Old 11-16-2005, 02:04 PM   #3826
Losi.
Dan Hughes is offline   Reply With Quote
Old 11-16-2005, 02:15 PM   #3827
JayBee's Avatar
Trader Rating: 31 (100%+)
WHAT!!- You have got to be kiddin' me Any particulars why?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 11-17-2005, 01:00 AM   #3828
my guess is Yokomo USA product service. spare parts troubles. im sure most of us have been through it. hey, don't take my words as truth here. there could be more to matt's decision.
i've been thinking of switchin myself...HB Cyclone maybe? but that wouldn't be any better anyway...hahaha...unless HB starts an HB USA or something. XRay and RC America? but Im stuck on the BD simply because I dont have the funds to try to get another car, spare parts and all the hop ups, and of course that the BD is a damn good car for a hobbyist.
anyway. hey matt, good luck with the losi car. im sure you will do well.
phoebusb is offline   Reply With Quote
Old 11-17-2005, 07:42 AM   #3829
Scho's Avatar
Send a message via MSN to Scho
Right, Just got my BD yesterday, what shock lengths do i need to get proper ride height and droop...?
And where do you messure the shock length from?
cheers guys
Scho is offline   Reply With Quote
Old 11-17-2005, 08:44 AM   #3830
cheers guys
61.5mm to 62mm should do it. Measure from the top of the shock cap to the bottom of the shock end.
pops is offline   Reply With Quote
Old 11-17-2005, 09:23 AM   #3831
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
Al, at some of our lovely bumpy tracks here in the UK you should probably use the longer shock ends and set the shocks to 64mm lenght. This allows around 6mm of ride height. How come the change from xray? Car was going well last time I saw it (torc rd12 @ stafford), and especially as you nearly decapitated me with it , I was marshalling under the rostrum and you hit that random curb next to the pitline, car took flight, whoossh! Take cover!
Ali Graham is offline   Reply With Quote
Old 11-17-2005, 10:22 AM   #3832
I know why he left but im not sure if Matt wants everyone to know so im not saying. Its no real big reason, and it wasnt to do with parts support.
Old 11-18-2005, 02:32 AM   #3833
Scho's Avatar
Bahahaha, More random driving of mine at TORC? Really? Never?
Yeh, fancied a change got a bit bored of the Xray
Old 11-18-2005, 02:37 AM   #3834
Scho's Avatar
Well ive set them at 62mm now, I've cut the top hat's down in the shocks so i gain more length that way...
Old 11-18-2005, 05:50 AM   #3835
Scho's Avatar
Whats the highest ride height possible with 62mm shocks?
I can only just get 5mm on the front, thats without and droop screws set
Old 11-18-2005, 08:34 AM   #3836
Sleighty's Avatar
i will measure mine in abit scho
A1-RC.com
Team Scream
Xray
Sleighty is offline   Reply With Quote
Old 11-18-2005, 09:16 AM   #3837
ive told him how to fix it, but im curious to do if what ive said you people do aswell, as everyone that has a bd or sd that i have seen has different to the bd manual..... its the little spacer that goes inbetween the steering block and chub, the manual says put it below the block, but all that i have seen have the spacer above the block which lowers the wheel down over the wishbone making the car sit higher and be able to get your 5mm rideheight scho.
so do any of you run it as the manual says? or with the spacer above?
thanks
agower is offline   Reply With Quote
Old 11-18-2005, 10:31 AM   #3838
asw7576's Avatar
If you need more than 5mm ride height,
You could use SS Shock End.
You can use SSS Shock End but don't turn the piston shaft all the way down.
Old 11-18-2005, 12:29 PM   #3839
thanks
When we run the C block in the bottom hole I put the spacer above the steering hub. When we run the C block in the upper hole the spacer is run under the steering hub to get proper ride height. Never have any problem getting 5+mm of ride height anyway with 62mm shock length.
Old 11-18-2005, 01:33 PM   #3840
it was because of what i said, he told me
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
