Old 02-15-2006, 09:42 PM   #4591
rocketron's Avatar
Trader Rating: 16 (100%+)
Originally Posted by coons88
No I mean this
i've experienced this and seen the same. imho the layshaft is too soft as the "hard" coating wears very quickly and then the shaft is chewed up too easily. then these little pieces ruin the one way bearing ---- failure in the works.
i just do not use the center one-way any longer not a solution but....
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 02-15-2006, 09:53 PM   #4592
coons88's Avatar
Send a message via MSN to coons88
Originally Posted by pops
haven't seen that happen, have been running a fixed center main gear with spool on asphalt and diff on carpet. Could it be the oil you've added?
The original 1 way i added no oil and this still happened, im onto my second one, and so I decided a bit more oil may help it.
Yea the standard center shaft wears very quickly. When I just replaced the one-way I installed the Ti center shaft, but the one-way seems to be on the verge of locking up again - after only 1 weekend of racing.
Associated TC6.1 | Hobbywing V3 | LRP X12 | Spektrum | Futaba | Reedy
coons88 is offline   Reply With Quote
Old 02-15-2006, 10:25 PM   #4593
asw7576's Avatar
How about titanium layshaft ? Is it harder ( tougher ) than the steel ?
Old 02-15-2006, 10:43 PM   #4594
Jochim_18's Avatar
I do have the same problem. The center one-way just locks up for no reason.
Old 02-16-2006, 05:44 AM   #4595
Hi,
@coons88: Yes, that's the only stiffener post you can use. Or put o-rings under the screws that holds the top deck to increase flex.
The problem with the driveshaft and the locking center one-way is very well known here in Germany.
The only solution is a harder center driveshaft. I ordered one but it didn't arrived yet so I changed the one-way bearing to one with different tolerances and it holds up perfectly, even with the worn out driveshaft.
Cheers
Chris
speedy-932 is offline   Reply With Quote
Old 02-16-2006, 10:02 AM   #4596
I remove two small ball bearing and put another one-way bearing in, the double one-way holds up very well, no problem so far.
caveman is offline   Reply With Quote
Old 02-17-2006, 02:05 PM   #4597
loopedeloop's Avatar
HI Guys
Can anyone direct me to, or provide a good foam/ asphalt setup for my BD.
I'm running 12t mod on good surface, 37 shore ellegi foams all round, whitefr, blue rear springs.
Your help would be appreciated
cheers
loopedeloop is offline   Reply With Quote
Old 02-17-2006, 05:30 PM   #4598
stuey's Avatar
hey everybody
can any body tell me which is the best possiton to run the c hub in the top hinge pin hole with the spacer under the hub carrier or in the lower hinge pin hole with the spacer on top of the hub carrier and why reason i ask this in the uk we tend to get stuck in our british ways if one top driver does something it must be correct i'm not sure.
stuey is offline   Reply With Quote
Old 02-17-2006, 05:36 PM   #4599
stuey's Avatar
Ive not had any prolems with the one way centre pully snagging i had a layshaft wear out on me which i thought was a bit odd what i use for the layshaft on my one way pully is a yokomo MX4 off road car lay shaft from a few years back its a little long nothing a dremal cant fix most importantly its the same diamitar and the pin holes are in the same place not given me any probs.
Old 02-17-2006, 05:59 PM   #4600
Originally Posted by stuey
hey everybody
Bottom hole seems the best, upper hole makes the car a little more twichy.
pops is offline   Reply With Quote
Old 02-17-2006, 06:07 PM   #4601
stuey's Avatar
ok if thats the case were would the best place for the washer to be above or below the hub.
Old 02-17-2006, 06:47 PM   #4602
coons88's Avatar
Originally Posted by loopedeloop
HI Guys
cheers
I run pretty much the standard setup, just without the rear sway bar. Running 37 rear 32 front. I find it works very well at North Harbour
Old 02-17-2006, 07:43 PM   #4603
above the hub.
Old 02-18-2006, 01:40 AM   #4604
Simon K's Avatar
I've been experimenting with tyre widths which came to a head at the Ultimate open last month. I think the combo I ran was a 26mm wide Jaco 35 rear on the front and a 28mm wide Jaco 30 rear on the back. Still need a bit more track time to play with the suspension options as i would like to tune it like my old SP(whether thats a good thing or not, I don't know)
Car is run using thicker shock oil(40 wt I think).
5mm ground clearance and the front diff slightly tighter than the rear.
Fixed center and front diff.
Mazda 6 shell.
Peak Spashett V2 geared 24/78
Simon K is offline   Reply With Quote
Old 02-18-2006, 05:54 AM   #4605
Stu
Try both ways and find out for yourself you lazy git!
I have messed about with it all as well mate and have found that where we are now is best, bottom hole with spacer on top.
Stu
CML | TiR | Microtech Racing | Tubz Designz
StuartC is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
