Old 06-29-2005, 09:39 PM   #2746
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by smojoe
That would explain why their gearing chart only goes that high
Seeing as I would rather stick with 48p then go 64, what other spur size(s) should I get in order to have a little more gearing options? 84 & 82 seem to have close to a .15 (more like .17, but close enough) difference from each other. Should I get an 84t and 82t (and maybe a spare or two of each)?
edit- and a good company/ place to buy the spurs...
Check out PRS, they have the most round and quiet gears that I've run.
Old 06-29-2005, 09:45 PM   #2747
cone washers? Like these?
http://www.horizonhobby.com/Shop/ByC...rodID=OFN10343
Before I forget to ask, can those little plastic spacers inside of the shock (you remember those, don't you? it was a tube with a triangle thingy at the end) be taken out or do I have to install longer shock ends to get my desired ride height?
yea thats the guide for the shock rod. some cut down or cut off the tube part. i just finished building mine and have no trouble getting 5mm ride height plus another 4-5 of droop without cutting.
Turtlemaster is offline   Reply With Quote
Old 06-29-2005, 10:10 PM   #2748
Matt Howard's Avatar
There's a new bellcrank on the Yokomo japan page but the translation isn't the best. It looks to me like it's shorter and uses a spacer to allow, I'm guessing here, the belt to pass without rubbing on the bellcrank.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 06-29-2005, 11:22 PM   #2749
looks like maybe the belt will go between the chassis and next to the little spacer thingy,
given the choice between a older lrp 7.1 and a gt7, which one would you use in mod/stock. this will only be for a weekend or two. using the bd for mod, a sdw for stock, wide open flowing track. 9x2 for mod.
Old 06-29-2005, 11:53 PM   #2750
JayBee's Avatar
Trader Rating: 31 (100%+)
A Novak GTX or a Keyence Zero V Extreme ... -JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 06-30-2005, 01:09 AM   #2751
babytoy101's Avatar
definitely a GT7 !!! the older LRP 7.1 is as old as the C2 ESC of novak
babytoy101 is offline   Reply With Quote
Old 06-30-2005, 01:15 AM   #2752
babytoy101's Avatar
Originally Posted by Mr. Shookie
Put back on the brace otherwise you will get tweak very easy.
I use 64pitch so all I know is 112t is the biggest and I use about 7.0 as a good starting point on most tracsk then go from there as to what feels right and the tempature and what not. I usally go a little lower at first to see if I am flateningout on the strait...
Just some advise put that peice back on now......go with the 84 and get the right pinion....
Just my opinions but what do I know....LOL
-Shookie <><
... some friends of mine used a 120T spur, but had to remove some material from the brace...
i agree with the final drive ratio of 7 for the monster stock... i think this is the magic number for this motor...
Old 06-30-2005, 01:17 AM   #2753
babytoy101's Avatar
i wouldn't remove it ...
Old 06-30-2005, 02:57 AM   #2754
Trader Rating: 18 (100%+)
Matt- I know you probably don't know, but do you know when that new bellcrank will be available to us here in the states? Thanks, and sorry for being "that guy" who asks the dumb questions.
Chris Brown is offline   Reply With Quote
Old 06-30-2005, 06:12 AM   #2755
JDM_DOHC_SiR's Avatar
You are correct Matt.. it allows for the belt to pass by the steering post without rubbing should be out here soon...in a week or two
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 06-30-2005, 07:03 AM   #2756
It usually takes a week or two after an item is released in Japan for Yokomo USA to get it. So if it's gonna be a week or two before it's release in japan like Dave says then probably a month for the release in the states.
RCTech #361
Old 06-30-2005, 07:50 AM   #2757
s2
s2's Avatar
yea, we use them on all the top deck screws, and the screws on that little rear brace. you will have to replace the notmal M3x8mm button head screws used on the top decks with M3x9mm flat head screws to fit into the cone washers
s2 is offline   Reply With Quote
Old 06-30-2005, 09:06 AM   #2758
Kyew's Avatar
-Dave
fyi: the latest BD kits we received here in singapore already have the new bell cranks included.
Kyew is offline   Reply With Quote
Old 06-30-2005, 09:20 AM   #2759
that's pretty cool they're including the new bellcranks with the new kits. Although I still believe it's more of a "cosmetic" problem more than anything.
RCTech #361
Old 06-30-2005, 10:56 AM   #2760
Definately just a cosmetic problem as I cant see it taking any time off my laps, although I wouldnt be angry if the new piece helped shave another .1 or .2 seconds off my lap
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
