Old 02-24-2006, 08:07 AM   #4636
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
Originally Posted by HarshGuy
I can fix all that, I guess I didn't realize "Circuit" was track, Ithought that was just the title for all that group of stuff.
Where does "carrier or shims under rear camber link" go?
And where does "won't unselect 2* rear toe-block" happen?
The hub carrier bit is in the left hand-column, all you do is type in 4* tbh, no diagrams or anything.
The shims under the camber link is on the diagram of the shock tower, there is an arrow and brackets, all you fill it with is 0, 0.5 etc.
With the toe-block, when I click on another one, the 2* is still selected, so it looks like I'm running toe different blocks
I've got no idea with acrobat reader so I don't know how to do any of this!
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 02-24-2006, 08:44 AM   #4637
HarshGuy's Avatar
OK I see this
Ok I see this, it's the "rear" one I missed, front one works
Humm ...works for me, how about others? ...I have a fix for you Click Here
no actually, what version reader you using? 5.0+ should work just fine I have tried with 5.x, 6.x, 9.x and all works ...unchcek's the 2, when I click 2.5 or 3
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 02-24-2006, 08:25 PM   #4638
HarshGuy's Avatar
OK ...all issues resolved in the editable BD sheet, I did find an issue if you clicked 3 degree on the hud, 2 stayed selected. So all issues are fixed.
Old 02-24-2006, 09:49 PM   #4639
SchuMi2's Avatar
Trader Rating: 34 (100%+)
Had a little bit of spare time so I have done alittle work on the BD....It now runs Cyclone/Pro 4 Suspension with Tamiya Shocks. I also did some mods to the steering and chassis.
I will be running it in practice this week to see how it goes
Yokomo MR4TC-BD-yokpro6.jpg   Yokomo MR4TC-BD-yokpro2.jpg   Yokomo MR4TC-BD-yokpro3.jpg   Yokomo MR4TC-BD-yokpro11.jpg
SchuMi2 is offline   Reply With Quote
Old 02-24-2006, 10:00 PM   #4640
Rowdy's Avatar
Nice work schuMi2, any chance of getting a few more pics of the steering assembly from a few different angles. I have been trying to think of a way to improve on the factory steering assembly myself. looks like you have done a great job.
Rowdy is offline   Reply With Quote
Old 02-24-2006, 10:10 PM   #4641
SchuMi2's Avatar
Here's a couple more of the steering....I will see if I can get any clearer ones.
Old 02-24-2006, 10:40 PM   #4642
ShuiM12
Interesting, can't wait for your report. Nice work
caveman is offline   Reply With Quote
Old 02-25-2006, 12:57 AM   #4643
Rowdy's Avatar
schuMi2 Thanks for the pics. Are the inner ball studs, mounted under the steering rack, the same as the ones on the cyclone.
Old 02-25-2006, 03:28 AM   #4644
SchuMi2's Avatar
The inner ball studs mount under the carbon plate on the steering rack. I made up the alloy block with the 2 holes for the inner ball studs and 2 holes to mount it to the carbon plate. I used the original hole at the back of the plate and drilled another in the front. All holes are threaded. Without shimming the inner ball studs forward it is the same as running the middle hole on the original plate
Hope I explained it well enough
Old 02-26-2006, 12:00 PM   #4645
Ali Graham's Avatar
Found something out today by "accident"
we all know how the 1-way pulleys lock up, wel i found a way to unlock them temporarily if your stuck. Just hook the pulley up the wrong way round so that the supposed 1way pulley si going to the rear, and depending on the power of your motor (with a stock took 2mins) the strain will unlock the pulley! Bit of a dodgy solotuion but when they cost 25 ($45+) apiece I'm not complaining.
Old 02-27-2006, 12:41 AM   #4646
highwayman's Avatar
hi... what's the advantage of using the SDW arms on the BD?
thanks - jason
highwayman is offline   Reply With Quote
Old 02-27-2006, 01:20 AM   #4647
coons88's Avatar
Send a message via MSN to coons88
When mine locks up I can pull on the front belt gently while holding the spur gear, and slowly pulling the belt a bit harder untill it unlocks. But after the next run its locked again, so I am realy stumped. Hopefully Yokomo is aware of this problem and working on a solution.
Associated TC6.1 | Hobbywing V3 | LRP X12 | Spektrum | Futaba | Reedy
coons88 is offline   Reply With Quote
Old 02-27-2006, 02:06 AM   #4648
coons88's Avatar
Just found out about this: New Masami Special BD
Apperntly it says something about new shock towers and new drive train.
But not much info at this point.
Old 02-27-2006, 04:19 AM   #4649
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Highwayman,
I just put a set on my BD and it seems to me It steers better the arms narrow the front width a mil or two try it out you may like it
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 02-27-2006, 07:09 AM   #4650
Hi,
oh... a Masami Special... we will see...
Today some new parts arrived. 2 new chassis and top decks and a few new ackermann plates. Some with different holes and others in a "Heavy Duty" version.
Cheers
Chris
speedy-932 is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
