Old 08-06-2005, 07:29 PM   #3136
Originally Posted by coons88
The hole on the bottom of the c-hub just makes the car sit lower, I did not like it because I could not get any ride hight
When you change the hole on the C hub you need to move the spacer between the C hub and the steering hub, to top or bottom, or your ride height will be way off.
pops is offline   Reply With Quote
Old 08-06-2005, 07:41 PM   #3137
coons88's Avatar
Send a message via MSN to coons88
Ahhhh, thanks
Associated TC6.1 | Hobbywing V3 | LRP X12 | Spektrum | Futaba | Reedy
coons88 is offline   Reply With Quote
Old 08-06-2005, 08:28 PM   #3138
eeyan's Avatar
Send a message via AIM to eeyan Send a message via Yahoo to eeyan
Originally Posted by Francis M.
whats with every selling thier BD's I haven't even had a chance to run mine yet. I was wondering if most of you are running the fixed mid pulley or the one way pulley.?
Francis... where do you race now? La Mirada next week... come join us. Oh yah, I still run my BD...
Fixed center and front one-way for me. Handling was also alright when I had the spool in, but I felt the parts wear was a bit much.
TAOB Racing Team (1999 - 2011)
eeyan is offline   Reply With Quote
Old 08-06-2005, 08:37 PM   #3139
Whats the difference between the fixed center and the center one-way? (handling wise)
www.freerice.com
Help hungry people while learning.
smojoe is offline   Reply With Quote
Old 08-06-2005, 08:42 PM   #3140
beer_drinker's Avatar
The fixed center pulley will give more agressive steering compared to the one-way pulley
beer_drinker is offline   Reply With Quote
Old 08-06-2005, 08:58 PM   #3141
My BD had its first race meet yesterday, and all I can say is WOW
The car is alot faster than my CGM and way more consistent as well
The only negative is that the underside of the chassis is all scratched
This was racing stock btw
Old 08-06-2005, 09:01 PM   #3142
coons88's Avatar
Quick, buy some chassis protector
Old 08-06-2005, 09:04 PM   #3143
definately
Old 08-07-2005, 04:16 AM   #3144
ark
Depends on what youre running. If youre running a fixed center pulley and a front one way, you're going to have more off power steering.
If you're running a fixed center pulley and a front spool, youre going to have a little more stability off power come push (good for loose conditions)!
ark is offline   Reply With Quote
Old 08-07-2005, 04:05 PM   #3145
I am thinking ahead when I race carpet. Stock motor, rubber tires, and more then enough traction. I guess I will order the fixed center and use it as a (dreaded) tuning option. Is there anything else I should buy while I am ordering from speedtech (seeing as horizon doesn't have BD stuff)? Fellow BD driver at the track said to pick up a spare rear belt and shock towers, along with the normal stuff (arms, hubs, hinge pins)
www.freerice.com
Old 08-08-2005, 11:02 PM   #3146
highwayman's Avatar
for tuning, i recommend getting some springs and the in-line steering knckles. as for spares, maybe the CVD pins.
the new arms of the BD are very resilient, haven't broken 1 yet.
highwayman is offline   Reply With Quote
Old 08-08-2005, 11:15 PM   #3147
JayBee's Avatar
Trader Rating: 31 (100%+)
Me either and I've taken some HARD spills. The INLINE STEERING KNUCKLES are definitely purchase worthy. Gave my car the entry steering that I needed -JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 08-09-2005, 01:56 PM   #3148
muahaha's Avatar
Default inline knuckles?
sorry if i sound like a newb, but can any1 show me the different between both the inline knuckles and the standard ones or at least tell me how to spot the differents?
muahaha is offline   Reply With Quote
Old 08-09-2005, 02:59 PM   #3149
If you look at the knuckles from the side, the inline knuckles have the top and bottom mounting holes right in the centerline of the knuckles. The 1 degree offset have the mounting holes offset 1mm toward the trailing arm
DOTMAN is offline   Reply With Quote
Old 08-09-2005, 03:21 PM   #3150
rocketron's Avatar
Trader Rating: 16 (100%+)
also the trialing knuckles have a "1" molded into them and the other a "0"
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
