Old 02-20-2006, 11:23 AM   #4621
Originally Posted by speedy-932
Hi,
I know but I thought it is worth a try.
Cheers
Chris
They might custom make them if he gives them the size. Diameter and length.
pops is offline   Reply With Quote
Old 02-20-2006, 01:25 PM   #4622
Send a message via MSN to Zacharopoulos
Ok guys , maybe i will give a try
Zacharopoulos is offline   Reply With Quote
Old 02-23-2006, 07:35 PM   #4623
weel's Avatar
Default Need Info
Hi guys,
My BD is coming ! crash is the different story.... i just want to know which parts that often to look after owez..so i can buy it for spare...
thanks
weel is offline   Reply With Quote
Old 02-23-2006, 07:52 PM   #4624
Originally Posted by weel
Hi guys,
thanks
Best spare is the "Wide Bumper", it will save you money on front parts. Good items for spares are:
4 deg caster blocks
0 deg offset front steering hubs
1 deg offset front steering hubs (standard)
Hinge pin set
Front suspension arms
wheel bearings
I am sure others will add anything I forgot
Old 02-23-2006, 08:05 PM   #4625
Shopkeeper's Avatar
Trader Rating: 35 (100%+)
Hi guys,
thanks
Have fun with your new BD, its a great car.
All I have ever broke is:
Caster blocks
Steering hubs
Pins in the universals
Shopkeeper is offline   Reply With Quote
Old 02-23-2006, 08:34 PM   #4626
weel's Avatar
4 deg caster blocks
Hinge pin set
wheel bearings
Hey,
Thanks man,now i can go to H'shop n by me a spare n option parts
i did saw yok fan using that wide Bumper !! i tot it was a GP parts he threw inside his BD...Hmmm still so much i need to know bout BD
Third "Final" day : 6 Nov 2005 JMRCA Race was still playing in my mind...masami was so fast,tailing hara by inch n past hara in corner n leading by few feet away....(worth download da clip)
Anywhere thanks man 4 da superb fast reply....
Old 02-23-2006, 08:40 PM   #4627
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default Wide bumpeer
The wide bumper is absolutely the best thing you can get. If you get the Yok extra wide with the Kydex you might want to cut the kydex down just a bit smaller than the foam itself. This way the full impact isn't taken by the front part of the chassis, definite ouch when hitting full wooden boards. Let the foam do the job. Or the other brands are just as good.
You'll find the Yok to be quite a durable car.
I've been driving it for a while now, I've only broken
1 steering knuckle
a few bent rear pivot balls, darn !!!!walls why are they there!!!!
bent a few hinge pins (not one after the Yok wide bumper)
That is it.
olhipster1 is offline   Reply With Quote
Old 02-23-2006, 09:28 PM   #4628
HarshGuy's Avatar
At pops request, I've created an editable version of the BD seup sheet, you can get it here:
http://www.gearchart.com/index.cfm?f...tsblank&type=1
http://www.arroyoc.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 02-23-2006, 09:59 PM   #4629
Shopkeeper's Avatar
Thumbs up setup sheet
Thanks Harshguy
Old 02-23-2006, 10:06 PM   #4630
weel's Avatar
Thanks olhipster1 4 da info...i hop my H'shop got da stock 4 da wide bumper....
Hey Harsguy ! Nice setup sheet man...good job...i've download n try it click n print hmmmm..very interesting
Old 02-23-2006, 10:51 PM   #4631
Very Cool, thanks Harsh!
Old 02-23-2006, 11:18 PM   #4632
coons88's Avatar
Send a message via MSN to coons88
Yea thats awesome. I see you cannot wirte in the track though.... Did you miss that by mistake, or on purpose or am I doing something wrong?
Associated TC6.1 | Hobbywing V3 | LRP X12 | Spektrum | Futaba | Reedy
coons88 is offline   Reply With Quote
Old 02-24-2006, 02:36 AM   #4633
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
I also can't write in the track, hub carrier or shims under rear camber link. Also mine won't unselect 2* rear toe-block, so when I press 2.5 2 is still there Anyway who are we to complain, we can just right it in! Good job Harshguy
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 02-24-2006, 02:54 AM   #4634
Scho's Avatar
Send a message via MSN to Scho
Yokomo BD anyone?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...ME:L:LCA:UK:31
Thanks Al
Scho is offline   Reply With Quote
Old 02-24-2006, 06:52 AM   #4635
HarshGuy's Avatar
I can fix all that, I guess I didn't realize "Circuit" was track, Ithought that was just the title for all that group of stuff.
Where does "carrier or shims under rear camber link" go?
And where does "won't unselect 2* rear toe-block" happen?
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
