Old 11-29-2005, 01:45 PM   #3886
Droop measurement:
how do you set the droop? Is it measured with a standard gauge under chassis plate?
And the droop value shown in the setups is "above ride height" or it is total chassis lift before tyres leave the ground?
Thanks,
Eddi.
EddiRossi is offline   Reply With Quote
Old 11-29-2005, 02:52 PM   #3887
SpeedTech's Avatar
Originally Posted by ChadCapece
Any word on when these parts will be available?
The hollow center shaft is already available on our website
Team Bomber hop-ups others will be uploaded on our site as soon as they are released.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 11-29-2005, 05:36 PM   #3888
Steve, what are the little round pieces do next to the hollow center shaft?
pops is offline   Reply With Quote
Old 11-29-2005, 06:09 PM   #3889
John what was your setup for carpet wars on sunday? Did you run a 1 way?
Dan Hughes is offline   Reply With Quote
Old 11-30-2005, 11:36 AM   #3890
What is the effect of moving the steering arms back or forward on the the bellcrank plate?
Bertracing is offline   Reply With Quote
Old 11-30-2005, 12:16 PM   #3891
JayBee's Avatar
Trader Rating: 31 (100%+)
Doesn't this affect steering ackerman?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 11-30-2005, 12:16 PM   #3892
ChadCapece's Avatar
Basically, that's the Ackerman effect. It's when the inside wheel changes it's correlating angle compared to the outside wheel. Here's a quote off http://users.pandora.be/elvo/:
"A large Ackermann angle gives you smooth, predictable steering. You'll be able to round the corners nicely without all four tires trying to force the car in a different direction. A smaller Ackermann angle on the other hand can give you more aggressive steering, especially entering the corners. However, it isn't guaranteed that the front won't wash out now and then. Neither is a smooth cornering radius. It can be useful an high-traction tracks, if your car tends to oversteer in the middle of the corners, and you'd like a little more turn-in. Not to mention the psychological impact on the person driving right in front of you when you're entering corners."
ChadCapece is offline   Reply With Quote
Old 11-30-2005, 12:39 PM   #3893
asw7576's Avatar
So which position that gives large ackerman effect ? forwards or backwards ?
Old 11-30-2005, 12:41 PM   #3894
ChadCapece's Avatar
IDK, I've got the links full forward in the rack it steering is neutral. Just loosen up the locknuts and slide them back and forth. The more the inside wheel in angled, the more turn in you'll have.
Old 11-30-2005, 01:07 PM   #3895
Layman's answer, the further forward the ballstud the more aggresive turn in you should get. That's how it is for me.
HTH
Stu
CML | TiR | Microtech Racing | Tubz Designz
StuartC is offline   Reply With Quote
Old 12-02-2005, 04:10 AM   #3896
fastolfart's Avatar
Just a quick tip for those who might get the hollow titanium centre shaft, don't use it with a one way, the one way bearing will chew it up.
It is so hard to fix the driver, but so easy to blame the car.
fastolfart is offline   Reply With Quote
Old 12-03-2005, 04:04 PM   #3897
stinkypop's Avatar
Whats the difference between a LCG car kit and a SDW car kit? In regard to parts and geometry?
stinkypop is offline   Reply With Quote
Old 12-03-2005, 04:25 PM   #3898
ChadCapece's Avatar
LCG has a lower center of gravity than the SDW. I just handles better in general, but I believe the SDW is stiffer, so it should work better for foam on carpet.
Old 12-03-2005, 07:19 PM   #3899
Jochim_18's Avatar
The front end of my BD is sloppy, specially on the steering plate. I tried everything shimming it etc. It doesn't affect the performance just don't like it sloppy. Need help.
Old 12-03-2005, 08:13 PM   #3900
ChadCapece's Avatar
I use Duratrax teflon bearings in the rack. Then take a GS Racing shim (not sure on size) and put in between the flange lip and the rack. Under the bearing, I put 1 brass motor shim and a teflon motor shim. This raised the carbon fiber off the aluminium and gives smooth action. After that, put a tiny amount of thread lock on the steel screw and screw it in to the aluminium arm. Don't fully tighten down. The steering should be very smooth and slop free. Also, make sure you have the shims on the post to keep them from moving up and down under the upper deck.
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
