Old 01-07-2006, 12:52 PM   #4186
Originally Posted by stumper
Ok I just bought a used BD . It needs a diff pulley and since I like dual diffs I want a diff up front. but the problem is everywhere I look the diff pulleys are out of stock........ Does the diff pulley suck that bad that everybody is buying them up??
No, they don't seem to wear out at all. Could be a glitch in ordering them. Where have you checked that they are out of stock?
pops is offline   Reply With Quote
Old 01-07-2006, 12:56 PM   #4187
Originally Posted by asw7576
1. Remove the bearings
2. Give super glue to the bearing holes on the steering plate
3. Put back the bearings.
This is a very good fix. While you are at it to help strengthen the plate, CA the inside holes where the ball studs mount and also CA the edges all around the outside of the plate. This does strenghten the plate. I have seen a few break where the ball studs mount.
Old 01-07-2006, 01:00 PM   #4188
Both speedtech and stormer is out of them. I did however find everything I need at Horizon !
stumper is offline   Reply With Quote
Old 01-07-2006, 01:00 PM   #4189
Big KAT's Avatar
I'm in the same boat, Stormer and Speedtech are out of stock. I ordered one from Yokomo USA, but haven't recieved a confirmation if they have any or not yet
Xray
Big KAT is offline   Reply With Quote
Old 01-07-2006, 01:13 PM   #4190
I just ordered 3 from horizon and they're in stock.
Scratch that......I only got one, 2 are back ordered.......
Old 01-07-2006, 04:24 PM   #4191
ChadCapece's Avatar
A tip I've got for the gears.
Take a hobby knife and a bottle of CA glue. But a ring of CA around the thin gap between the gear and the shield that keeps the belt from coming off. The gap is on the outside, opposite of the side that touches the belt.
Then take the knife and run it along the line of CA to remove excess.
This should keep the shield from coming off and your gear will last longer.
Steering rack: http://rctech.net/forum/search.php?searchid=330293
ChadCapece is offline   Reply With Quote
Old 01-07-2006, 11:11 PM   #4192
Jochim_18's Avatar
Like they said CA the stering plate at the holes and arounf the edges, And then get yourself a servo saver for your servo. This will help prevent the steering plate form breaking. Slop is not really a problem.
Old 01-08-2006, 02:22 AM   #4193
hi guys, sorry to interrupt your Yokomo thread, a tamiya 415 driver here. looking at getting the BD battery tray. instead of using tape all the time on my 415
i need the posts and the plate, i a bit confused with the part number as i don't have the manual. what part do i need
BD-118G MR-4TC BD GRAPHITE BATTERY PLATE
BD-118M MR-4TC BD ALUMINUM SPECIAL BATTERY POST
BD-118T MR-4TC BD BATTERY TRAY
also does the strap work good? coz i see it is held only by body clips and not a screw down one. is there issues with it? is it adjustable?
any help appreciated
thanks
qwerty is offline   Reply With Quote
Old 01-08-2006, 03:25 AM   #4194
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
I never had issues with the strap, but lately i've gone to taping in the cells though simply to keep out as much tweak as possible.
v0rtex is offline   Reply With Quote
Old 01-08-2006, 10:09 AM   #4195
thanks
As long as you use the foam on the battery plate, the battery (3700 and 3800) will be tight and secure.
Old 01-08-2006, 10:47 AM   #4196
Default White Belts
Is there anywhere apart from Speedtech that do the white belts?
Sponsored by Team Wave Online
www.teamwaveonline.com
stuartb is offline   Reply With Quote
Old 01-08-2006, 10:54 AM   #4197
Originally Posted by stuartb
Ive seen a few drivers running white belts ala 415 - does anyone know where these are from?
They're from Team Bomber.
Old 01-08-2006, 11:18 AM   #4198
I know Speedtech do them but does anywhere else?
Old 01-08-2006, 01:07 PM   #4199
I've tried looking for them. RainbowTen carries Team Bomber, but not the belts. I can't find them anywhere except Speedtech. I think they will be getting them in the next few weeks.
Old 01-08-2006, 01:11 PM   #4200
Send a message via MSN to Zacharopoulos
Sorry guys but is it possible to tell me the difference between the Yokomo genuine belt and the white belt??
Also which hop up do you suggest me to buy??
Zacharopoulos is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
