Old 12-18-2005, 08:55 AM   #3991
TC_Tuner's Avatar
Trader Rating: 34 (100%+)
Originally Posted by asw7576
Skid angle is the position of suspension arms relative to flat chassis : anti dive, level, pro dive
You adjust by adding or removing spacer below the hinge pins holder.
See the pics so you can get the idea.
So in Yokomo's setup sheets, they're sort of repeating themselves by listing 'skid angle' AND 'height spacer'. The one sorta defines the other...correct?
If this is the case, how is it on Masami's LRP setup, that he has -.5 degree on his front skid angle but also list .5mm spacer under both mounts? Does this make sense?
Thank you for any help here-
TC_Tuner
Airtronics | Byron's Fuel | Pro-Line | OS | Kyosho | Ballistic Batteries | RIP Al's Hobby Shop
MRX4-X F180 Cobra Zipper Kart Yokomo BD Cup Racer FM1e Recoil M18 Pro Scalpel dNaNo Baja 5T HB D8 Vorza ERevo Savage Flux SCX10 GT2 T4 Slash Ten SCTE Blitz ESE HB Cyclone D4 Mini ERevo Vendetta ST Mini T Micro T
TC_Tuner is offline   Reply With Quote
Old 12-18-2005, 09:26 AM   #3992
You can use no spacer in front mount and 0.5mm spacer at the rear mounts, you get 0.5deg anti-dive. Or you can put, e.g 1mm under front mount and 1.5mm under rear mounts, you still get 0.5deg anti-dive, but in this case you have a higher front roll center.
For the Masami LRP master set up, well, you will have to ask masami himself, but I think that's a typepo. More likely he only put 0.5mm spacer under rear mounts.
caveman is offline   Reply With Quote
Old 12-18-2005, 10:11 AM   #3993
Thomas Pumpler has won the "Lord of Touring" trophy at the GP Worldcup in Suisse with the Yokomo BD in front of Marc Rheinard and Andy Moore.
He had to start from place 10 but after this announcement
Surprise!!!!!!
The Lords of Touring Race will be runned backwards and the first pilot will be on the last place!!!
he was on pole and won the "Lord of Touring" race.
Cheers
Chris
speedy-932 is offline   Reply With Quote
Old 12-18-2005, 11:38 AM   #3994
can someone post some more "carpet with foams" setups; I'm having a lot of trouble getting 5mm of ride height with the droop settings I want.
www.freerice.com
Help hungry people while learning.
smojoe is offline   Reply With Quote
Old 12-18-2005, 12:35 PM   #3995
Smojoe, with carpet you need to set your ride height first, 5mm. You want about 2mm of suspension travel in the front until the front tires lift off the tweek board. For the rear you want 3 to 4mm of suspension travel before the rear tires lift off.
I do this by placing an 8mm thick flat object under the rear chassis of the car (so rear tires do not touch board). Remove the front bumper and un-do the front shocks at the suspension arm. Place the 7mm portion of the ride height gauge under the front of the chassis (5mm ride height + 2mm droop increase = 7mm). Now with the droop screws, adjust each arm until the front tires just lift off the board. You will get exactly 2mm of suspension travel. Do the same with the rear, just use 5mm ride height + an additional 3 or 4mm = 8 or 9mm total. I find this method is really the only way to get an accurate droop with foams for me.
pops is offline   Reply With Quote
Old 12-18-2005, 01:05 PM   #3996
on the setup you gave me, it said you used the long ball ends on the shocks. I installed those and had about 11mm of clearance and the only way I could make it lower was by running lower lbs. rating springs, cutting the springs, or using the droop screws to lower the height (using the shock geometry that I wanted, at least)
*edit*
with the short shock ends, I have 5.5mm RH in rear with a 5-6mm droop possible but on the front I have a max RH of 3.5mm and 0 droop. I will try long shock end on just the front now...
www.freerice.com
Old 12-18-2005, 01:54 PM   #3997
*edit*
Crap, I'm sorry, that's a typo, should have been a short shock ends! I am sorry! Use only the short ends..
Old 12-18-2005, 02:11 PM   #3998
how did you get enough ride height with the short shock ends in the front?
*edit* nevermind, I got 5.5mm RH all around with about 3mm avalible droop in the front. unthreaded the front shock ends about 1mm and moved the lower shock mount to the innermost hole.
www.freerice.com
Old 12-18-2005, 05:36 PM   #3999
Running 62mm shock length in front, mounted in middle hole on arm and 2nd hole from outside on the tower.
Old 12-18-2005, 10:06 PM   #4000
62mm... magic. Thanks pops! too bad there isn't racing for a few weeks at stockton...
www.freerice.com
Old 12-18-2005, 10:22 PM   #4001
I think there is racing on the next two Wednesdays.
Old 12-18-2005, 10:37 PM   #4002
seriously? It isn't on the website... you going on wednesday so you can help a poor kid out?
www.freerice.com
Old 12-19-2005, 05:27 AM   #4003
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
Hi guys, the car was absolutely awesome at carpet masters round 2 yesterday, it was just dialled! Corner speed was fantastic and it was perfectly flat, and not a hint of grip roll on cs 22 gls! Qualified second in 27T but in the first leg of finals got serverely battered knocking a corally off my cells, but after 2 legs I finished 6th overall, oh well.
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 12-19-2005, 06:27 AM   #4004
utieh's Avatar
Can you post your set-up??? .
utieh is offline   Reply With Quote
Old 12-19-2005, 08:14 AM   #4005
Yeah, posts your set up. please.
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
