Old 01-01-2006, 09:51 AM   #4141
Originally Posted by smojoe
hey pops, where were you this wednesday? I was looking forward to meeting you/ picking your brain for information.
Work came first.....
pops is offline   Reply With Quote
Old 01-01-2006, 10:45 AM   #4142
Sleighty's Avatar
anybody got the part no. for the hpi titanium ball studs?
cheers
A1-RC.com
Team Scream
Xray
Sleighty is offline   Reply With Quote
Old 01-01-2006, 11:24 AM   #4143
ChadCapece's Avatar
http://www.speedtechrc.com/store/ebp...?catmainid=341
Square make the ball studs
ChadCapece is offline   Reply With Quote
Old 01-01-2006, 02:28 PM   #4144
Jochim_18's Avatar
I have the same problem using a front spool on my car, So I switched back to double one-way on one of my BD and love the way the car handles, But on my other BD I use a front diff for 19T Class.
Of all the car I have ever driven YOKOMO BD is the best. I've have been running consistent week after week with this car.
Old 01-01-2006, 02:39 PM   #4145
ChadCapece's Avatar
I think my local track might be switching to stock instead of 19t or mod, so I might not have to worry about breaking spools until the next time I travel out of town.
Old 01-02-2006, 06:55 AM   #4146
hey guys i need a good setup for rubber tyres.
i run a 27 turn team brood motor, the tyres i use are cs 32s with a medium insert.
The track is ryper hobbies it is a tight track and needs alot of steering but i cant seem to find a good setup thanx jamie.
jamie814340 is offline   Reply With Quote
Old 01-02-2006, 11:39 AM   #4147
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Jamie,
What surface or you running on asphalt of carpet I have a asphalt setup that corners very well like a Xray car
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 01-02-2006, 11:44 AM   #4148
Hi, Mike
Can you post your set up, I need a good asphalt set up also. Thanks
caveman is offline   Reply With Quote
Old 01-02-2006, 12:52 PM   #4149
Sleighty's Avatar
hi everyone,
ive just been looking at a few setup sheets from uk racers. Chris Grainger uses Tamiya shock piston #3, why would this be any better than the yokomo one? does anyone know the difference and does anyone know the part numbers for the pistons that will go into the yokomo shocks?
thanks
A1-RC.com
Team Scream
Xray
Old 01-02-2006, 01:07 PM   #4150
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
the yokomo pistons are slightly to "small" for the yokomoshocks. theres a gap betwen the piston end the wall of the shocks, which oil can go through. Tamiya Pistons fit perfectly. I use them too in order to have better working shocks.
with rubbertires I always used 35WT Losi Oil on Asphalt.
Martin Hofer is offline   Reply With Quote
Old 01-02-2006, 01:11 PM   #4151
i thought it was becuase the tamiya pistons already have 1mm hole in them so it is easier and more precise than drilling the yokomo pistons out
agower
agower is offline   Reply With Quote
Old 01-02-2006, 01:16 PM   #4152
Sleighty's Avatar
thanks for that...
do you have the part numbers?
A1-RC.com
Team Scream
Xray
Old 01-02-2006, 01:17 PM   #4153
Tamiya only has two & three holes pistons, I suppose Chris Grainger use three holes pistons(not #3). It has three 1.1mm holes and 9.9mm in diameter. While Yokomo pistons have smaller diameter, 9.72mm. So the gap between piston and cylinder wall is quite big. I see a lot of yokomo set up from masami and other japennese drivers use yokomo #3 pistons with holes enlarge to 1.0mm. I try both piston last summer, Tamiya 3 holes pistons has a bit more grip but the differece was small. Tamiya pistons are a bit thinner, so you will need some thin motor shims to take up the gap. part # 53573.
Old 01-02-2006, 01:18 PM   #4154
actually .... no :-) cause I got them from a friend.
Old 01-02-2006, 01:33 PM   #4155
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
you really need to use the different pistons or drill out the std holes when using oil thicker than 50wt, the oil is too thick and can lead to very unprogressive shocks on the bench and dodgy handling on the track.
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
