Old 08-12-2005, 02:25 PM   #3166
JayBee's Avatar
Trader Rating: 31 (100%+)
Any one of those tire compounds may work; I lean towards the Sorex 36's though. If your rear-end is still wash'n out a bit, try a tad more rear droop. -JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 08-12-2005, 03:09 PM   #3167
Originally Posted by tcdrvr
I got my BD used about one month ago and have raced it three times since then. The first run wasn't that impressive, the back end slid out at almost every turn. After that I switched to Matt Howards 23-Turn setup less the rear swaybar and the car was nearly perfect with the exception of two things in certain turns the car had a slight push and in others the back would get a little loose. Does anyone have any suggestions on where to go from here to resolve these issues? I suspect the push is almost all caused by the spool but the rear traction issue is a big concern. As far as tires, I was using CS-27's.
Matts set up was for a one-way, try changing your shock positions on the tower. Position both front and rear shock in the second hole from the outside on the tower. If the car pushes too much add a light rear sway-bar, sometimes it takes away a push, sometimes it will give you more traction?
pops is offline   Reply With Quote
Old 08-12-2005, 07:11 PM   #3168
BritRacer's Avatar
who sells thicker chassis for carpet? i have searched the web to no luck
BritRacer is offline   Reply With Quote
Old 08-12-2005, 09:17 PM   #3169
Originally Posted by dynoman007
in the US where do you guys buy parts for the BD ..
speedtech has some who else ?????
Horizon has BD specific parts listed, but not in stock at the moment
www.freerice.com
Help hungry people while learning.
smojoe is offline   Reply With Quote
Old 08-13-2005, 02:56 PM   #3170
Anyone know? Any ideas where they are available? Carpet season is coming soon....
Old 08-13-2005, 03:27 PM   #3171
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
I know I don;t have a BD anymore but EA Motorsports and BMI together have one coming from the last I heard.
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 08-15-2005, 06:57 AM   #3172
This is just a thought but as the BD has the holes drilled out for the split type suspension mounts, could the ones from the SDW be put on the car so that you can run short arms on the front?
Dan Hughes is offline   Reply With Quote
Old 08-15-2005, 07:09 AM   #3173
just a little info post,, it is said the the shaft drive cars are better for stock and belt drive cars are better for mod. this past weekend i ran stock with my SDW and my BD back to back with the same tires, and i mean same tires, i didn't use the same setup on both cars as they like different things, and i used the same body. with the BD i was able to carry more corner speed, hold my lines more consistantly, and drive deeper into the corners. with all that said, let me also say, this was on a very large nicely flowing pavement track. shorter track, tighter turns maybe the sdw will shine again as it as in the past.
anyway, just thought i would post that in case anyones been holding off on trying the bd in stock,
i also did some testing with spur gear sizes. ran a few laps with a 114/38 64 pitch gear set, thats a 6.0 gear ratio. then ran a 72/24 48 pitch gear set which is also a 6.0 gear ratio. the car reacted better and was quicker with the 72/24 combo. i think i read this early in this thread from johnbull about using a 116 in mod and 100 in stock, imo it seems for stock the small spur does work better.
Turtlemaster is offline   Reply With Quote
Old 08-15-2005, 07:56 AM   #3174
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
i was testing the BD now quite for a while, but I always have too less turn in steering, no matter what I change on the Setup.
What shall I do? I have ordered the inline steering knuckles, but I'm not sure if this will cure (I hope this word is right :-) ) my problem.
Here is my actual Setup. The track is a pretty tight 220m long track with not that much grip. Motors are 27T and 12T but I don't have enough steering with both.
Martin Hofer is offline   Reply With Quote
Old 08-15-2005, 09:05 AM   #3175
29TC's Avatar
Send a message via ICQ to 29TC
can someone please post the part number for the inline steering knuckle? thanks.
29TC is offline   Reply With Quote
Old 08-15-2005, 09:14 AM   #3176
johnbull's Avatar
Inline steering block SD415S
Inline steering block graphite SD415SG
johnbull is offline   Reply With Quote
Old 08-15-2005, 09:50 AM   #3177
Send a message via AIM to aoizip
Martin Hofer
i see you are not running any sway bar... so i would try to add a
sway bar up front first... turn in should be a bit quicker.... then try add a
sway bar in the rear without the front one on.... see if you like those feeling..
~Ming
aoizip is offline   Reply With Quote
Old 08-15-2005, 10:29 AM   #3178
Swaybars are not my most favourit
swaybar in the front takes away much too much grip
Old 08-15-2005, 10:34 AM   #3179
Kyew's Avatar
Perhaps you can try playing with the ackerman positions?
Alternatively you could put back the original suspension mount shims.........
Kyew is offline   Reply With Quote
Old 08-15-2005, 10:37 AM   #3180
i have the ackermann all the way front, and if I go back to the original suspension mount shims I get less steering
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
