Old 02-02-2006, 01:45 PM   #4486
Originally Posted by Dan Hughes
Nothing in particular, just seal the chassis and build away. The rear driveshafts will break if they take a heavy blow so be careful.
Cheers Dan....
Is there away roud the driveshafts or is it just a matter os having spares in your box?????
Cheers
Stu
RompingDonkey is offline   Reply With Quote
Old 02-02-2006, 01:50 PM   #4487
they wil break easily as they are lightweight aluminium made for the worlds spec sd car. so there not overally strong as masami generally doesnt crash much . if you had a set of tir rear driveshafts for the bd then they wud be great spares, extremely light and very strong. or you cud just get the normal bd driveshafts. upto you really .....
agower is offline   Reply With Quote
Old 02-02-2006, 03:50 PM   #4488
Originally Posted by seaball
i'll assume the vertical ball stud option goes away with those items? how does the camber link mount? i seem to remember a vertical tab on the old car...
please advise.
we should be able to make 4* work. personally, i always try to make that work anyway, as going away from that often yields on oddly driving car.
thanks.
You can only use a vertical ball stud on the older 5, 3, and 7 degree caster blocks. You will have to shave some material off the old style for them to work properly.
pops is offline   Reply With Quote
Old 02-02-2006, 07:26 PM   #4489
ChadCapece's Avatar
Originally Posted by RompingDonkey
Cheers Dan....
Cheers
Stu
Always have a smooth rear diff. This will help keep the breakages down. I've been running rear aluminium Tobee Craft aluminium universals for a while now and haven't had any problems.
ChadCapece is offline   Reply With Quote
Old 02-02-2006, 10:09 PM   #4490
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default Yok Stiff Chassis
Has anyone used the Yok Stiff chassis on carpet? Believe the part # is BD-002GH. I just ordered one, since my original chassis is cracked in the front (kydex bumper was a bit too hard).
Is anyone running Yok BD's in the east coast (Philly area) or will I be the only one.... I'll must convert all of them to YOKs.
olhipster1 is offline   Reply With Quote
Old 02-03-2006, 09:09 AM   #4491
Send a message via AIM to aoizip
olhipster1:
I'm pretty sure I was almost the only guy that race a yok at horsham(near philly).
~Ming
aoizip is offline   Reply With Quote
Old 02-03-2006, 02:12 PM   #4492
DaveC's Avatar
Default Yok BD chassis
Guys, if there is enough interest Team Pickles will make a BD carpet chassis. Check their thread on the T2 chassis and send them an e-mail.
DaveC is offline   Reply With Quote
Old 02-03-2006, 05:03 PM   #4493
olhipster1's Avatar
Default aoizip
aoizip, well at least I will have one person to compare track setups at horsham for my BD and LCG.
It's taken a bit of time to set the car up to react the way I wanted to run on ozite with foam, but it's pretty much on the mark now.
Just need to get my driving skills up to par now.
Are you running foams or rubber tires? stock or something else?
talk to ya later.
OL.
Old 02-03-2006, 09:59 PM   #4494
Is anyone else having problems keeping the batteries in with the stock strap? Is there another strap you can use?
No, I don't want to use tape. I have for three weeks now and am sick and tired of it.
www.freerice.com
Help hungry people while learning.
smojoe is offline   Reply With Quote
Old 02-03-2006, 10:24 PM   #4495
DaveC's Avatar
Single sided foam on the bottom of the battery strap will fix the battery ejection problem.
Old 02-04-2006, 03:06 PM   #4496
Rowdy's Avatar
Originally Posted by highwayman
rowdy : cool... great job... could this be the next upgrade to the BD?
Yeah I should hope so. Then all they would need to do is move the rear diff closer to the center of the car and design a smaller more compact steering rack assembly, similar to the cyclone. So what do others think would be good improvments on the currnt BD. You know the Worlds aren't to far away we may be seeing a new model BD soon.
Rowdy is offline   Reply With Quote
Old 02-04-2006, 03:14 PM   #4497
Hi,
for a new version of the BD (or a complete new car?) I would expect things like that:
-narrower, stiffer chassis
-new diff outdrives (aluminium or delrin)
-new one way outdrives for more free spin (the Xray ones are amazing and fit the BD)
-a better center shaft (the stock one wears out very quickly)
I think that's all.
Cheers
Chris
speedy-932 is offline   Reply With Quote
Old 02-04-2006, 03:25 PM   #4498
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
I have battery strap problems, but seeing as I still run 3300's i've put all the blame on that. I can run 5 mins withou hitting barriers, but usually cant run 5 mins without someone hitting me..
I've resorted to tape and the battery brace, the battery stayed in last night after a fairly big crash.
v0rtex is offline   Reply With Quote
Old 02-04-2006, 06:00 PM   #4499
I have to ask you, did you put the single sided foam tape on the battery strap? I don't know anyone who is throwing out batteries unless they failed to put the foam tape on the strap.
Old 02-04-2006, 07:08 PM   #4500
ChadCapece's Avatar
To move the batteries closer in, they would need to move the motor further back, or move the spur gear more away from the centerline.
What I'd like to see:
-Servo setup sideways, like most cars
-more compact steering assembly
-open top ball cups and 2.5mm hex holes in the ball studs
-one-way AND spool included
-locked center shaft, instead of the one-way center shaft
-stiffer chassis design (just less cutouts in the plate would work)
-different castor c-hubs available
-graphite arms
-more durable universals
that's it
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
