Old 12-30-2005, 09:06 PM   #4111
Originally Posted by jamie814340
hey what pinion and spur should i run with stock, i have a bd of course
Its ryper hobbies track and the straight isnt very long what would be a good starter point. thanx
jamie
Carpet or Asphalt? What kind of stock motor?
pops is offline   Reply With Quote
Old 12-30-2005, 09:08 PM   #4112
Just to let you guys know the new Yokomo hardened universals have come in to Yokomo USA. They are supposed to fit the SD and BD without any mods.
Old 12-30-2005, 09:11 PM   #4113
ChadCapece's Avatar
Speaking of those, what can be done to keep the pins from coming out after a few runs? I have a set for the front and the pins now come out b/c of the slight slop that has developed.
ChadCapece is offline   Reply With Quote
Old 12-30-2005, 09:16 PM   #4114
I'm not sure, never had much of a problem with the old ones, hopefully these will be better. I always put grease on the joints to reduce wear, and that seemed to help alot. Being the new ones will actually fit in the fronts, there should be less stress on them than the old ones.
Old 12-30-2005, 09:27 PM   #4115
ChadCapece's Avatar
I'll try some HPI grease or auto axle grease. That might make them stay in their place.
Old 12-31-2005, 05:22 AM   #4116
All you Yokomo guys can get some good set-up tips off Ali Graham....But dont ask him to solder your cells.......
Nick Simpson is offline   Reply With Quote
Old 12-31-2005, 06:55 AM   #4117
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
geez, what did he use as his iron, a candle?
v0rtex is offline   Reply With Quote
Old 12-31-2005, 07:01 AM   #4118
Lol...........
Old 12-31-2005, 07:37 AM   #4119
JRXS_chris's Avatar
Nick, you legend.
JRXS_chris is offline   Reply With Quote
Old 12-31-2005, 07:50 AM   #4120
pheyhoe's Avatar
R/C Tech Charter Subscriber
A candle lmfao.
That looks worse than mine did when i soldered my first battery pack at the age of 11 with a 20w iron
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 12-31-2005, 08:48 AM   #4121
Originally Posted by JRXS_chris
Nick, you legend.
Old 12-31-2005, 05:56 PM   #4122
Pops...I used the yokomo hardened universals( same as those I presume)when I first got the BD with a speedtech spool.I went thru 2 sets..1 broke the uni 2 bent 2 shafts.I went to a front diff then and never had any more breakages.I am still trying to get the same steering as a spool but no luck as yet.I still managed to win the State titles in stock ...but I used a diff.
Barger is offline   Reply With Quote
Old 12-31-2005, 06:21 PM   #4123
Jochim_18's Avatar
Your guys opinion on what size of spur I need to use on a tight carpet track "80x40". Right now I have 102 on my BD. I'm thinking of putting a much larger spur gear on my car like 115. Can I gain any advantage on running a much bigger spur on this type of track.
Old 12-31-2005, 06:40 PM   #4124
ChadCapece's Avatar
114 is the largest that you should "try" to fit in the car.
Old 12-31-2005, 06:51 PM   #4125
Jochim_18's Avatar
Is their a big difference in performance of the car when running a larger spur gear on a tight technical track?
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
