Old 07-13-2005, 05:08 AM   #2896
raving-monkey's Avatar
Send a message via MSN to raving-monkey
moving the wheels back will decrease grip, but make it more stable....moving the wheels foward would of increased rear grip, but would of been slightly more aggresive through the corners (well thats what ive found when shortening the wheel base)
raving-monkey is offline   Reply With Quote
Old 07-13-2005, 05:15 AM   #2897
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Wheelbase:
front: if you put the spacers behind the arms -> less steering, car carries better cornerspeed
spacers in front of arms -> more steering, less cornerspeed
rear: shims behind arms -> less steering (more stability in the rear)
shims in front of arms -> more steering, sometimes you get the feeling, that the rear end (actually I don'T know how to say..) "floats", means you can never say, if the rear end will break out or not..
Wheelbase overall:
long -> more stability, especially on the straight, but the car reacts slower
short -> less stability, especially at high speed, Car can get a little nervous, but reacts faster (often prefered)
roll center:
front: car doesn't "roll" that far, less steering, nearly same effect as sway bar
rear: " " " " ", more steering , nearly same effect as swaybar
Hope you can understand, what I've written :-)
Martin.
Martin Hofer is offline   Reply With Quote
Old 07-13-2005, 05:17 AM   #2898
@ Matt Howard:
Whats the weight of your BD, ready to race? 1550g or over? I'd say so.
Old 07-13-2005, 05:21 AM   #2899
utieh's Avatar
Martin and Raving-Monkey,
Thank you very much for the fast answer!
I'm not sure of the right definition of grip in English, but I meant that the rear end was a bit loose...on my SD when I was moving the rear arms forward it had the opposite effect (it was adding more weight on the rear wheels when I was doing so). With a longer wheel base the car does feel more stable and doesn't feel so loose but it's just slower
I will try an in-between setting.
Martin, I'm not sure I understood everything about roll center and arms mounts shims
Thanks again.
Gilles
utieh is offline   Reply With Quote
Old 07-13-2005, 05:25 AM   #2900
sometimes you run too soft springs in the rear, then arm spacing has the opposit effect ... try Yokomo orange in front end green in the rear
Old 07-13-2005, 06:30 AM   #2901
Originally Posted by Matt Howard
Here's a pic of my "carpet" BD with a custom made 3mm chassis and topdeck. Super stiff.
Looks good to me!
@ Matt Howard:
I'm not Matt Howard but the car we have setup just like this is right at the foam tire rule of 51oz which is about 1450g. But that again is on foam tires. Hopefully that helps.
Jim
Fantom, BL Racing, Retired
jimnew is offline   Reply With Quote
Old 07-13-2005, 06:31 AM   #2902
Matt Howard's Avatar
Originally Posted by Martin Hofer
@ Matt Howard:
I haven't weighed my car yet with the new thicker chassis but it was considerably under weight with the stock chassis. I forget how much under it was but I know I had to add 6 nickels, how ever much they weigh
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 07-13-2005, 06:33 AM   #2903
do foams weight less than rubber tires?
Old 07-13-2005, 06:37 AM   #2904
Yes, and the weight difference is not consistent from one person to another as tire diameter is personal preference, making it hard to give an exact weight.
Old 07-13-2005, 06:44 AM   #2905
I've also got the Ti racing "worlds" aluminum CVD's on the car and they weigh almost nothing
RCTech #361
Old 07-13-2005, 06:51 AM   #2906
Yeah, those things are unbelievable. I run those on my Schu------, Can't say it in the wrong thread
Old 07-13-2005, 07:03 AM   #2907
johnbull's Avatar
@ Matt Howard:
With GP3700s mine is just under 1500 grams with bodyshell.
johnbull is offline   Reply With Quote
Old 07-13-2005, 07:08 AM   #2908
yes this is what I know too, but if you run such an heavy chassi, the car hast to be over 1500 with rubbers
Old 07-13-2005, 07:18 AM   #2909
It all comes down to cost/benefit anaysis.
Sometimes you have to give something up in order to get something in return.
On carpet with foams a little weight is worth having the suspension work properly and give you the most cornerspeed possible, IMO.
And I can tell you Matt's car is NOT heavy. It is nowhere near the weight of a racing equipped CGM.
Old 07-13-2005, 07:19 AM   #2910
This chassis is specifically for foam tire racing where you need a really stiff chassis. For rubber tire racing I will probably just get another BD instead of switching chassis' back and forth
RCTech #361
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
