Old 01-31-2006, 02:18 PM   #4471
have u got any pictures of the chassis on a car?
mwoods is offline   Reply With Quote
Old 01-31-2006, 02:20 PM   #4472
Hi,
no sorry, I will wait until the end of the week to see if there is an interest in the chassis and will order then some. Or just one for me if noone is interested.
Cheers
Chris
speedy-932 is offline   Reply With Quote
Old 01-31-2006, 02:48 PM   #4473
i will have 1 if its going to be good on a tarmac track?
Old 01-31-2006, 03:08 PM   #4474
Send a message via MSN to Zacharopoulos
Any drawings for the upper deck??
Also an advise , the lower deck looks like a carpet deck , also with the 3mm thickness , it will be very unflexible !!!
I suggest to keep the 3mm but to find some points to dremmel , maybe under the servo or speedo , also something for th emotor maybe??
I like my car with a lot of steering and with unflexible decks but i think that this will be too much !!!
Zacharopoulos is offline   Reply With Quote
Old 01-31-2006, 11:32 PM   #4475
Hi,
@mwoods: We have to see whether it will work or not when the outdoor season starts. But you can always generate grip with the suspension.
@Zacharopoulos: Drawings of the upper deck will come later this day.
It looks like a carpet chassis? It is a carpet chassis.
I don't think the chassis will have any cut outs beside the batteries. But you can get the same chassis in 2.5mm, 2mm, 1.5mm or even 1mm. Enough flex.
Cheers
Chris
Old 02-01-2006, 03:09 AM   #4476
Rowdy's Avatar
Here's some pics of a chassis I made for my own personal use. It is 22mm narrower then standard, batts moved 8mm closer to center, servo moved 8mm closer to center, drive train lowered by 2mm, topdeck lowered by 3mm, roll center remains the same as standard.
I have only had limited runtime with the chassis, but the one time I had it on the track it proformed extreamly well.
Rowdy is offline   Reply With Quote
Old 02-01-2006, 05:15 AM   #4477
highwayman's Avatar
rowdy : how did you lower the drivetrain ?
highwayman is offline   Reply With Quote
Old 02-01-2006, 05:46 AM   #4478
Hi,
@Rowdy: Nice work.
I understand how you moved the spurgear more towards the motor (nice spacer) , but how were you able to move the servo 8mm closer to the centerline without removing the inner servo mount?
Cheers
Chris
Edit: Attached the top deck.
Old 02-01-2006, 08:01 AM   #4479
Send a message via AIM to aoizip
Rowdy --- Nice work....
speedy-932 -- a narrow chassis by any chanse... for lcg also...
thanks
aoizip is offline   Reply With Quote
Old 02-01-2006, 08:17 AM   #4480
Hi,
I will order my chassis on Friday (if anyone wants one for sure I will order one for him aswell).
A narrower chassis should work a lot better but you will always have the problem that not every servo will fit perfectly. But I will see what I will do for the outdoor season...
Cheers
Chris
Old 02-01-2006, 02:10 PM   #4481
i would say that he milled the chassis for the bulk-heads. this is the only way i think he could have done it, please correct me if i am wrong
flysti is offline   Reply With Quote
Old 02-01-2006, 06:21 PM   #4482
Hi
I have just bought a Yokomo MR4TC BD BRCA Grainger Special Edition...
I was just wondering if there any do's or donts or tips when building it?
Stu
RompingDonkey is offline   Reply With Quote
Old 02-02-2006, 12:23 AM   #4483
Rowdy's Avatar
highwayman - I lowered the drivetrain by milling 2mm of the bottom of the bulkheads. I then shimmed the inner camber linkages back up to their original position to keep the same roll center.
speedy-932 - I did remove the inner servo mount and just use the outer one and shoo goo to secure the servo in place. Also I connect all the electronics together with d/s tape which seems to help hold everything in place nicely.
I'm very keen to give the chassis some more track time, but unfortunatly I haven't been able to find the time lately. I was a little worried about how the changes would effect the cars handling but i must say it performed well above what i had hoped for.
Old 02-02-2006, 06:03 AM   #4484
Originally Posted by RompingDonkey
Hi
Stu
Nothing in particular, just seal the chassis and build away. The rear driveshafts will break if they take a heavy blow so be careful.
Dan Hughes is offline   Reply With Quote
Old 02-02-2006, 09:24 AM   #4485
highwayman's Avatar
rowdy : cool... great job... could this be the next upgrade to the BD?
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
