Old 11-08-2005, 05:10 PM   #3766
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Francis M.
it's called japan nationals jmrca it droped of to the 2nd page of electric forum
once you click on its on the third page or you can find it direct on the
yokomousa web site.
Got it Thanks
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 11-08-2005, 06:52 PM   #3767
crabboy's Avatar
Trader Rating: 58 (98%+)
Originally Posted by fastolfart
BTW, the car was powered by a Trinity Green Machine 3, worked perfectly for the tight, technical track. Also had the grunt to pull harded through the flat out sweepers on the straight where the monsters were loading up.
yeah I have found that with the roar motors over monsters on tight tracks
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 11-08-2005, 07:56 PM   #3768
Shopkeeper's Avatar
Trader Rating: 35 (100%+)
Originally Posted by Bluey_74
Pops, what part number? or are they just the same as the SD?
Cheers
I'm not pops, but he has helped me a time or two so I will save him the time here.
Yokomo
SD-010FH (front)
SD-010RH (rear)
TIR
TI2504 FW (front)
TI2504 RW (rear)
Shopkeeper is offline   Reply With Quote
Old 11-08-2005, 08:56 PM   #3769
Piyo Piyo's Avatar
If I change the roll center by putting 1mm shims on every suspension mounts on the car (F & R) so the suspension are up for 1mm, what is the driving characteristics I got compared to susp mounts without 1mm shims?
Thanks in advance
VIOLA ARIELLE & FLOREN ISABELLE
Piyo Piyo is offline   Reply With Quote
Old 11-08-2005, 11:15 PM   #3770
Shopkeeper's Avatar
Thanks in advance
You would be raising the roll center, this would give the car less roll which results in less traction.
Old 11-10-2005, 09:52 AM   #3771
Mr. Shims's Avatar
I will post one later this week when I have time to unpack every thing.
The track was out doors on foam tyres
Thanks!
Mr. Shims is offline   Reply With Quote
Old 11-10-2005, 11:41 AM   #3772
Hollowman's Avatar
Send a message via MSN to Hollowman
Hi i don't have a yokomo bd but it's a nice but i especially like the battery bar & the gray 3700 battery inlay slots but where can i get some ?
thanks in advance.
greetings hollowman
Hollowman is offline   Reply With Quote
Old 11-10-2005, 11:43 AM   #3773
rc-zombies's Avatar
thanks in advance.
greetings hollowman
Speedtech should have them..
I was able to get some from Stormer Hobbies..
and retrofitting them for my Cyclone.
Old 11-10-2005, 12:52 PM   #3774
Hollowman's Avatar
24 Dollars shipping cost to Holland why is that so exspensive and those it fit on the cyclone with only drilling 2 holes ? and wil the battery tray fit on the cyclone slots.
edit : its not 24 dollars shipping
greetings hollowman
Old 11-10-2005, 12:53 PM   #3775
it might be cheaper from www.microtechracing.com in england....
agower is offline   Reply With Quote
Old 11-10-2005, 01:02 PM   #3776
rc-zombies's Avatar
greetings hollowman
Try HK or Japan shops..shipping is probably cheaper.
for the cyclone..you'll have to widen the batter slots. no drilling..
use CA or ShorGoo.
this is what I plan to do when I get my chassis back.
Old 11-11-2005, 07:00 AM   #3777
Scho's Avatar
Send a message via MSN to Scho
Ok, anyone know wher ei can get a fixed layshaft for the BD?
Scho is offline   Reply With Quote
Old 11-11-2005, 07:18 AM   #3778
Alex you need to get it from overseas. Try speedtech, champ rc.
Dan Hughes is offline   Reply With Quote
Old 11-11-2005, 07:41 AM   #3779
Scho's Avatar
Both out of stock
Old 11-11-2005, 12:07 PM   #3780
Scho's Avatar
Just to check is this the fixed pully/layshaft?
http://www.precisionrc.com/nv/car/pr...roduct_id=6153
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
