Old 10-31-2005, 01:11 PM   #3676
Originally Posted by tir
Fastrax spool does not fit both
Speedtach im pretty sure does not either
my mistake that from thesame batch of fastarx spools my mates had one in his bd and it worked fine, and i have mine in my yokomo sd lcg and it works fine must be my immagiantion that they dont fit in both
i have also seen the exact same with speedtech spool, again my imagination ?
dont get me wrong, the tir spools are grate, apart from they dont last long with any crashes, especially indoors!
but i do run tir worlds cvds and they are grate
agower is offline   Reply With Quote
Old 10-31-2005, 03:17 PM   #3677
rc-zombies's Avatar
anybody know the # of teeths the front and rear belts are?
lmk thanks.
Old 10-31-2005, 06:38 PM   #3678
TC_Tuner's Avatar
Trader Rating: 34 (100%+)
Default fragile steering rack plate?
Had my new BD on the track for the first time. ran very good outta the box (stock rubber).
I did have one problem. The carbon steering rack broke, quite easily. It cracked right where the ball stud for the steering linkage is attached.
I've already contacted Speedtech and Yokomo direct, neither have them instock.
Given how easily it broke, I'm not exactly excited to replace it with the same part. I do not know any other options here. Does anyone else?
Maybe it was a freak think. I'm interested to know if others have found this part to be fragile.
TC_Tuner
Airtronics | Byron's Fuel | Pro-Line | OS | Kyosho | Ballistic Batteries | RIP Al's Hobby Shop
MRX4-X F180 Cobra Zipper Kart Yokomo BD Cup Racer FM1e Recoil M18 Pro Scalpel dNaNo Baja 5T HB D8 Vorza ERevo Savage Flux SCX10 GT2 T4 Slash Ten SCTE Blitz ESE HB Cyclone D4 Mini ERevo Vendetta ST Mini T Micro T
TC_Tuner is offline   Reply With Quote
Old 10-31-2005, 06:54 PM   #3679
im having a problem with my BD the front belt is rubbing agenst the steering. any one know how to fix this?
TEAM GENESIS R/C, Roche P12 2017, Roche F-1, PAINT BY MIKEY
onroad dude is offline   Reply With Quote
Old 10-31-2005, 07:01 PM   #3680
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
lmk thanks.
Pretty sure they're 20 tooth and the center are 10, hence the 2.0 internal drive ratio
v0rtex is offline   Reply With Quote
Old 10-31-2005, 07:04 PM   #3681
ChadCapece's Avatar
huh? I think there are more than 20 teeth on the front or belt. The diff gears have 40teeth alone.
ChadCapece is offline   Reply With Quote
Old 10-31-2005, 07:07 PM   #3682
Oops, i thought he ment the size of the pulleys..
Old 10-31-2005, 07:20 PM   #3683
hi, there.
I want to change the 48 pitch spur gear to 64 pitch spur. can anyone give me suggetion, how many teeth I start from?
J-racing is offline   Reply With Quote
Old 10-31-2005, 07:32 PM   #3684
Regional Moderator
daniz24's Avatar
I believe the diff pulley is 40T and center pulley is 20T
daniz24 is offline   Reply With Quote
Old 10-31-2005, 07:42 PM   #3685
ChadCapece's Avatar
114 spur
Old 10-31-2005, 10:54 PM   #3686
beer_drinker's Avatar
TC_Tuner
You could try sealing the edges of the new part with CA when you get it. That may help to make it stronger.
beer_drinker is offline   Reply With Quote
Old 10-31-2005, 11:31 PM   #3687
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default just a thought
has anyone tried placing the aluminum steering plate from the Yok LCG..
i'm going to try in the next few days...
was thinking of putting the pivot ball for the servo ball cup in the closest bearing screw down..
the LCG's steering plate is and exact fit to the BD's steering bell cranks..
just have to figure out how to place the servo's ball cup into an accurate position as to not lose any servo throw leverage.
any ideas anyone?
olhipster1 is offline   Reply With Quote
Old 10-31-2005, 11:51 PM   #3688
JayBee's Avatar
Trader Rating: 31 (100%+)
As soon as you figure this out let us know
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 11-01-2005, 01:15 AM   #3689
Sleighty's Avatar
TC_Tuner
It may be more expensive but you could also buy two and put two on if you wish? I think that would work
A1-RC.com
Team Scream
Xray
Sleighty is offline   Reply With Quote
Old 11-01-2005, 02:27 AM   #3690
Sam_Smith's Avatar
Send a message via MSN to Sam_Smith
can someone please point me in the direction of a rayspeed spring rate chart please?
TIA
Sam_Smith is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
