Old 08-19-2005, 11:17 AM   #3211
Originally Posted by pheyhoe
JDM_DOHC_SiR
What do you run on the front then??? I am having loads of problems with the pins becoming loose or snapping so i was thinking of getting the TIR worlds ones all round.
When do you think the prototype ones will hit production pops?
I believe they are now the same as the Worlds, I haven't found anything better. The fit was not good on the prototype, had to remove coating above the threads for the hexs to fit, but other than that, they are great. Also need to check before each race day that the pin doesnt come loose in the CVD. Lock-tite and really tightening the set screw down, doesn't seem to stop that little pin from moving a little each race day. But, they are super strong. There is also an extra hole in the bell in case of wear, but after more than 7 months of racing no wear at all, have only one broken axle (major crash), and one slightly bend bone (hardly noticeable). Sheared the rear arm off twice bending the hinge pin into an L once, but the CVDs are still like new.
pops is offline   Reply With Quote
Old 08-19-2005, 11:30 AM   #3212
rocketron's Avatar
Trader Rating: 16 (100%+)
i have not had a pin problem for the last several race days now... get yourself either a #53 drill blank or drill and make your own pins from this they fit slightly better than the stock pins and do not break. the drill is easy to find at nearly any hardware store and you can get 2 pins out of the shank.
good luck
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 08-19-2005, 01:08 PM   #3213
JDM_DOHC_SiR
They've recently been updated as well and are even stronger. I've got a set of the latest shafts in my BD, took a big hit at the Bedrock national on Sunday and bent a Fastrax spool (For those not in the know the Fastrax spool is made out of nice, driveshaft snapping, steel)
Actually put a TiR spool in and it gave the car a bit more steering, 2nd leg of the A I had the 2nd fastest car on the track.
//Stu
CML | TiR | Microtech Racing | Tubz Designz
StuartC is offline   Reply With Quote
Old 08-19-2005, 02:13 PM   #3214
Sleighty's Avatar
//Stu
Stu, where do you get all your TiR parts from in the UK? I cant find anywhere that stocks TiR parts for the BD? I didnt even know that they did a spool for the BD.
Some part numbers and places to get these items would be appreciated
A1-RC.com
Team Scream
Xray
Sleighty is offline   Reply With Quote
Old 08-19-2005, 03:33 PM   #3215
Sleighty, I get my stuff direct from TiR, I believe you can order direct from TiR, www.titaniumracing.com. The spool is the same for the BD and the SD.
Spool: TNM3530
TI2504FW - TiR Worlds Edition Yokomo SD Blue Front Driveshafts pr
TI2504RW - TiR Worlds Edition Yokomo SD Blue Rear Driveshafts pr
(Blatant cut and paste for the driveshaft part numbers, cheers other Stew )
Stu
Old 08-19-2005, 04:33 PM   #3216
TOEBSTER2's Avatar
Are any of you guys running the BD with foam tires on carpet? I've been running mine for about a month this way. It's pretty good , just looking to compare to anyone elses set up. Is there any Aluminum diff out drives available?
Crookid Creations
TOEBSTER2 is offline   Reply With Quote
Old 08-20-2005, 02:18 AM   #3217
johnbull's Avatar
I have run the TIR Worlds drive shafts on both my BD and son's TC4s and can highly recommend them.
I run an RW Racing spool on the BD and have just ditched the alloy IRS spool on the TC4s and replaced them with the works lightened steel versions.
Never had any drive problems with either car.
johnbull is offline   Reply With Quote
Old 08-20-2005, 02:53 AM   #3218
coons88's Avatar
Send a message via MSN to coons88
Yes I have, whats your setup like?
Associated TC6.1 | Hobbywing V3 | LRP X12 | Spektrum | Futaba | Reedy
coons88 is offline   Reply With Quote
Old 08-20-2005, 06:58 AM   #3219
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
Just wanted to say that my centre one way locked itself last night (?) as someone else mentioned earlier, oh well, at least it saves me paying a bomb to ship one over...
Ali Graham is offline   Reply With Quote
Old 08-20-2005, 07:45 AM   #3220
tony montana's Avatar
Trader Rating: 66 (100%+)
I have a few questions about the BD. Im new to touring but looking to get one for the indoor season. I think the BD looks awesome, How does it fair against the xray's and other comp. One more thing that concearns me is yokomo seems to come out with a new car every 6 months, I dont want to buy the BD and a month later something else comes out. Where is the cheapest place online to buy one, and get spares
K.C. Guy- TLR- Horrizon Hobby- Team Trinity- 92 zero designs- AKA
tony montana is offline   Reply With Quote
Old 08-20-2005, 09:33 AM   #3221
JayBee's Avatar
Trader Rating: 31 (100%+)
Try out Speedtechrc.com or Stormerhobbies.com and I think RC Champ -JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 08-20-2005, 05:07 PM   #3222
coons88's Avatar
I would not say that, after Yokomo released the SSG nothing was released for over a year untill the CGM which was basicly the same car. It is only recently that Yokomo have released a couple new cars to update there range.
And I would 100% recomend the BD, awsome car, no problems so far, no breakages, really easy to drive and really easy to setup.
Old 08-20-2005, 06:38 PM   #3223
Ditto!
Old 08-20-2005, 07:48 PM   #3224
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by pops
Ditto!
TOASTY!!!!!!
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 08-20-2005, 08:39 PM   #3225
Originally Posted by STLNLST
TOASTY!!!!!!
Too bad you weren't at Speedworld today, Mr. Nineteen Turn.
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
