Old 01-06-2006, 04:07 AM   #4171
Send a message via MSN to Zacharopoulos
Hello guys , i am new to the forum , and i would like to help me..
Tomorrow i will start building my first yokomo BD and i would appreciate it if you could tell me on what points i have to pay attention , and also to show me some points that they have "problems" and tell me how i can fix this problems!!
Zacharopoulos is offline   Reply With Quote
Old 01-06-2006, 04:14 AM   #4172
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
Read the instructions over before beginning, and build slowly making sure there is no binding in arms etc.
Races are won on the track, not by building the kit the fastest Having said that, the BD is a pleasure to build.
One thing to take note of is the diff adjusting cams, dont cut the lugs off the inside of them! they're used to locate the diff adjusters in the housing Sure only a few dollars to replace, but it could cause a heap of frustration.
All the usual things can be done, soak the belts in wd40, soak the bearings in shellite or motor spray and re-oil with a light machine oil before installing them in the car and you'll have a super free drivetrain
v0rtex is offline   Reply With Quote
Old 01-06-2006, 04:16 AM   #4173
Also, be careful with the direction of the center one-way, its caught a few people out as thier cars are accidentally 2wd once they finish because the one way is backwards
Old 01-06-2006, 05:01 AM   #4174
Thumbs up
ok thank you , i will keep in mind
Old 01-06-2006, 10:12 AM   #4175
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
make sure you read the supplement sheet(s)
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 01-06-2006, 10:14 AM   #4176
oooooooooooooookkkkkkkkkkkkkk!!!!!!!!!!!!!!!!!!!1
Old 01-06-2006, 11:43 AM   #4177
pitshop's Avatar
Trader Rating: 56 (98%+)
Originally Posted by jamie814340
hey guys i need everyones yokomo bd ashpalt outdoor setup, the track im on is ryper hobbies it is a tight track and needs alot of steering.
I need the setups to be detailed as possible
thanks jamie
hey who operates ryper nowadays??
PIT SHOP 153-D Araneta Avenue
Q.C. opposite PNB between SM Sta Mesa and So En
tel (632)716-6553 fax (632)714-0550
YOU CAN CALL 09174632746 OR 09175331943
please like us on FB - PITSHOP RC
pitshop is offline   Reply With Quote
Old 01-06-2006, 01:28 PM   #4178
Good idea to take the belts out of the packet and hang them up with a weight on the bottom. This allows them to go into there proper shape. They are packed in quite a small bag and thus come out in a rather odd shape.
Other than that happy building, build the car as per manual, using the kit oil and everything. Its a very good car straight out of the box.
Schumacher
Team Sorex
EA Motorsports
Speed Passion
East Coast Bodies
John Pape is offline   Reply With Quote
Old 01-06-2006, 01:50 PM   #4179
ChadCapece's Avatar
If you run modified, keep the bearings in stock condition w/ the grease. After a few runs in mod, the excess grease will be thrown out, and the bearings will be free and less likely to lock up (compare to running on oil). If you run stock, go ahead and spray them out and put in some lightweight oil.
ChadCapece is offline   Reply With Quote
Old 01-06-2006, 01:52 PM   #4180
I am going to run with 7 or 8 turns motor !!!
Old 01-06-2006, 01:56 PM   #4181
ChadCapece's Avatar
I try to practice w/ mods all I can b/c my track runs 19turn. I've lost a few of the smaller bearing in the hubs after I cleaned them out and oiled them. Then I put in a whole new set and after a few high speed runs, I noticed the extra grease was thrown out of the seal and the car had plenty of freespin. After about 20 runs on those bearings, they are still smooth and none have locked up.
Old 01-07-2006, 10:20 AM   #4182
Guys i have just finished building my new BD and i noticed that something is wrong at the beellcrank , i mean that the carbon plate isn't very well stabilised at the bellcranks !! Does anyone else have the same prob??
Old 01-07-2006, 11:16 AM   #4183
Default diff pulley
Ok I just bought a used BD . It needs a diff pulley and since I like dual diffs I want a diff up front. but the problem is everywhere I look the diff pulleys are out of stock........ Does the diff pulley suck that bad that everybody is buying them up??
stumper is offline   Reply With Quote
Old 01-07-2006, 12:19 PM   #4184
Zach: The carbon plate does wobble a bit, it's not a fault. I know some people have used different bearings and washers to try and stop the wobble but I don't really see it as a problem.
Stu
CML | TiR | Microtech Racing | Tubz Designz
StuartC is offline   Reply With Quote
Old 01-07-2006, 12:41 PM   #4185
asw7576's Avatar
Stu
1. Remove the bearings
2. Give super glue to the bearing holes on the steering plate
3. Put back the bearings.
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
