Old 08-15-2005, 10:48 AM   #3181
Kyew's Avatar
hmmmm...tricky. it's a bit hard to want both turn-in and steering at the same time. usually i will use a higher roll center to initiate the turn-in and compensate for the reduction in mid corner steering with a softer spring or laydown the shock more. sorry i can't be of help.
Kyew is offline   Reply With Quote
Old 08-15-2005, 10:52 AM   #3182
Originally Posted by Martin Hofer
i was testing the BD now quite for a while, but I always have too less turn in steering, no matter what I change on the Setup.
What shall I do? I have ordered the inline steering knuckles, but I'm not sure if this will cure (I hope this word is right :-) ) my problem.
Here is my actual Setup. The track is a pretty tight 220m long track with not that much grip. Motors are 27T and 12T but I don't have enough steering with both.
Martin, you have done everything you could, so sell the car. NOT, just kidding! It looks like you have tried just about everything, but the one thing that really stands out, is the position of your front shocks. Having them standing so upright stiffens the suspension and will take away inital turn-in. Lay the front shocks in, this will soften the front and allow the car more intial steering. This car loves sway-bars, they will keep the car more level and faster, try a silver in the front and a black sway-bar in the rear, your car will be faster, once you get use to it.
pops is offline   Reply With Quote
Old 08-15-2005, 07:23 PM   #3183
using the stock setup for the rear hinge pin mounts, add one more spacer to the front pin mounts, this will give anti squat and raise rear roll center
on the front try leaving the hub spacers where they are and move to the upper hole. you can also try moving the ball stud on the hub to the inner most hole, and remove the spacers from the front block. and lean the shocks in one hole on the front like pops said.
Turtlemaster is offline   Reply With Quote
Old 08-16-2005, 05:48 AM   #3184
highwayman's Avatar
Martin Hoffer : have you tried running the front c-hubs on the lower hole, that helped me a lot. also try running a fixed center pulley in combination with your 1way.
highwayman is offline   Reply With Quote
Old 08-16-2005, 05:55 AM   #3185
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
i run the c-hubs in the lower hole! and my center oneway broke, so it's a locked one now :-) I'm a bit disappointed, that it lasted only for a month now, but I can't change it.
Btw. running an centre oneway gives a bit more steering.
Martin Hofer is offline   Reply With Quote
Old 08-16-2005, 06:13 AM   #3186
Well I've taken the plunge and picked up my Yok BD.
Couple of queries....
1) Anyone got an handy build tips?
2) What "essentials" do I need? Sp far I have some extra Rayspeed springs with the collars and the sway bars. Anything else needed?
Cheers
Andy
Andy M is offline   Reply With Quote
Old 08-16-2005, 06:16 AM   #3187
johnbull's Avatar
Welcome to a great car thread Andy.
I have just answered your PM in racechat.
Forgot to tell you - 40 oil and AE silver springs all round.
johnbull is offline   Reply With Quote
Old 08-16-2005, 07:12 AM   #3188
Lol cheers Joe, got your reply thanks
RE: Springs...
I currently have the kit springs (Yok Blue and Yellow??) and a full set of rayspeed reds and whites. I had intended to get more of the Rayspeeds in however...
I also have a full AE spring kit, are these useful on the BD? Do they use the std shock collars ok?
Cheers
Andy
Old 08-16-2005, 07:33 AM   #3189
s2
s2's Avatar
Andy-
The black greese which comes with the kit isnt really very great for use on the driveshaft assembely, it just doesnt seem to 'stick' and'll fly off as soon as you drive. try Much*More Joint Greese or Tamiya Anti-Wear Greese, these 'stick' better, think the Much*More stuff is easyer to get in the UK
if you can, replace the standard driveshafts, the Yokomo ones have caused me no end of trouble, with the pins snapping, or becoming loose. ive been using the TiR Worlds CVD Driveshafts since last week and they are much better, they have 0 bind at full bend, and the parts fit is much better, which should hopefully mean no snapped/loose pins.
later
s2 is offline   Reply With Quote
Old 08-16-2005, 09:44 AM   #3190
JayBee's Avatar
Trader Rating: 31 (100%+)
Yeah the Tamiya Anti-wear grease is awesome stuff. It's actually so sticky that you go EWWW what's in this I'm having problems with the hardened universals binding up at full lock. I don't have my car in front of me right now but I'll take a look later to see how I can stop it. Where are folks getting the TiR ones? -JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 08-16-2005, 10:25 AM   #3191
s2
s2's Avatar
in the UK the TiR driveshafts are widely available, im affraid i dont know about the states.
1 thing i forgot to mention, the TiR driveshafts dont fit in the Yokomo 1way
Stew
Old 08-16-2005, 11:24 AM   #3192
Stew
You should be able to get them from the Schumacher USA web site, either now are in the near future. They are the US importer. You can use the oneway outdrives from the SD, they have a larger inner diameter and will fit the TIRs. The BD outdrive's inner diameter is too small.
Old 08-16-2005, 12:44 PM   #3193
What's the order number? Unfortunately there are now images...
I think it should be:
TR2504T TiR C.V.D. MR4-SSG - MR4-SSG
Is it for the complete car? Or just a pair?
And where's the difference to this two?
TNM2504FS Steel C.V.D. MR4-SSG frt - MR4-SSG
TNM2504RS Steel C.V.D. MR4-SSG rear - MR4-SSG Rear
Cheers
Chris
speedy-932 is offline   Reply With Quote
Old 08-16-2005, 12:48 PM   #3194
Cheers
Chris
I don't know the part number.
The difference is the rear hub axles are longer than the front axles.
Old 08-16-2005, 12:48 PM   #3195
die einen sind für vorne und die anderen für hinten (rear) so wies aussieht ist das immer nur einer, weil in der einzahl geschrieben wird
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
