Old 10-09-2005, 09:03 AM   #3481
kylehirano's Avatar
Trader Rating: 14 (100%+)
Just bought a BD, and am looking to race stock rubber on oxzite carpet, I have a set of Rayspeed springs and am wondering what a good staring point is. I usually run mod, but Ive been out of racing for over a year and want to ease back into it. Anyway if anybody can give me advice on what springs will work, I would appreciate it Thank you
kylehirano is offline   Reply With Quote
Old 10-09-2005, 12:46 PM   #3482
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by pops
You suck STLNST
I can get my parts orders though....LOL
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 10-09-2005, 03:41 PM   #3483
God knows you need them..
pops is offline   Reply With Quote
Old 10-09-2005, 03:44 PM   #3484
Rayspeed Yellow, Red and Blue.
Old 10-09-2005, 03:58 PM   #3485
Default BD shock lengths vs droop?
I've just completed building a second BD. Does anyone else have a problem with the shock lengths?
Here in the UK we race outdoor tarmac. The tracks are mostly mid to low grip so we tend to run droop at 3 to 4. To achieve this you need a shock length around 64mm.
If you use the short shock ends then the have to be fitted with around half of the thread not screwed in - vulnerable to breakage in a collision.
If I fit the long shock ends then I can't get the ride height below around 7mm.
I read on this thread about cutting off the prtrusion on the internal plastic shock shaft guide and I find that even with this cut off completely I can only just get 64mm length and the guide doesn't seem very secure.
Don't get me wrong its a great car and the first one TQs and wins nearly everywhere in 19T.
I'm just bothered about the potential for a failure.
regards
Don
donwhit is offline   Reply With Quote
Old 10-09-2005, 07:10 PM   #3486
Local racer's Avatar
Default website
Does anyone have a number or web adress for the guy that makes the carpet chassies for the bd
http://www.tqracing.net
Local racer is offline   Reply With Quote
Old 10-09-2005, 07:50 PM   #3487
Can't wait till it arrives.
It will be soon!
Fantom, BL Racing, Retired
jimnew is offline   Reply With Quote
Old 10-09-2005, 07:58 PM   #3488
Regional Moderator
daniz24's Avatar
You can try to look for Yokomo SS shock body, because it's longer than the kit standard...
daniz24 is offline   Reply With Quote
Old 10-09-2005, 08:57 PM   #3489
Piyo Piyo's Avatar
Originally Posted by RED-LINE M03
BD-118T Battery Tray. Is this the Yok part # for the white rubber looking things that the batteries are laying on the YOK BD.
Do you think they would fit on a FT TC4?
Regards,
E
Mostly the battery tray will fit on any cars. You need to grind/sand your chassis carefully so it fit perfectly with the trays. I did it once on my SDW, pheewww it takes 2 more hours for that.
VIOLA ARIELLE & FLOREN ISABELLE
Piyo Piyo is offline   Reply With Quote
Old 10-10-2005, 12:48 AM   #3490
asw7576's Avatar
regards
Don
I don't use the collar triangle ( black plastic that you place inside in the shock to guide the piston shaft ). I don't know why uncle masami use that triangle, for what ??
I can set the ride height freely now by setting up the downstop screws and shock collars.
btw, why yokomo shocks makes squirt sound at Top Dead Center?
Old 10-10-2005, 04:35 AM   #3491
Registered User
xrcbuggy's Avatar
Yesterday, 05:58 PM BD shock lengths vs droop? Report | Post #3485
What I did was made new holes above the original holes, you need a drill press for a perfect job & make sure both sides are equal distance from a reference point ( make jig for it). This only works for rear tower.
xrcbuggy is offline   Reply With Quote
Old 10-10-2005, 08:00 AM   #3492
regards
Don
most the people i know run about 5 and 4 droop and the bd, with the yoke gauge. they have there shocks set at 62mm and can get easily 5.5mm rideheight.
agower is offline   Reply With Quote
Old 10-10-2005, 08:02 AM   #3493
becuase it supports the piston shaft inside, without there is abit of play in it and your shocks can leak easier.
i no people that also sometimes cut it down abit but never run without it!
Old 10-10-2005, 08:18 AM   #3494
Regional Moderator
daniz24's Avatar
I think you already answer your own question. To guide the piston shaft.
Sure, don't use them if you don't mind to refill the shock after every 3-4 runs
It's the air bubble sound. You're not filling the shock in a correct way.
Old 10-10-2005, 04:06 PM   #3495
Default Carpet Chassis
Hi, A friend mentioned to me yesterday that there was someone on this thread who made a stiff chassis and upper plate for the BD. I'm going to my first carpet race next week and wanted to see if I could get a one. If anyone can point me in the right direction, I would appreciate it.
DOTMAN is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
