Old 08-27-2005, 03:55 PM   #3271
Originally Posted by agower
no you dont, im using mine fine.
I guess you could use a thinner spacer under the top kingpin, but I don't want have anything rubbing against the top kingpin, which could loosen up the kingpin with steering action. There is little or no play in the top kingpins anyway.
pops is offline   Reply With Quote
Old 08-27-2005, 05:46 PM   #3272
me too.
Turtlemaster is offline   Reply With Quote
Old 08-27-2005, 06:34 PM   #3273
coons88's Avatar
Send a message via MSN to coons88
Originally Posted by Turtlemaster
me too.
Me three
Associated TC6.1 | Hobbywing V3 | LRP X12 | Spektrum | Futaba | Reedy
coons88 is offline   Reply With Quote
Old 08-29-2005, 01:03 AM   #3274
TENCHO's Avatar
Default i got jipped
JDM_SIR jipped me out of a whole bag full of blue aluminum 415MS parts. He told me that he could them annodized a different color, so i belived him. I gave him the parts 5 months ago, and haven't heard from him since. Geez, just when you think someone is your friend,....DAVE I WANT MY PARTS BACK!
TENCHO is offline   Reply With Quote
Old 08-29-2005, 03:52 AM   #3275
highwayman's Avatar
ran the BD last saturday... man, this car is just plain stable, consistent through out the race !
highwayman is offline   Reply With Quote
Old 08-30-2005, 03:31 PM   #3276
Phil C's Avatar
Yer it is a great car, mine was so smooth to drive at West London Ko gp. There were alot of Bd's in all 3 classes that were very quick.
Rob miller set Tq and a new track record in stock, i got 5th with mine.
In 19t Stuart Cann did very well wining 1 of the finals from 3rd on the grid and came 3rd in another to get 3rd overall.
In mod Chris grainger was very much on the pace, but was very unlucky in the 3rd final, looked like someone turned a transmitter on costing him 3rd place.
I gotta say im very please with mine, had a few problems at 1st with hubs stripping and snapping pins in the front driveshafts, but ive overcome these by using suzuki alloy front hubs and TIR worlds driveshafts. Other than that its been awesome, not broke a single thing and ive gotta admitt ive had sum pretty spectacular crashes
| Team XRAY UK | HUDY | RC DisCo| LRP | Sanwa | SMD | Moorespeed | MB Models | Gingapaint | McLaren Racing |
Phil C is offline   Reply With Quote
Old 08-30-2005, 03:58 PM   #3277
pheyhoe's Avatar
R/C Tech Charter Subscriber
Erm, about the kingpins. When you buy the TI king pins it says to put one at the very bottom outside the hub carrier and one at the top inside the carrier. If you install them like this but run the normal ballstud/kingpin the steering binds...
How are you guys running them?
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 08-30-2005, 04:13 PM   #3278
Phil, slight correction (and trumpet blowing), I actually finished 2nd at the KO
Paul, to be honest I think you only need to run the Ti kingpins on the bottom, just use the standard kingpin and washer on the top. I've only ever run with the inline kingpin on the front so have never experienced your problem, it's only ever the bottom kingpin that causes problems though so the standard 1 in the top should help your problem.
//Stu
CML | TiR | Microtech Racing | Tubz Designz
StuartC is offline   Reply With Quote
Old 08-30-2005, 04:19 PM   #3279
Phil C's Avatar
//Stu
Opps, even better
Old 08-30-2005, 04:23 PM   #3280
pheyhoe's Avatar
//Stu
I tried running the standard ball/kingpin on the top but when i tightend it up the steering went stiff. should i follow the spacing instructions off the BD manual or the TI instructions?
I would try now but ive just finished a full rebuild and my hands hurt
Also, whats the part number for the spacers on the center pulley shaft? (fixed, if it makes any difference)
Old 08-30-2005, 04:30 PM   #3281
Right, think I've got ya now. To run the kingpin/ballstud you have to have the washer under the steering arm, not hanging out the bottom of the caster block. You then run the caster block in the lower position on the wishbone.
It is possible to have it the other way round but it requires some dremelling or funny spacing. Word is Yokomo should be bringing out a longer ballstud/kingpin to give you both options.
Can't help you on the pulley I'm afraid, don't even have 1 myself yet.
//Stu
Old 08-30-2005, 04:33 PM   #3282
pheyhoe's Avatar
Thanks!
For now i will just run both TI kingpins and run a standard ballstud in the holes used by the SD.
I hate shims, i always loose them. The pulley assembly is so loose that when i acclerate hard the pulley slides to one side and makes a not very nice noise. i can run it but it sounds like my SD :P
Old 08-30-2005, 05:02 PM   #3283
Phil C's Avatar
Ah yer had forgotten about that, ive got the proper locked centre pulley and i need some shims too, anyone got any ideas on the part number for the thick plastic shims used in the layshaft assembly?
Cheers Phil.
Old 08-30-2005, 08:39 PM   #3284
Trader Rating: 18 (100%+)
Does anyone know where to get the Suzuki aluminum front hubs? I am having a hard time finding them in the states.
Chris Brown is offline   Reply With Quote
Old 08-30-2005, 08:42 PM   #3285
I meant steering knuckles, sorry.
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
