grainger
Ok got a yokomo BD C.G. with all the hop-up parts on Looking through the setup sheets I have a few questions, On the front SDW wishbone it has two holes for the shock, but on the sheet there are three with the middle one ticked, does this mean outside on SDW arm? Also the setup sheet for Bedworth National is different to the one on CML's website for Bedworth National which one did he use? Lastly are RS14 pistons the same as Tamiya #3 pistons.
Thank you.
BJ is offline   Reply With Quote
Old 04-08-2006, 03:28 AM   #4890
use the outer holes on SDW arms.
the set up on CML site is old.
tamiya #3 has 1.1mm holes, while RS14 has 1.2mm holes.
caveman is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
