Old 03-06-2006, 01:13 PM   #4711
Originally Posted by Zacharopoulos
Would be possible some part numbers???
Newer Parts
ZS-4134 4 degree
ZS-4135 5 degree
ZS-4137 7 degree
pops is offline   Reply With Quote
Old 03-06-2006, 01:40 PM   #4712
Send a message via MSN to Zacharopoulos
tthank you very much!!!
Zacharopoulos is offline   Reply With Quote
Old 03-08-2006, 11:12 AM   #4713
pitshop's Avatar
Trader Rating: 56 (98%+)
so where are all the pics of the new BD???
PIT SHOP 153-D Araneta Avenue
Q.C. opposite PNB between SM Sta Mesa and So En
tel (632)716-6553 fax (632)714-0550
YOU CAN CALL 09174632746 OR 09175331943
please like us on FB - PITSHOP RC
pitshop is offline   Reply With Quote
Old 03-10-2006, 08:49 AM   #4714
Send a message via MSN to makytc4
Default yokomo bd carpet setup
has anyone got a really good carpet setup for rubber and mod.
the carpet is brand new and is very high traction.its a fair size track. struggling to keep it on all 4 wheel cuz of grip roll.
i was running sorex 24r prebuilds which are 2 grippy. was thinking sorex 28's with echo yellows inserts.
tried using one way but u gotta have brakes round it. tried spool seemed hard to drve.
any idea of a good start point.
also been struggling with on power steering any idea how get some back
.im running 50wt all round with 2 hole 1.2mm piston . associated blue spring front silver rear( was gold blue but went down due to grip roll)
any help appreciated
makytc4 is offline   Reply With Quote
Old 03-10-2006, 08:50 AM   #4715
dont worry i am i right forum just used to have tc4 now i got a bd
Old 03-10-2006, 02:14 PM   #4716
Rowdy's Avatar
I'm no expert on carpet, in fact only ever race on it twice, but I would have thought carpet racing will heat up the tyres considerably, even more than asphalt racing. That said I'm thinking that Sorex 32r or 36r would have a better temprature range more suited to the conditions. Maybe someone with some more experience on the surface could help.
On asphalt Hara inserts are my choice and seem to work as good or better then anything I have tried; can't see any reason they wouldn't work well on carpet as long as you got the hard inserts.
Rowdy is offline   Reply With Quote
Old 03-10-2006, 02:41 PM   #4717
Rowdy's Avatar
Possibly try looking at your droop settings to limit the amount of weight transfered to the rear of the car when on power.
Old 03-10-2006, 02:54 PM   #4718
Sorex 28R is about perfect, with Orion JB foam blue(light weight medium thick on medium grip, thick one on high grip track).Never has overheat problem unless you run it in summer. 24R when grip is low, but on high grip track, the car wants to move side to side a bit and traction roll of course. You can do something like shock, springs, droop,etc to reduce traction roll, but the most effective way is to coat the outside side wall(up to the shoulder) with super glue. You may have to recoat it every few runs.
On power steering, try 1.1mm x2holes piston at the rear with 40-45w oil(you can keep the 1.2mm x2holes piston on the front shocks), moves the rear shocks to outside holes on tower, try rayspeed yellow, HPI pink, Tamiya blue or X-ray white at the rear, these are a bit stiffer than Asso silver but softer than Asso blue. These help on-power steering a lot.
caveman is offline   Reply With Quote
Old 03-10-2006, 03:00 PM   #4719
Ok, here we go this seemed to work pretty much anywhere and there was no grip roll when the grip came up.
Dual 1ways
2 neg camber all round
Inline steering blocks
droop 5 front 4 rear
springs rayspeed red front and white rear
55wt oil with 1.2mm x 3 pistons
3 deg rear toe in
front shock position on tower second from inside and middle on arm
rear shock position on tower second from inside and outside on arm
2mm spacer under front ball end at bulkhead and 1.5 under front suspension mounts and 0.5 rear.
Dan Hughes is offline   Reply With Quote
Old 03-10-2006, 07:12 PM   #4720
thanks alot for the help will try wednesday night at club.
mate just said about grip roll on my car didnt thinka bout it. been running a orion lipo cuz its loads lighter. be y it grip rolling looked at it and it only does it right hand bendswhen u need the weight that side to keep it down .
gonna chuck load weight on that side as well me thinks.
my mate used cs22 with shumacher orange in them( x soft) overheated about 4 mins was on about going up to the yellow.
any idea if the yok 38m would work also got some pit medhard inserts little bit harder than the 38m. ive been to a lot of tracks but dam has this carpet got some grip and they wanted to use additive, i dont think so.
Old 03-11-2006, 10:29 PM   #4721
any BD guys going to the carpet nats in stockton?
I don't wanna be the only "yokomo" guy there
www.freerice.com
Help hungry people while learning.
smojoe is offline   Reply With Quote
Old 03-12-2006, 01:05 AM   #4722
rocketron's Avatar
Trader Rating: 16 (100%+)
there will be three others there running BD's
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 03-12-2006, 09:53 AM   #4723
Send a message via AIM to mush104
hey everyone i was wondering if some of you could give me some setups for rubber tires and it should be a med. to high bite thanks
mush104 is offline   Reply With Quote
Old 03-12-2006, 10:19 AM   #4724
woohoo! hope you guys won't mind me asking for setup advise
www.freerice.com
Old 03-12-2006, 11:39 AM   #4725
Default Ackerman
When some set-up sheets say - "ackerman postion standard" - what exactly is that setting ?
Alistair
Al Williams is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
