Old 01-14-2006, 11:40 AM   #4291
Send a message via MSN to Zacharopoulos
I think that is a lexan cover for our differentials , so it will not let the dust to go in !!
So , more running time without rebuilding and cleaning!!!
Zacharopoulos is offline   Reply With Quote
Old 01-14-2006, 11:48 AM   #4292
Francis M.'s Avatar
Originally Posted by speedy-932
Hi,
@asw7576: I've seen it today that I don't always need that much steering. This weekend is a qualifiying round for the german nationals and the trick is tight but with a 3 sweepers and 2 super-fast 90 degree corners. The rest are hairpins where I need steering but I have to concentrate not to turn too much on the wheel in the fast parts because I loose too much corner speed.
@Turtlemaster: There is 4mm spacer in the front of the arms.
@Francis M.: Send me a PM and I will change my CAD drawings for you a bit...
Cheers
Chris
thanks speedy, After you posted what you did to your steering rack and c hubs i did take a look at my bd vs my friends RDX and you are right the rdx has more mechanical throw.
Francis M. is offline   Reply With Quote
Old 01-14-2006, 12:04 PM   #4293
Send a message via AIM to R/C Anonymous
two guys at the local track took Corally RDX steering racks and installed them on their BDs running 19turn foam...they turned the servo sideways also and they were getting faster lap times like that
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 01-14-2006, 01:05 PM   #4294
Hi,
@Francis M.: That's exactly the point. If I want more steering I can get it. And if not... then not...
@R/C Anonymous: I heard that twice now and can't imagine how it works. Do you can take a photo and show it up here?
I remarked a problem with more steering throw. I glued a set of tires for tomorrow on JB wheels. The problem is at full steering throw the rim will rib against the A-Arm... but no problem for me and my Dremel... Problem fixed...
Cheers
Chris
speedy-932 is offline   Reply With Quote
Old 01-14-2006, 08:46 PM   #4295
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey speedy-932,
If ya want more steering yokomo has a inline steering blocks you can use part# SD415S this should help
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 01-14-2006, 09:23 PM   #4296
I raced my BD on a tiny carpet track (36 ft X 45 Ft) today against x-ray's and Corally's. The longest straight was only 12 ft long. I didn't need to have 100% steering throw to steer as well or out steer any of the other cars; in fact I ran 87% steering throw. I can't imagine needing to modify my car so it steers more; it already steers to much. Not to mention the more your wheels turn the more speed you will scrub off; slowing you down. I easliy took TQ and the win; and I was the only non Corally or X-ray car in the A-main. By easily I mean 2 laps on 2nd place a "Corally."
kmorast is offline   Reply With Quote
Old 01-14-2006, 10:24 PM   #4297
Hi,
@mike ivy: Already built in.
@kmorast: What class are you running? I only run modified and sometimes 17T. In modified im always looking to improve steering but in stock/17T you have to concentrate on keeping corner speed. There you don't need that much steering throw.
Cheers
Chris
Old 01-15-2006, 12:42 AM   #4298
Today was stock; but I also race mod.
Old 01-15-2006, 03:13 AM   #4299
hey guys im really fed up with the bd.......
i run stock 27 turns,
every time i race the little pin the goes through the dogbone and the steering nuckle allways snaps and causes my right or left wheel to lock up whats the best way to stop this happen iv spent 170$ on new pins....
thanks in advance jamie
jamie814340 is offline   Reply With Quote
Old 01-15-2006, 05:02 AM   #4300
asw7576's Avatar
I notice that one too It happens since the day I have yokomo SD.......
Anyway, I cure it with super glue..... give it a liitle glue on the hole pin and the screw. Becareful okay..... don't let the super glue flow to rotating mechanism.
Old 01-15-2006, 05:24 AM   #4301
i had the same problem originaly when i ran my yokomo sd, but i solved it by changing to the tir cvds avaliable from www.titaniumracing.com and didnt break a single bit of them indoors or outdoors. or you can use the hardend universals, i got mine from speedtech of them and didnt break a single one.
agower is offline   Reply With Quote
Old 01-15-2006, 06:56 AM   #4302
Does anyone know if the rear sway bars are available from rayspeed , or the part number for the genuine yokomo sway bars??
The part number for the front rayspeed sway bars is RS-25 right??
Old 01-15-2006, 07:32 AM   #4303
ChadCapece's Avatar
Wow! $170.00 on pins. No wonder they are usually out of stock, b/c you've bought them all .
Either take large shrink wrap and cover the axle where the pin goes in/out. OR buy Yokomo hardened universals OR buy TiR cvd's
ChadCapece is offline   Reply With Quote
Old 01-15-2006, 12:21 PM   #4304
Hi,
@kmorast: Ok, if it works for you. I took out a bit steering throw today (grip came up) aswell because the rear came around when I turned to hard on the wheel.
@jamie814340: Like mentioned befor you could use TiRacing or Yokomo universals or you could use the pins from Alex Racing for Barracuda. I used them in my LCG and never snapped a pin. Or you do it how I did and use a thicker pin. 1.5mm hardened steel or spring steel will do it...
@Zacharopoulos: RS-25 for the rear Rayspeed swaybars and ZS-412FSP for the front Yokomo swaybars.
Cheers
Chris
Old 01-15-2006, 12:31 PM   #4305
Greg M's Avatar
When I've snapped a pin and had no spares, I've used an allen key. Come to think of it, one of my fronts is still an allen key
Greg M is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
