Old 10-17-2005, 08:11 AM   #3571
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
For racing rubber tires on carpet the Chassi is just right.
Try the kit setup, should work pretty good.
Martin Hofer is offline   Reply With Quote
Old 10-17-2005, 05:11 PM   #3572
I ran mine on carpet using the kit setup, with a spool and was fairly good, some slight alterations here and there but nothing drastic.
I've got the rayspeed driveshafts on one of my cars and the Tir ones on the other and find the Tir ones better, for one you don't have to file the rib off the wheel hub, they fit the car better. And the rayspeed fronts I cannot use with the Tir spool as they're not long enough.
I have now ordered sum new wheel hubs to fit the second car with Tir ones.
Schumacher
Team Sorex
EA Motorsports
Speed Passion
East Coast Bodies
John Pape is offline   Reply With Quote
Old 10-17-2005, 09:11 PM   #3573
coons88's Avatar
Send a message via MSN to coons88
What tyres do you use for carpet? Rubber tyres that is, not foams.
Associated TC6.1 | Hobbywing V3 | LRP X12 | Spektrum | Futaba | Reedy
coons88 is offline   Reply With Quote
Old 10-17-2005, 11:29 PM   #3574
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by highwayman
just to clarify... when using the TC4 bones you have to shave off some material off the pins?
how about when using the stock rear yokomo bones?
Yes, but only on the sides that contact the slots, the stock Yokomo bones fit like a glove .
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 10-17-2005, 11:32 PM   #3575
JayBee's Avatar
Originally Posted by Matt Howard
If you're running foam tires on carpet you'll need to get a thicker chassis. The BD was optimized for outdoor racing so the chassis flex that you want there is something you absolutely don't want for carpet racing
So Matt, what a HIGH BITE asphalt track? I run on one; do you feel I can use the 3.0mm chassis and topdeck with some success?
Old 10-17-2005, 11:33 PM   #3576
Gonna run the CGM, I guess.
phoebusb is offline   Reply With Quote
Old 10-17-2005, 11:36 PM   #3577
JayBee's Avatar
Only if someone holds a gun to my head . My BD is working pretty good right now but I'm already committed with the thicker chassis
Old 10-18-2005, 01:47 AM   #3578
jaybee where do you get excel diff outdrives from?
agower is offline   Reply With Quote
Old 10-18-2005, 04:32 AM   #3579
I was running the CGM then went to the BD. Even with the stock chassis the BD was much faster than the CGM on carpet.
kmorast is offline   Reply With Quote
Old 10-18-2005, 04:36 AM   #3580
The person that cut my thick chassis said that a couple of guys ran the thick chassis at the Reedy race; as you know that was asphalt.
Old 10-18-2005, 04:58 AM   #3581
Matt Howard's Avatar
Yes
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-18-2005, 10:37 AM   #3582
SpeedTech's Avatar
Hi Guys,
Just want to post a quick note that MR-4TC BD parts are back in stock We also have new yokomo hardened universals for the SD (which will work on the BD as well) in stock
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 10-18-2005, 10:59 AM   #3583
Sorex 28s with GM Red Carpet Inserts or CS27s with JB Foam Thin Inserts(currently blue_yellow_blue)
Old 10-18-2005, 07:05 PM   #3584
highwayman's Avatar
What's the advantage of using universals?
highwayman is offline   Reply With Quote
Old 10-18-2005, 07:10 PM   #3585
JimmyMac's Avatar
Chad, were you still looking for RaySpeed CVD front axles? I have a new set of them here as spare. I think they cost me $14. Just the axles. No bones or pins or nothing...
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
