Old 12-31-2005, 07:03 PM   #4126
ChadCapece's Avatar
If you keep the same size pinion gear, a larger spur will give you more acceleration.
ChadCapece is offline   Reply With Quote
Old 12-31-2005, 07:08 PM   #4127
Hey guys what are some upgrades i can do to my yokomo?
jamie814340 is offline   Reply With Quote
Old 12-31-2005, 07:10 PM   #4128
Jochim_18's Avatar
So this mean I can get more punch? Which I really needed on my local track.
Old 12-31-2005, 07:14 PM   #4129
ChadCapece's Avatar
From order of necessicity:
1. P-Dub hard front bumper.
2. Place the steering turnbuckles below the bell crank plate and on the bottom side of the the carrier.
3. Use the Yokomo sway bar open ball cups for the bulkhead side of the camber links. Also, use HPI titanium ball studs on the bulkheads. That way you can just use a hex driver to take off the studs and remove diffs or change roll centers.
4. Use a button head screw for the outer servo mount (where the chassis makes a fin). That will allow the screw to grinde on the asphalt and not the chassis which will eventually snap off. ONLY do this mod if you run on asphalt that is bumpy or low traction.
5. Do a search on this thread for info on how to properly build a diff.
6. If you decide to run a spool, upgrade to either TiR worlds edition CVDs or Rayspeed axles and TC4 bones (which require much grinding, but are very durable)
7. Run 64 pitch gears
8. Get a servo horn with a built in servo saver.
9. Use RPM or Schumacher ball cups for the outer sides of camber links and all steering linkages.
10. Enjoy the best engineered belt driven car on the market. Then laugh at your fellow racers when they struggle to remove diffs or change spurs. (Disclaimer: This may cause bodily harm if fellow racers are 300lb bikers named Bubba)
Old 12-31-2005, 07:14 PM   #4130
ChadCapece's Avatar
Yes, but a smaller pinion will give you the same effect.
Old 12-31-2005, 07:20 PM   #4131
Jochim_18's Avatar
Yes! But with a larger spur I can have more option with gear ratio don't you think?
Old 12-31-2005, 07:42 PM   #4132
fastolfart's Avatar
Jochim_18,
For RYPER raceway, I think you should run a rollout of around 26mm for a Monster. For the Nats, I tried monsters, Epic ROAR stock, P2K2 pro and settled on a Green Machine 3 for RYPER. The reason for the choice, it just felt better in testing than the others through the first sweeper on the straight. I got all motors to run the same qualifying times durring Fridays practice, the main thing was tunning the chassis to work on the track and keeping the lines tight.
You are welcome to PM me if you have any other questions or need any help.
Peter
It is so hard to fix the driver, but so easy to blame the car.
fastolfart is offline   Reply With Quote
Old 12-31-2005, 07:46 PM   #4133
fastolfart's Avatar
PHEW did a bird crap on those solder joints
I think he needs a bit more heat in his soldering iron.
Old 12-31-2005, 08:07 PM   #4134
fastol i pm u ok about ryper raceway
Old 12-31-2005, 08:45 PM   #4135
JayBee's Avatar
Trader Rating: 31 (100%+)
Yeah..get the iron out of this guys hands
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 12-31-2005, 08:51 PM   #4136
Originally Posted by Barger
Pops...I used the yokomo hardened universals( same as those I presume)when I first got the BD with a speedtech spool.I went thru 2 sets..1 broke the uni 2 bent 2 shafts.I went to a front diff then and never had any more breakages.I am still trying to get the same steering as a spool but no luck as yet.I still managed to win the State titles in stock ...but I used a diff.
Yeah the steel spool is really hard on the universals or dog bones. Having much better luck with the Yoke plastic spool. Also we are using the Ti Racing Worlds CVDs, they are great.
pops is offline   Reply With Quote
Old 12-31-2005, 09:00 PM   #4137
hey pops, where were you this wednesday? I was looking forward to meeting you/ picking your brain for information.
www.freerice.com
Help hungry people while learning.
smojoe is offline   Reply With Quote
Old 12-31-2005, 09:26 PM   #4138
asw7576's Avatar
My friend gave up using a spool after losing 2nd place in national series. He switched to use one way again ( Slow In - Fast Out style ).
Old 12-31-2005, 10:31 PM   #4139
ChadCapece's Avatar
I SHATTERED a plastic spool today. It came out of my car in 6 pieces. I think I probably messed it up practicing w/ mod before the races, b/c when I raced it in the stock class, it broke after tapping a pipe. Anyone else experienced this w/ the plastic spool?
Old 01-01-2006, 02:10 AM   #4140
Chadcapece...A friend put one in a cyclone (with delrin ouydrives) and actually smashed it including the outdrives.This is why I have stayed with a front diff in my BD...maybe not as much turn in ......but no breakages!!!!!
The only car I have that has no problems with a spool is my 05 xray
Come on Yokomo get your act together!!!!!
Barger is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
