Old 03-04-2006, 05:29 PM   #4696
PaintingRoly's Avatar
Trader Rating: 56 (100%+)
Originally Posted by H.Nilsson
What is this??????????
It's the T.O.P. racing Scythe
follow me @RC3grafix on Instagram for pictures of my paint work.
PaintingRoly is offline   Reply With Quote
Old 03-04-2006, 06:49 PM   #4697
Rowdy's Avatar
Originally Posted by Ralf
Thanks Dan,
I have just spotted an image, will order them as well
Will you try them on carpet or asphalt ?
Where did you see the pic of the new springs, do you have a link?
Rowdy is offline   Reply With Quote
Old 03-04-2006, 07:53 PM   #4698
New products for Feb.
English version http://www.teamyokomo.com/japan/newp...s2006_2_en.htm
pops is offline   Reply With Quote
Old 03-04-2006, 10:02 PM   #4699
highwayman's Avatar
where can i find masami's latest set-up for the japan nationals?
thanks -jason
highwayman is offline   Reply With Quote
Old 03-04-2006, 10:30 PM   #4700
The new Yok springs, the softer three, black(YS-1460L), blue(YS-14575L) and yellow(YS-1455L) seems to be the same as the Rayspeed green, blue & yellow. Same size wire, same # of coils. Look at the part #, YS-1460L, 1460 means 1.4mm wire with 6.0 coils. Although the other three are different.
The HPI blue is also 1.4mm wire with 6.0 coils(OK, slightly shorter & maybe different grade of material). Chris Grainger says it is very close to Rayspeed green(I agree), though some people think HPI blue is similar to Rayspeed blue or yellow.(not start an argue here)
caveman is offline   Reply With Quote
Old 03-05-2006, 02:41 AM   #4701
Hey guys iv moved from stock to mod right..... and im running a 21 pinion (48 pitch) and a 78 spur (48 pitch) in stock what would i have to change pinion and spur wise to run a 11x1 mod motor.
Thanks in advance jamie
jamie814340 is offline   Reply With Quote
Old 03-05-2006, 02:57 AM   #4702
Foam or rubber? on medium size track, try 20T pinion with rubber and 22T pinion with foam(58mm dia).
Old 03-05-2006, 02:58 AM   #4703
ok its a rubber trye on a very weavy track do i need to change my spur?
Old 03-05-2006, 03:15 AM   #4704
I have a 78Tspur on my car, a 20T pinion will give you 7.8 fdr, It depends also you motor set up, etc, but on weavy(tight?), maybe run more timing and try a 76T spur with a 19T pinion, this give you 8.0fdr.
Old 03-05-2006, 03:19 AM   #4705
im running a 12 timing but i dont really know if it is a 12 but im using the line on the far right to dertermin the timing on the motor is this right?
Old 03-05-2006, 03:20 AM   #4706
When I run 12Tmod, about 7.4-7.6fdr and 24-30deg timing on small to medium size indoor tracks.
Old 03-05-2006, 03:25 AM   #4707
Those lines are not always accurated, if you have a timing stand, you can check it. Or use a caliper to measure, 1mm is about 3.2deg.
Old 03-06-2006, 12:22 PM   #4708
Send a message via MSN to Zacharopoulos
Guys what if i want to change caster angle???
Zacharopoulos is offline   Reply With Quote
Old 03-06-2006, 12:34 PM   #4709
You can use the older MR4-TC caster blocks available in 3, 5 and 7 degrees. You will have to slightly modify them with a dremel for them to function correctly.
Old 03-06-2006, 12:36 PM   #4710
Would be possible some part numbers???
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
