Old 10-12-2005, 11:15 AM   #3511
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by HELLOkitty
i am thinking of getting this car but i cannot find it,even speedtech does not have this car kit....kitty
Speedtech doesn't but Stormer Hobbies does for $409.99...
http://www.stormerhobbies.com/cgi-bi...e=&man=&page=2
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 10-12-2005, 12:09 PM   #3512
asw7576's Avatar
Originally Posted by JayBee
I don't know it all but this is a bit of info I have on it...
*ROLL CENTER/CAMBER LINKS*
Long Link- A long link gives a lot of body roll in turns. It feels as if the body is willing to keep on rolling, until in the end, the springs prevent it from rolling any further. The car has more grip in corners, especially the middle part. But if there already alot of traction, the long camber links can slow the car down in turns.
Short Link- A short link makes it so that the blody doesn't roll as far, it's tendency to roll drops off as it rolls. It feels as though the car generates a little less grip.
More Parallel Link (more parallel to the lower arm)- A parallel link gives a little more roll than an angled one. It feels very smooth and consistent as the body rolls in turns.
Angled Link (distance between arm and link is smaller on the inside)- An angled link makes it feel as if the car has a tendency to center itself (leveling, no roll), other than through the springs or anti-roll bar. It gives a little more initial grip, and steering into corners. It makes it very easy to 'throw' the car. The body rolls a little less than with parallel links. It's possible to use softer settings for damping spring rate than with parallel links, without destabilizing the car.
Beware that you should always keep an eye on the balance of your car; large differences in roll center front vs. rear will make the car feel less consistent and less confidence inspiring.
Longer Front- The front rolls and dives more in turns. Lots of steering in mid-corner. Could make the car hook.
Shorter Front- The front feels very stable. A little more turn-in, but has less steering in mid-corner.
Longer Rear- More rear traction in turns, and coming out of them. Rear end slide is very progressive, not unpredictable at all. Make sure that there's enough rear camber though, or you could lose rear traction in turns.
Shorter Rear- The rear feels very stable. It breaks out later and more suddenly, but if it does, the slide is more controllable. It makes the front dive in a little more, which results in more steering, especially when braking.
More Angled Front- Turn-in is very aggressive. The front feels as if it wants to roll less than the rear.
More Angled Rear- The rear end is rock-solid while turning in. It feels very confidence inspiring.
How's that for a little 101 HTH...
Thank you so much JB !!!
Here is my BD photos. Would you examine the upper link and tell me what kind of driving behavior I'll be getting with. My home track is asphalts, bumpy and little bit dusty ( medium to low traction I guess ) and quite technical circuit.
Yokomo MR4TC-BD-bd-047x.jpg   Yokomo MR4TC-BD-bd-048x.jpg   Yokomo MR4TC-BD-bd-045x.jpg   Yokomo MR4TC-BD-bd-049x.jpg
Old 10-12-2005, 03:49 PM   #3513
Buyer Beware
nice car...kitty
HELLOkitty is offline   Reply With Quote
Old 10-13-2005, 03:36 PM   #3514
Evening guys.
We're just starting our indoor season this side of the pond (who ever decided it was a pond? Love to see the size of their garden ) so I'm need of a little help on gearing for 19T. Going to be running Reedy QM or Peak Dysantry laydown, track is about the size of the Vegas track. What would be good starting ratio's for these 2 motors? I've only really run 19T outdoors on largish tracks so am a tad in the dark.
Cheers in advance dudes.
Stu
CML | TiR | Microtech Racing | Tubz Designz
StuartC is offline   Reply With Quote
Old 10-14-2005, 12:36 AM   #3515
billdapart's Avatar
Default yokomo bd ssg (old one)
I was wondering if one of you guys could helpme..
I recently picked up an older style ssg bd
I love this car and it handles REALLY well with all the lightening i 've done to the old bulkheads and such.. but i don't seem to be getting the gearing right.
Does anyone have a suggestion for gearing for this older bd? I'm going to be running stock on asphault.. medium to high bite
billdapart is offline   Reply With Quote
Old 10-14-2005, 03:13 AM   #3516
sosidge's Avatar
Well I've been running my SD with a Quad Mag at around 7.35:1 overall and this seems a good balance on most indoor tracks.
Old 10-14-2005, 09:15 AM   #3517
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
First of all, use only one!! upperdeck. It gives you much more grip and the handling well be better too. Usually a good startingpoint is: the more grip a track has, the harder a car has to be, so if you are racing outdoors on an, as you say med to low traction track, you should only use one upperdeck to allow the car to felx more.
to the upperlinks:
It should drive pretty simple. maybe a little understeer. Try to use the original "Kingpinballstud", as used in the kit setup. Handling is much better.
Martin Hofer is offline   Reply With Quote
Old 10-14-2005, 10:00 AM   #3518
Ahhh Mr Cann, greetings, I ran my peak dynasty on a ratio of 6.0 at Carpet thrashnal. Fair sized track, and seemed good, others ran there's slightly lower at 6.24.
Schumacher
Team Sorex
EA Motorsports
Speed Passion
East Coast Bodies
John Pape is offline   Reply With Quote
Old 10-14-2005, 10:37 AM   #3519
I am confused there is only one BD, sounds like you mean an SD SSG (shaft drive)? If you are using a Monster Stock, try somewhere between 7.8 and 8.5 to start.
pops is offline   Reply With Quote
Old 10-14-2005, 10:38 AM   #3520
He must mean the TC with the SSG conversion.
Dan Hughes is offline   Reply With Quote
Old 10-14-2005, 10:50 AM   #3521
tcdrvr's Avatar
Wasn't the Yokomo car before the SD a belt-drive? Maybe that's what he means by older style BD. I can't remember what it was called but it's the car that Hara won his world championship title with, just a guess.
tcdrvr is offline   Reply With Quote
Old 10-14-2005, 10:56 AM   #3522
MR4 TC Special 2
Old 10-14-2005, 11:09 AM   #3523
original MR4-TC. I'm having trouble gearing it too. Biggest spur I think fits is 72 tooth (48 pitch) but the motor mount doesn't allow the motor to get close enough to use the pinion I would like to use (24 tooth). the smallest pinion I can fit while still keeping a decent gear mesh is 28 tooth.
www.freerice.com
Help hungry people while learning.
smojoe is offline   Reply With Quote
Old 10-14-2005, 11:14 AM   #3524
I have two of the MR4TC cars and they both came with 78T spurs. I currently have a 81T on one of them. Try a bigger spur
DOTMAN is offline   Reply With Quote
Old 10-14-2005, 11:30 AM   #3525
billdapart's Avatar
Default yes and no
No, I'm not talking about an SD
I'm not sure if it was the same car that Hara won with, but it IS based off the originial mr4-tc (i have one of those and almost all the parts are a direct fit.
I'll try and take some pics for you guys tonight.
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
