Old 12-20-2005, 09:19 PM   #4021
asw7576's Avatar
Originally Posted by Turtlemaster
i'm confused as all get out,, on the front hinge pin, when i have a spacer under the rear split mounts, and no spacers under the front, my front end is very "twichy" with it flat all around or up in the front it settles down.
and when grip is down, why do you go to a stiffer spring in front. i do the opposite, i go softer in front. maybe its just our driving styles
Let me confirm what you wrote, do you mean the position of front hinge pin is tilted downward / ( like aeroplane's landing position) ? If yes, then twichy (very responsive) is what you get. I don't like twichy handling, so I tilted upward \ for the hinge pins.
When grip is poor, I have lose rear traction when exiting out of corner under full throttle. I use harder front to make it slight understeer even at full throttle ( Actually I should exit softer and not full throttle ).
Old 12-20-2005, 10:27 PM   #4022
SpeedTech's Avatar
Hi Guys,
Just want to post a quick note that the Team bomber hop-ups for the BD are in stock
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 12-20-2005, 10:35 PM   #4023
ChadCapece's Avatar
awww man, I placed an order 2 days ago, and now I gotta pay $8 shipping again to get 2 belts .
ChadCapece is offline   Reply With Quote
Old 12-20-2005, 10:42 PM   #4024
SPRING RATES YOKOMO AND RAYSPEED
Can anyone assist me with the spring rates between Yokomo and rayspeed springs.
Thankyou
Calvin.
caltech1 is offline   Reply With Quote
Old 12-20-2005, 10:47 PM   #4025
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
I dont have the Rayspeed chart handy..
v0rtex is offline   Reply With Quote
Old 12-20-2005, 10:49 PM   #4026
Cool SPRING RATES
Thanks VORTEX all I need now is the Rayspeed info.
Cheers
Calvin.
Old 12-20-2005, 10:55 PM   #4027
tell us how much better they are, please.
www.freerice.com
Help hungry people while learning.
smojoe is offline   Reply With Quote
Old 12-20-2005, 10:58 PM   #4028
Shopkeeper's Avatar
Trader Rating: 35 (100%+)
caltech1
If you do a quick search of this thread with the search bar in the right of your screen, you will find that it has been posted a number of times in previous pages.
Shopkeeper is offline   Reply With Quote
Old 12-20-2005, 11:13 PM   #4029
Wink SPRING RATES
Thanks Shopkeeper. I have found what I wanted by using the search function.
Cheers
Calvin.
Old 12-21-2005, 07:10 AM   #4030
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
Originally Posted by utieh
Can you post your set-up??? .
sorry for slow response, have been away from my computer for a bit.
The carpet masters track is very flowing, not like many others with many fast, flowing corners with very high bite carpet, this might not work on a very tight, twisty track.
setup:
FRONT ONE-WAY
DIRECT CENTRE PULLEY (this where it's interesting, I originally used a 1-way pulley, it was smoother to drive but slightly slower. However, when running the locked you need to knock your steering trim forward a bit (electronically is the best way) to stop the car scrubbing out in corners and to help carry more corner speed)
FRONT:
NO ROLL BAR
INLINE STEERING BLOCKS
4*HUBS
2* CAMBER
0* SKID ANGLE
1MM UNDER BOTH SUSP. MOUNTS
6MM DROOP
ARM POS.:4-0
SSS SHOCKS
SHORT SHOCK END
63MM LENGTH
RAYSPEED RED SPRING
55 SHOCK OIL
SHOCK PISTON:3x1.1MM (make sure you drill out the std pistons or buy the rayspeed/tamiya ones as the thick oil struggles to get through the std holes)
1 O-RING
USED BOTTOM HOLE ON C-HUB, WASHER ABOVE STEERING BLOCK
OUTER HOLE ON WISHBONE
2MM UNDER INNER CAMBER LINK
INNER SHOCK POSITION ON TOWER
REAR:
NO ROLL BAR
O* HUBS
2* CAMBER
0* SKID ANGLE
0MM UNDER BOTH SUSP. MOUNTS
5MM DROOP
ARM POS. 2-2
SSS SHOCKS
SHORT SHOCK END
63MM SHOCK LENGTH
RAYSPEED WHITE SPRING
50WT OIL
3x1.1MM PISTON
1 O-RING
STD CAMBER LINK HOLE ON REAR HUBS
BOTTOM HOLE ON HUB
3RD OUT HOLE ON SHOCK TOWER
0MM UNDER INNER CAMBER LINK
5MM RIDE HEIGHT ALL ROUND
tyres were cs22 pre glueds, using jack the gripper additive, full on the back, quater on front tyres
the motor was an eXpress monster, with blue/green springs geared at 7.43
bodyshell was protoform g6, very neutral, I'm going to try a ride stratus mk.3 next round to give the car a slightly looser feel.
hope this helps!
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 12-21-2005, 07:53 AM   #4031
Ali Graham's Avatar
if anyone wants a short video to see how this setup goes shoot me an email and I'll send it you, only 6mb
Old 12-21-2005, 08:22 AM   #4032
Toe? Or do you run without toe-in in the rear?
Cheers
Chris
speedy-932 is offline   Reply With Quote
Old 12-21-2005, 09:15 AM   #4033
I'm a bit confused. What is the droop measurement shown in the setup sheets? I know what droop is, but the way it is measured is not clear to me. Please advice
JohnDoe is offline   Reply With Quote
Old 12-21-2005, 09:34 AM   #4034
Ali Graham's Avatar
Cheers
Chris
my mistake, I used 3* toe block
I measure my droop with the gauges that AREN'T hudy, ie ones that don't have minus- figures on them. I always measure to the bottom of the castor block. Yes this can be a problem when using the different hingepin holes, especially with the std setting when the block sticks out under the wishbone, but becoz this setting kills steering, rasing the wishbones (less droop) will get the response back. It's all very confusing and I'm sure there are hundreds of people that will disagree.
Old 12-21-2005, 10:15 AM   #4035
Sorry but don't know how to quote, but the new Team Bomber are belts are very good, I have friends who are yokomo team drivers and brought some back from the Japanese nationals. They noticeabley free up the car,the centre shaft reduces some of the slop found in the drivetrain.
I saw speedtech had all of it in and thus ordered it. Impressed with service and would recommend them to anyone.
Schumacher
Team Sorex
EA Motorsports
Speed Passion
East Coast Bodies
John Pape is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
