Old 09-09-2005, 08:35 AM   #3331
tir
Originally Posted by Chrissy C
You have certainly designed it well. I have one and it is 8 grams lighter than my previous spool, the only issue is the snapping of the drive cups. Will you be bringing the ally cups out? and do these use blades?
Chris
The HD spool for the BD and 415 are available in 2 options:
1 Pro competition come with Delrin cups on the pro version which also incorporate our spool sleeves.
2. Competition spool come with ally cups as standard
both are interchageable.
Essentially outside we use Delrin with sleeves for indoor we use Ally.
With respect to blades - they give understeer. Adam rogers and I tested them on the 415ms back to back and the maniax one with the blades gave terrible understeer. The blade although a great idea by cecil schumacher, cause too much drag entering and exiting corners which upsets the handling. Years ago when there was poor grip and less torque they were a great idea. Now I think they have come to the end of their life.
Unfortunately steel pins are the most efficient way of transmitting power.
TIR
P.s Cups are available:
Tel 0044 1603411981
tir is offline   Reply With Quote
Old 09-09-2005, 08:38 AM   #3332
tir
Originally Posted by ukmaxx
TIR - any idea when your website will be up and running so we can purchase from u?
Hi
The website is having its links finallised as we speak. Should be fully functional next wednesday.
In the meantime you can order on 01603411981.
Regards
TIR
Old 09-10-2005, 12:11 AM   #3333
Scooby Horton's Avatar
Does anyone know who makes a 3mm chassis for the BD?
Scooby Horton is offline   Reply With Quote
Old 09-10-2005, 05:08 AM   #3334
Matt Howard's Avatar
yes, but I'm not telling you
PM jimnew on this board and might be able to hook you up
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 09-10-2005, 06:35 AM   #3335
pheyhoe's Avatar
R/C Tech Charter Subscriber
Ok, so im running on carpet in Modified with the BD this weekend.
Im running TRC 26mm blue (40 shore?) foams. Im just looking at the gap between the wheel and the steering hub and its only about 0.75mm. Should i run a thin spacer on the front wheels?
Also, i have Rayspeed yellow on the front and blues on the back. Does that sound too soft? medium/low grip carpet. Running a spool.
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 09-10-2005, 06:50 AM   #3336
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
Shouldnt need space it to with 26mm foams, but if you swap to 28mm foams you might need to try and find some Suzuki Alu knuckles because these have a little more room.
Yeah a bit too soft imho.. I've run Rayspeed reds on the front and Yokomo green's on the back on carpet in 27t Stock, car was around 2 or 3 tenths off the pace per lap. I wouldnt mind going up to Rayspeed greys on the front next time perhaps, havent yet because my LHS has been out of stock
Was running Ellegi 40's on the front and 35's on the rear, ball diff in the front and locked center pulley.
v0rtex is offline   Reply With Quote
Old 09-10-2005, 07:05 AM   #3337
pheyhoe's Avatar
I have all the rayspeed springs, do you think Red on the front and blue on the back. Its not ozite, its kind of a laid material stuff. but its still grippy. but compared to some high grip carpet tracks i would say the grip is medium/low.
I think grey would be too hard?
Old 09-10-2005, 07:13 AM   #3338
In that case, grey could be too hard for you.. Still, i'd start on the side of hard and adjust softer if needed, but thats just me
Old 09-10-2005, 09:02 AM   #3339
Shopkeeper's Avatar
Trader Rating: 35 (100%+)
Default springs
Speaking of springs, I know I read this somewhere but I can't find it now. Is there a diffrence in the inside diameter of the Yokomo vs Rayspeed springs? If so, which one is which? I have some springs that came with my car and I am trying to figure out what the rates are. They fit nicely on the lower spring retainers but are very sloppy on the upper retainer/adjuster. Also, I have read some of the rate charts that are posted here and the one that comes off the Bd site or manuel and they seem to be different. Anybody know which one is right?
Shopkeeper is offline   Reply With Quote
Old 09-10-2005, 09:06 AM   #3340
pheyhoe's Avatar
If they are loose at the top they are Rayspeed springs.
Old 09-10-2005, 09:20 AM   #3341
The Rayspeed springs are longer than Yokomo springs 25.5mm vs 23mm.
ID Rayspeed are 14.5mm Yokomo are 13.5mm
Yokomo softest to hardest
Black
White
Blue
Yellow
Pink
Green
Stainless
Orange
Yokomo GT
Red
Yellow
Green
Silver
Gray
Brown
Rayspeed
Green
Blue
Yellow
White
Red
Gray
pops is offline   Reply With Quote
Old 09-10-2005, 09:27 AM   #3342
Shopkeeper's Avatar
Wow, fast repy, Thanks.
I just went back and it seems that there might be confusion on the yokomo springs, but the rayspeeds seem all the same. I guess it won't matter as I have the rayspeeds.
Is there a trick to getting them to fit better, or is everyone just running them loose on the top?
Thanks again.
Old 09-10-2005, 09:34 AM   #3343
Shopkeeper's Avatar
Wow, you guys are on it!!
Thanks pops, Hey you race at parking lot races right? how far off of the kit set up are you if any?
Old 09-10-2005, 10:18 AM   #3344
Race mostly on permanent tracks. Kind of close
Front
Spool
Silver swaybar
1.5 deg camber
instead of 1mm shims under the suspension mounts using .5mm shims
front droop 10
4mm spacer in front of arms
upper hole in caster block
Rayspeed white springs
450 oil #3 piston shock length 61.5mm
shock mounted in middle hole of the Arm and 3rd hold from the outside on the tower.
Rear
Locked center drive gear
Black upper swaybar
1 degree reversed rear hubs
1 deg of rear camber
3 deg of rear toe with 1deg hubs reversed = 2 deg of total rear toe
rear droop 4mm
4mm spacer in front of rear arms
400 shock oil #3 pistons
camber link on 3rd hold from outside rear hub
Shock mounted in 2nd hold from outside on the shock tower and outside hole on the arm.
This works very well on a high traction high bite track, car still pushed a little too much last time out.
Old 09-10-2005, 12:54 PM   #3345
JayBee's Avatar
Trader Rating: 31 (100%+)
pops-
1-degree 'reversed' hear hubs? What's this?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
