Old 12-11-2005, 04:13 AM   #3931
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default Barger
Thanks Barger,
Guess I won't try the spool, don't want to be chewing up gears.
I found the same with the steering, not enough so I played with the setup a little, changed my front toe out to 1 1/2 with a 1 degree camber (same camber in rear)
added a few grams of weights in the back to give her junk in the trunk
worked quite a bit better.
Currently trying to find the optimal spring combination for foam/carpet, any suggestions.
....what degree rear block are you running?
have you tried a 1 degree block rear....this will allow the car to transition a little better in the steering....or soften up the front springs by one....try the rear first see if that helps it out.
olhipster1 is offline   Reply With Quote
Old 12-11-2005, 06:21 AM   #3932
asw7576's Avatar
Originally Posted by Barger
WARNING!!!! I tried a spool/Locked center gear on tarmac with rubbers...It worked great BUT I chewed or bent
3x stock front shafts
2X hadened steel universals
The other guy at my club did about the same...We both went to diff front/locked center gear...that was a lot better...but I still have a problem of turning into the corner
Spool could last longer in dusty or low traction situation.
My friends got the same problem like yours and he actually gave up using it after losing the chance in podium finish.
Have you try front ball diff ?
Old 12-11-2005, 06:39 AM   #3933
What's the difference when moving the steeringblock up in the C hub?
How much ride height and droop should I use on "low traction" carpet using rubber tires. I pretty much have the stock setup right now... Any other things I might try.
JohnDoe is offline   Reply With Quote
Old 12-11-2005, 06:46 AM   #3934
To correct myself. Actyally what's the difference when moving the C-hub up and the steering block down. It might be not possible to use the steering block up when the c-hub is also up....? Now I got everyone confused, did'nt I
Old 12-11-2005, 09:45 AM   #3935
asw7576's Avatar
More aggressive : move front upper link forward or mount it to king pin
Less aggressive : move front upper link backward or mount it in one of the four holes located behind king pin.
Ditto with length of upper link.
Longer link : less aggressive, wide corners, sweepers.
Shorter link : more aggressive, lots of medium to tight cornering, chichanes
Old 12-11-2005, 10:56 AM   #3936
hi, guys.
I need help here with my new BD. I have problem with the ball diff. I didn't get the best setup for the rear ball diff (sometime to loose and sometime to tight). any tips? thanks
J-racing is offline   Reply With Quote
Old 12-11-2005, 07:54 PM   #3937
Olhipster1...thanks for your ideas...I am using 2degree rear toe Red springs front white rear std oil and I am using a ball diff in the front.
Barger is offline   Reply With Quote
Old 12-11-2005, 08:00 PM   #3938
JayBee's Avatar
Trader Rating: 31 (100%+)
Yokomo hasn't been in the mix too much lately (except for the 12L4Y) but since HPI w/the Cyclone (Hara & Surikarn Editions supposedly coming), X-Ray w/the T2 and Tamiya brewing up a few things... anyone 'heard' anything from the Yokomo camp?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 12-11-2005, 08:01 PM   #3939
ChadCapece's Avatar
Originally Posted by J-racing
hi, guys.
do a search on this thread for "diff balls"
Others and myself have posted some extensive info on this subject.
ChadCapece is offline   Reply With Quote
Old 12-11-2005, 08:02 PM   #3940
ChadCapece's Avatar
ahaha, those other companies are just trying to catch up w/ Masami and Yokomo!
Old 12-11-2005, 08:27 PM   #3941
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
With the quality and pure track speed of the BD and LCG, I sure hope yokomo aren't planning a new onroad car yet - i doubt they'll seriously do anything for another 12 months. At least thats what I hope anyway, I cant buy a new car too often
They do have a new 4wd off-roader due in the next month or so, that would be thier focus at the moment
v0rtex is offline   Reply With Quote
Old 12-11-2005, 08:42 PM   #3942
JayBee's Avatar
True, I forgot about that
Old 12-11-2005, 09:20 PM   #3943
Jochim_18's Avatar
By looking at the new Buggy, It looks like the BD with the motor moved to the middle of the chassis. Do you guys think this will be the next chassis for their next TC car? . Since TAMIYA have this configuration on the TA05.
Old 12-11-2005, 09:28 PM   #3944
Its got a 3+3 saddle pack too, I dont see them replacing a successful car like the BD with it.
Old 12-11-2005, 09:32 PM   #3945
Jochim_18's Avatar
OK guys I don't know what to get? I have a good deal on a SD world edition but I don't know if the 3800 will fit on the chassis, And I'm also thinking to just to get the LCG converion for my SD.
What car handles better?
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
