Old 02-13-2006, 02:29 PM   #4576
Hi,
perhaps your outdrives got damaged by the heat developed by the slipping diff.
The Yokomo screw is fitting very well, I don't have any problems with them. I just broke one after around a year.
Cheers
Chris
speedy-932 is offline   Reply With Quote
Old 02-13-2006, 02:34 PM   #4577
Send a message via MSN to Zacharopoulos
@speedy : no the diff outdrives are ok , i checked them , i forgot to tell you that before tighting the screw i rebuild the diff and run 2 batteries at low speed!!
I don't mean the standard screws , but some other that are a little slant at the end
Zacharopoulos is offline   Reply With Quote
Old 02-13-2006, 08:48 PM   #4578
coons88's Avatar
Send a message via MSN to coons88
Does anyone have a problem with the center one-way locking up?
I run 12t mod and it locks after a run. I just replaced both the center shaft and the one-way last weekend for the nationals and after the weekend of racing the one-way is now clicking (which is what it did before the original locked up). I used EPO to oil the one-way before I installed it.
Associated TC6.1 | Hobbywing V3 | LRP X12 | Spektrum | Futaba | Reedy
coons88 is offline   Reply With Quote
Old 02-13-2006, 09:05 PM   #4579
TC_Tuner's Avatar
Trader Rating: 34 (100%+)
Default center one way
regarding the center one way, I too have found it locking up (stock rubber). I replaced mine with the center spool for the time being.
I felt it went out pretty early - only about 6 track days (and I did clean and lube it...)
TC_Tuner
Airtronics | Byron's Fuel | Pro-Line | OS | Kyosho | Ballistic Batteries | RIP Al's Hobby Shop
MRX4-X F180 Cobra Zipper Kart Yokomo BD Cup Racer FM1e Recoil M18 Pro Scalpel dNaNo Baja 5T HB D8 Vorza ERevo Savage Flux SCX10 GT2 T4 Slash Ten SCTE Blitz ESE HB Cyclone D4 Mini ERevo Vendetta ST Mini T Micro T
TC_Tuner is offline   Reply With Quote
Old 02-13-2006, 09:34 PM   #4580
Jochim_18's Avatar
I do have the same problem with the center one-way locking up. Don't know why it did that. But now I switch to direct drive, Car seems to accelerate faster. But I kept the front one-way though.
Old 02-13-2006, 10:10 PM   #4581
RayWarner's Avatar
Send a message via AIM to RayWarner
Originally Posted by v0rtex
CML in the UK. A URL was posted a page or two back.
Found CML but I don't think they ship to the US. Anyone know for sure?
RayWarner is offline   Reply With Quote
Old 02-14-2006, 12:24 AM   #4582
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
They're the UK importer for yokomo among other brands, your best bet would be to contact one of thier customers (hobby shops) in the UK and have it shipped that way. The standard BD would probably end up being a better deal if you're shipping it to the USA from the UK.
v0rtex is offline   Reply With Quote
Old 02-14-2006, 12:29 AM   #4583
http://www.cmldistribution.co.uk/pro...subMenu=CR-KIT has a list of the parts included that are not in the standard BD kit.
Old 02-14-2006, 06:57 AM   #4584
www.microtechracing.co.uk have the grainger bd in, and they ship worldwide...
agower is offline   Reply With Quote
Old 02-14-2006, 10:53 PM   #4585
Jochim_18's Avatar
You buy those parts, If you want your BD to have those.
Old 02-15-2006, 03:38 PM   #4586
Hi,
I'm just back from racing and here are my experiences with the carpet chassis...
My first thoughts were: Where is my steering gone? The car had good corner speed but was pushing a lot. First, I tried different tires but nothing really worked so I changed rear toe-in to 2 degree, used softer springs and used the most outer hole on the A-arm in front (everything step by step and only one changing at a time) . The car was really good and carried a lot of corner speed. I was just missing a bit of steering in very tight corners. The solution was simple but effective: I removed the stiffener post in the rear and the push was nearly eliminated.
I have to try a few different things next time and see how it works. All in all the chassis works better for rubber tires then I expected.
Cheers
Chris
Old 02-15-2006, 08:04 PM   #4587
coons88's Avatar
By the stifiner post do you mean the thing that supports the rear of the top deck?
And still wanting to know if anyone has a solution for the locking center one-way. Thanks!
Old 02-15-2006, 08:35 PM   #4588
Solution for the center one-way do you mean the slop?
pops is offline   Reply With Quote
Old 02-15-2006, 08:38 PM   #4589
coons88's Avatar
No I mean this
Old 02-15-2006, 09:05 PM   #4590
No I mean this
haven't seen that happen, have been running a fixed center main gear with spool on asphalt and diff on carpet. Could it be the oil you've added?
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
