Old 08-09-2005, 03:47 PM   #3151
Oh sure, if you want to do it the easy way
DOTMAN is offline   Reply With Quote
Old 08-09-2005, 10:57 PM   #3152
Originally Posted by highwayman
for tuning, i recommend getting some springs and the in-line steering knckles. as for spares, maybe the CVD pins.
the new arms of the BD are very resilient, haven't broken 1 yet.
Part # SD-415S?
what color springs? I saw on Masami's BD carpet setup he ran Blue front and Green rear, but that seemed a little soft to me.
Also, how about a 2* rear toe block?
www.freerice.com
Help hungry people while learning.
smojoe is offline   Reply With Quote
Old 08-10-2005, 08:29 AM   #3153
dynoman007's Avatar
Send a message via MSN to dynoman007 Send a message via Skype™ to dynoman007
Default parts
in the US where do you guys buy parts for the BD ..
speedtech has some who else ?????
dynoman007 is offline   Reply With Quote
Old 08-10-2005, 08:31 AM   #3154
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Oh man did you get one of those cars!!!!!!!! Thats not an Xray. Check you on the flip side Dave. Oh Rob was in the hospital but is all good now in case you didn't know. Nothing major since the problem was caught so he is back at work already.
Brian
ST Racing Concepts (STRC)
Old 08-10-2005, 08:34 AM   #3155
dynoman007's Avatar
Default lol
i have had this car for a while it just has too much bling to not play with it ..
i keeled a rear diff gear and im in need of one atm for this weekend bd-503
Old 08-11-2005, 05:09 PM   #3156
JayBee's Avatar
Trader Rating: 31 (100%+)
Oh where, Oh where has ol Matt Howard gone. Oh where, Oh where can he be? For some reason I just had to do that .
But let's move along... I have a 'big-race' coming up this weekend and I'm making sure my car is up to snuff. Weight balance-wise my car is:
Front/left- 13.04oz
Front/right- 11.65oz
Rear/left- 11.91oz
Rear/right- 12.56oz
So Left-side/Right-side weight is 24.95oz to 24.21oz AND Front to Rear weight is 24.69oz to 24.47oz.
Are these figures something I should get absolutely even or are they 'CLOSE ENOUGH'? I just want to optimize the handling of the car. Any insight would be appeciated. -JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 08-11-2005, 06:24 PM   #3157
ChadCapece's Avatar
Have you weighed the car with no shocks or electronics? It might be heavy to one side. Then you can add weight to make it equal. Put in electronics and redo the weighing. Balance with weights. Then put on shocks and adjust to remove tweak from shocks.
ChadCapece is offline   Reply With Quote
Old 08-11-2005, 06:27 PM   #3158
rocketron's Avatar
Trader Rating: 16 (100%+)
Front/left- 13.04oz
Rear/left- 11.91oz
Rear/right- 12.56oz
if your using 4 scales your cross weight is off significantly. RR+LF=25.60 compared to LR+RF=23.56 total weight 49.16 - the cross weights should be nearly equal which is more important than having the corners equal.
there is a thread about crossweight and using 4 scales you may read through if interested.
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 08-11-2005, 07:09 PM   #3159
JayBee's Avatar
Thanks guys. Is there any more input? -JB
Old 08-12-2005, 09:20 AM   #3160
tcdrvr's Avatar
Default Third Race on My BD
I got my BD used about one month ago and have raced it three times since then. The first run wasn't that impressive, the back end slid out at almost every turn. After that I switched to Matt Howards 23-Turn setup less the rear swaybar and the car was nearly perfect with the exception of two things in certain turns the car had a slight push and in others the back would get a little loose. Does anyone have any suggestions on where to go from here to resolve these issues? I suspect the push is almost all caused by the spool but the rear traction issue is a big concern. As far as tires, I was using CS-27's.
tcdrvr is offline   Reply With Quote
Old 08-12-2005, 10:59 AM   #3161
What kind of surface were you racing on, and aprox track temp. Also sometimes if the car is tweeked, it will be loose on say left turns and push on right turns, or vice-versa.
pops is offline   Reply With Quote
Old 08-12-2005, 12:29 PM   #3162
tcdrvr's Avatar
The surface is sealed asphalt with a lot of VHT layered on it air temp was about 97 F. As far as tweak I checked it with the Hudy Executive system and then measured the distance on the shock collars to see if they were within a mm of eachother and they were almost exactly equal on both sides. I'll have to check the tweak again I guess. The steering felt equal through most of the track.
Old 08-12-2005, 01:47 PM   #3163
iamramos's Avatar
did it slide in one or both directions? if in one only: could be tweek or bent hinge pins
iamramos is offline   Reply With Quote
Old 08-12-2005, 02:00 PM   #3164
tcdrvr's Avatar
Default Slide
The rear end broke loose slightly in both directions. This hurt me mostly in the high speed turns since the car was swaying slightly rather than accelerating forward. What I'm referring to is only a small loss of traction just so I make myself clear. It's not enough to spin the car around. I should also mention that I was running 19-turn
Old 08-12-2005, 02:14 PM   #3165
If it was 97 outside the track was too hot for TO27s. Try Sorex 36s or maybe RP30s or RP36s.
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
