Old 02-06-2006, 02:47 PM   #4516
I saw someone (think it was Charlie F.) who had the positive battery wire go directly to the motor and then another wire from the motor to the ESC. Is this better or is a T connection just as good/better?
www.freerice.com
Help hungry people while learning.
smojoe is offline   Reply With Quote
Old 02-06-2006, 02:56 PM   #4517
I have the + wire go directly to the battery and then T off the + wire to the motor. I don't think it makes much if any difference.
pops is offline   Reply With Quote
Old 02-06-2006, 02:59 PM   #4518
other then having two wires to solder to one motor lug
www.freerice.com
Old 02-06-2006, 03:06 PM   #4519
ChadCapece's Avatar
The T connection has 4 solder joints whereas the straight line (1 pos wire) only has 3. I solder the motor + wire and the battery + wire at the tab on the esc. That gives me 1 less joint over the T connection, and a cleaner look and easier to solder than the straight line connection.
ChadCapece is offline   Reply With Quote
Old 02-06-2006, 04:06 PM   #4520
ChadCapece's Avatar
Originally Posted by H.Nilsson
bd and sdw
sweeeeeeeeeet rides
Old 02-06-2006, 04:32 PM   #4521
The Quatum was designed to only accept one wire to the tab. I can't see any difference if there is an extra solder at the tab or an inch up on the wire. It would be still be the same, it's still a soldered connection at the tab. Thats still 4 connections.
If you are worried about resistance, the best thing you can do is to replace the wires more often because of solder build-up on the ends of the wires.
Old 02-06-2006, 05:05 PM   #4522
ChadCapece's Avatar
What I try to do is frey out the wires that meet at the tab, then twist them together to sort of lock them to each other. A dab of solder on the tab, and a dab of solder on the top of the wires, and they bond to the tab fairly easy. It would seem like there would be more joints, but I connect the wires and only use enough solder to make one tab. It's hard to explain, and I don't have a good enough camera to show you, sorry.
Old 02-06-2006, 06:10 PM   #4523
how about capacitors? do you guys run them with the quantums?
www.freerice.com
Old 02-06-2006, 06:18 PM   #4524
I want to know too.
G2B Anthony is offline   Reply With Quote
Old 02-06-2006, 06:21 PM   #4525
ChadCapece's Avatar
I used to run a diode, but not anymore. It didn't make much of a difference, and I was running mod and 19turn at the time. Same experience with a capacitor. To me, stuff like that makes such a small difference, that your time would be better spent rebuilding a diff, or perfecting your shock rebounds.
Old 02-06-2006, 06:25 PM   #4526
No, I was told by two of the drivers on the back of the LRP box, that I didn't need to run them. I guess if you were running stock they would be OK. They tend to drain run time in Mod. They do (me too) run the heat sink that comes with the Worlds Kit.
Old 02-06-2006, 06:28 PM   #4527
ChadCapece's Avatar
me 4
Old 02-06-2006, 06:28 PM   #4528
Or T ing your pos wires J/K
Old 02-06-2006, 06:30 PM   #4529
ChadCapece's Avatar
hahaha, you got me there. I guess I'm selectively anal retentive.
Old 02-06-2006, 07:55 PM   #4530
I guess I could work on that because all mine end up looking like "y"s
I run stock and only stock ATM, so I guess I will go ahead and leave the cap on.
www.freerice.com
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
