Yokomo MR4TC-BD
#2866
Got the BD.
Just got the BD this weekend. So obviously I'm looking for some build up tips.
I have heard about putting CA on the graphite parts such as the lower and upper decks. Do you apply CA only on the outer edges, or even apply some on the countersink holes for the screws?
Any other build up tips would be greatly apprciated. Thanks.
#2867
Check the past couple of pages, I've just asked the same question.
In short, dont cut the tabs from the diff/belt tension adjusters.
Double and triple check the orientation of the center shaft, and the front and rear pulleys. They can be a little un-obvious.
CA the chassis edges only, the countersunk holes dont need it (IMHO).
As mentioned above, CA the edges of the CF bellcrank plate. Im still to do mine, it looked a little brittle I must admit - hopefully that makes all the difference.
Have fun, its a pleasure to build
#2869
**raises white flag upon entry to Yoke thread**
I drive a TC4. I have looked far and wide online to find the seemingly elusive "Yoke caps" Us associated guys love to put your shock caps and bladders on our cars. Problem is I can only find them online at rainbow 10. Anyone have another solution to getting this part with out shipping from Japan?
YS-8D times 2 (need a set of four, 2 come in one package)
I may forget where I posted this so if you have the time could you pm me? thanks a million fellow racers : )
#2870
Guys ...I have a problem,I run my BD in stock/Mod with a locked center gear and a spool.I run on a flowing tarmac track with fast 180 degree corners at each end.My problem is I keep breaking the outside front cvd/universal.the cvd breaks the pin and cup...the universal (hardened) breaks the pin in the middle of the universal.I have broken 3 stock ones and 1 hardened universal.I understand the locked center gear and spool put a huge load on the front drive train but have not seen any comments on this site.If anyone is using a spool and has overcome this problem PLEASE tell me how as I am getting pissed off with all the breakages!!!!!!!!!!
#2871
I drilled a hole in my associated caps and then threaded screws into them. I've never had a problem with them leaking like this on my B4.
#2872
Whad'ya know! I remembered where I posted this!!
kmorast - I am asuming you use the hole you drilled to bleed your shocks. Scale of 1-10 with one being easy as breathing, how would rate your ability to build your shocks equal in rebound to each ohter and with out air?
yoko people-Thanks for letting me borrow your thread for a bit.
Andrew
Andrew
#2873
I have the RS already just need to go to my LHS for the AE Ones.
#2874
#2875
PARTS STOCK
Hello guy's what parts would you recommend to carry in my pitbox?????
Only just finished my BD, racing it for first time tomorrow....
#2876
Hello Chris i have been following your escapades with your BD ,are you happy with it over the previouse car?
#2877
#2879
Thanks Randy its what i thought, i was thinking of unusual parts that wear prematurely
