Old 12-12-2005, 09:21 PM   #3961
Jochim_18's Avatar
Right now I don't have any problem balls cups popping out. I used the associated short ball cups works pretty good. I like my car nice and simple.
Old 12-12-2005, 09:26 PM   #3962
Jochim_18's Avatar
question guys does the aluminum steering plate for LCG will fit the BD? Seems like the CF steering plate for the BD break easy.
Old 12-12-2005, 10:48 PM   #3963
asw7576's Avatar
use ca glue to fix the the edge and the holes.
use washer top and bottom ( sandwich style ) so the screws don't flex.
Old 12-12-2005, 10:56 PM   #3964
asw7576's Avatar
Originally Posted by diesel
Thanks guys for the valuable tips and suggestions.
asw7576: thanks for posting the pics...nice mod you have there. Correct me if i am wrong but your mod seems to have not only solved the popping ballcups problem but also the the kingpin thread stripping problem in the hubs.
Might just give this mod a shot but may shorten the xray connectors instead of buying shorter turnbuckles and see how well it holds up.
Here is the mod I did to my BD
For shock pictures, I also use MTX4 ball end connectors. The ball end fits into yokomo shock connectors SS and SSS.
Yokomo MR4TC-BD-king-pin.jpg   Yokomo MR4TC-BD-kingpin2.jpg   Yokomo MR4TC-BD-connectors.jpg   Yokomo MR4TC-BD-shock.jpg   Yokomo MR4TC-BD-shock2.jpg
Old 12-13-2005, 12:43 AM   #3965
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default LCG steering plate
Jochim,
the LCG aluminum steering plate will fit the BD...but a little drilling will have to be done to the plate. The big down side to this is that you will pick up the same steering slop the LCG utilizes from the bearings.
the LCG position the servo arm pivot ball in a layed down position but the BD steering plate pivot ball is in a stand up position.
if you drill dead center (where the zero mark is on the steering plate) and place the pivot ball standing up it should work...it works but it's a really tight fit. You will have to get just the right servo saver and use the open head Yokomo ball cup.
I may try it again in the next few weeks with the LCG hopup plate with the +- 1.5 ackerman adjusment, if I could find a pivot ball with a L shape at the thread I wouldn't have to drill it.
olhipster1 is offline   Reply With Quote
Old 12-13-2005, 03:50 PM   #3966
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey barger,
I sent you e-mail I hope the setup works for ya.
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 12-13-2005, 09:02 PM   #3967
YGM Thanks Mike
Barger is offline   Reply With Quote
Old 12-14-2005, 11:09 PM   #3968
new BD chassis for high grip
G2B Anthony is offline   Reply With Quote
Old 12-14-2005, 11:20 PM   #3969
JayBee's Avatar
Trader Rating: 31 (100%+)
Who makes this beauty?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 12-14-2005, 11:28 PM   #3970
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
I think Yokomo. If you look at thier PDF of this weeks product releases there is a new BD chassis out.
v0rtex is offline   Reply With Quote
Old 12-15-2005, 08:18 AM   #3971
Send a message via AIM to aoizip
anybody knows how thick this chassis is??
aoizip is offline   Reply With Quote
Old 12-15-2005, 08:43 AM   #3972
Hi,
since I bought my BD last week I had two amazing test days.
On the first evening I found a fast setup but it pushed too much.
So I tested different spring combinations and used different suspension blocks.
My setup ended here:
FRONT:
Front one-way
One-way centre pulley
No roll bar
Non-trailing steering blocks
4* castor blocks
1.5 camber
Skid mount angle:0*
0mm under both susp. mounts
Droop: 6
Wheelbase: 4-0
Rayspeed white springs
50wt oil
3 hole piston
No bumpstop
0mm under camber link
2nd from inner hole on tower
Middle hole on wishbone
REAR:
0* hubs
1.5 camber
2* toe in
0 mm under susp. mounts
Droop: 5mm
Wheelbase: 2-2
40wt oil
3 hole piston
No bumpstop
Std link locations on hubs
Outermost hole on tower
Outer hole on wishbone
Body: Mazda 6
Tires: Sorex 28
Inserts: JB blue-yellow-blue
Rims: Xray Hard rims
The car had tons of steering. And it was fast. I drove my fastest laptimes ever with this car.
I found that the white springs work better then the blue ones all around because the car rolls more and doesn't have that much body roll.
Cheers
Chris
speedy-932 is offline   Reply With Quote
Old 12-15-2005, 03:00 PM   #3973
is yokomousa the site you speak of, cause i can't find it.
Turtlemaster is offline   Reply With Quote
Old 12-15-2005, 05:23 PM   #3974
Yokomo Japan.
pops is offline   Reply With Quote
Old 12-15-2005, 05:31 PM   #3975
http://www.teamyokomo.com/japan/newp...2005_12_en.htm Web page of new releases.
http://www.teamyokomo.com/japan/news/index_en.html the PDF is linked from here.
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
