Old 01-10-2006, 08:20 PM   #4246
probably like $8 shipped thru standard mail. Let me test it out this weekend to make sure its all good before I try to sell them.
stumper is offline   Reply With Quote
Old 01-10-2006, 08:27 PM   #4247
Jochim_18's Avatar
Cool I'm getting one of those.
Old 01-10-2006, 08:33 PM   #4248
ChadCapece's Avatar
If they work for you, you'll sell one to every BD owner with $8.00 to spare
ChadCapece is offline   Reply With Quote
Old 01-11-2006, 07:40 AM   #4249
Send a message via AIM to aoizip
I'll pick one up of those steering plate also.
aoizip is offline   Reply With Quote
Old 01-11-2006, 09:55 AM   #4250
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
I'm guessing the 3 holes on your version are in the same place as the front, middle and rear holes on the std plate? Very nice, good work! Just wonderin about what happens if you would normally run in the 2nd from front and std hole positions? I've gotta get me one of these, but tbh I've never broken a rack yet in the 7 months of racing the bd twice a week indoors and out, but better safe than sorry!
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 01-11-2006, 10:06 AM   #4251
Yeah thats the holes that I used. I could easily add the others if needed. I originaly did it like that because I was going to use 3mm c/f and wanted to make it alittle more stronger right there. But with the alum . I dont see it being very weak with all the holes.
Old 01-11-2006, 12:53 PM   #4252
ok dumb ? if i counted the pullys right and did the math right the I.R. of this car is 2.00 am i right or not?
TEAM GENESIS R/C, Roche P12 2017, Roche F-1, PAINT BY MIKEY
onroad dude is offline   Reply With Quote
Old 01-11-2006, 12:58 PM   #4253
Yeah its 2.0 .
Old 01-11-2006, 06:12 PM   #4254
TC_Tuner's Avatar
Trader Rating: 34 (100%+)
Default pics
Originally Posted by Big KAT
TC_Tuner. . . I would like to see some pics of your steering rack and the rest of your ride. Thanks.
here's a few pic of my BD...
FYI, Tamiya (sp?) rear sway bars fit pretty good with a simple bend on the ends. Need to be careful to bend them so the bar is flat, but worked pretty good.
See the rear on my chassis image.
10-4
TC_Tuner
Eric
Yokomo MR4TC-BD-body.jpg   Yokomo MR4TC-BD-chassis.jpg   Yokomo MR4TC-BD-gear_detail.jpg   Yokomo MR4TC-BD-steering-rack.jpg
Airtronics | Byron's Fuel | Pro-Line | OS | Kyosho | Ballistic Batteries | RIP Al's Hobby Shop
MRX4-X F180 Cobra Zipper Kart Yokomo BD Cup Racer FM1e Recoil M18 Pro Scalpel dNaNo Baja 5T HB D8 Vorza ERevo Savage Flux SCX10 GT2 T4 Slash Ten SCTE Blitz ESE HB Cyclone D4 Mini ERevo Vendetta ST Mini T Micro T
TC_Tuner is offline   Reply With Quote
Old 01-12-2006, 04:02 AM   #4255
Send a message via MSN to Zacharopoulos
looks very nice but it would be nicer if the steering plate was blue anonized!!!!!!
Zacharopoulos is offline   Reply With Quote
Old 01-12-2006, 05:51 AM   #4256
TC_Tuner's Avatar
Default steel is real...
for my rack, I chose to make it out of steel. Weight wan't a concern to me for a small part - function was top priority. I sprayed clear over it so it wouldn't rust too easy. No anno on steel, from what I know.
The new plate, new RPM ball cups, and installing the linkage on the bottom as made all the difference. What was once the weakest area of the car is now bomb proof.
TC_Tuner
Old 01-12-2006, 07:29 AM   #4257
DaveC's Avatar
TC-Tuner,
I noticed that it doesn't appear that you are running a schottky diode with your Novak GT7. Do you experience any problems running a 27t motor like that? Any help would be appreciated, as I am trying to clean up the wiring on my BD.
Thanks,
DaveC
DaveC is offline   Reply With Quote
Old 01-12-2006, 08:37 AM   #4258
I've seen alot of setups that have the front C-hub mounted from the lower hole to the arms. I guess the spacer below the steering knuckle has to be moved above? What's the benefit from this compared to the stock setup?
Just by looking at it I noticed that by doing this the upper kingpin is binding the steering when tightened, as the unthreaded sectiong of the pin is not long enough to make the pin sit tight on the knuckle. Hard to explain but I hope someone understands....
JohnDoe is offline   Reply With Quote
Old 01-12-2006, 08:58 AM   #4259
The lower holes has better turn in and better on power steer, but a little bit less in mid-corner. Most people are using the lower holes/spacers on top set up now.You can mount the camber link on the shoulder( one of the three holes, usually the middle one), or you can dremel, grind down the top of the C-hub by exactly 1mm(better have a digital caliper), the kingpin ball can thread all the way in without binding, the ball cup will not rub the wheel. Oh don't forget to set the front shocks to 62mm.
caveman is offline   Reply With Quote
Old 01-12-2006, 10:16 AM   #4260
Is'nt there a big difference in behaviour of the car when using one of the three holes in the shoulder vs. the "normal" position?
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
