Old 11-11-2005, 12:16 PM   #3781
Yes.
Dan Hughes is offline   Reply With Quote
Old 11-11-2005, 02:10 PM   #3782
I'm not pops, but he has helped me a time or two so I will save him the time here.
Yokomo
SD-010FH (front)
SD-010RH (rear)
TIR
TI2504 FW (front)
TI2504 RW (rear)
Thanks all the same !!!!
Xray T2 09 (still) - LRP - MuchMore - Futaba 3PK (still)
Bluey_74 is offline   Reply With Quote
Old 11-11-2005, 02:43 PM   #3783
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
Does anyone have a part number for the set of Precision Bearings for the BD? I cant find the part number anywhere...
v0rtex is offline   Reply With Quote
Old 11-11-2005, 02:55 PM   #3784
Found it, BD-BBP
Old 11-13-2005, 02:12 PM   #3785
Scho's Avatar
Send a message via MSN to Scho
Need some help...
I want to build a diff for my BD for the front, can somone please list all the parts that are needed to do so.
Scho is offline   Reply With Quote
Old 11-13-2005, 02:21 PM   #3786
ChadCapece's Avatar
BD-503-gear
SD-501-Yokomo MR-4TCSD Diff Joints and Drive Cups (Front/Rear)
ZS-507-Yokomo MR-4TC Diff Thrust Bearing Set
ZS-508-Yokomo MR-4TC Diff Adjusting Kit
ZS-506-Yokomo MR-4TC Diff Rings (2 ea.)
SD-501R-Yokomo MR-4TCSD Aluminum Diff Joint Rings
ZD-505T-Yokomo 3/32 Tungsten Carbide Diff Balls (12)
ChadCapece is offline   Reply With Quote
Old 11-13-2005, 02:21 PM   #3787
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
They are listed somewhere in this thread. They are all correct but I can't remember all the part numbers. Have a look in the back of the manual at the exploded diagram. Car was good today at carpet masters, I took 5th in stock and Andy Robson and Ian Whittingham took 1st and 2nd in spec
Ali Graham is offline   Reply With Quote
Old 11-13-2005, 02:26 PM   #3788
Ali Graham's Avatar
Beat me to it!
Old 11-13-2005, 02:27 PM   #3789
ChadCapece's Avatar
Originally Posted by Ali Graham
Beat me to it!
I just copied and pasted of Speedtechrc.com
Old 11-13-2005, 02:35 PM   #3790
you will need the actual bearing that goes into the gear and into the outdrives aswel
agower is offline   Reply With Quote
Old 11-13-2005, 03:31 PM   #3791
Could you post your setup please?
Cheers
Old 11-13-2005, 07:57 PM   #3792
JayBee's Avatar
Trader Rating: 31 (100%+)
Here's the ceramic ones...5x8mm
http://www.speedtechrc.com/store/ebp...nid=393&id=635
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 11-14-2005, 12:42 AM   #3793
Registered User
xrcbuggy's Avatar
Can some one please tell me if other brand of Spur Gear (48P w/76T) fit our car? Like Robinson Spur Grear, do they fit BD?
xrcbuggy is offline   Reply With Quote
Old 11-14-2005, 12:47 AM   #3794
Kimbrough "diff gear" spurs fit for me. I havn't tried Robinson
www.freerice.com
Help hungry people while learning.
smojoe is offline   Reply With Quote
Old 11-14-2005, 04:52 AM   #3795
highwayman's Avatar
most aftermarket spurs will fir the BD, the only difference is if the spurs have 6 holes like the kimbrough or 8 holes like the yokomo/xenon ones...
when using the 6 holes only 2 holes will align and you can only use 2 screws, but with the 8 holes, 4 holes will align with the spur gear adapter, therfore you can use 4 holes to screw in the spur. hope this helps...
highwayman is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
