Old 06-29-2005, 02:44 PM   #2731
iamramos's Avatar
Originally Posted by chuckles
hey I was wondering are the axels on the BD, the same as the axels on the SD. THX
yes
iamramos is offline   Reply With Quote
Old 06-29-2005, 02:45 PM   #2732
rc-zombies's Avatar
yes.they are identical.
Old 06-29-2005, 03:08 PM   #2733
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by Martin Hofer
well, I guess so.
BTW. Has anyone got experiences with the new Yokomo BD lightweigth spool? and the locked belt pulley?
I've run both of those for the past month and a half or so and the car drives really well with them.
Old 06-29-2005, 03:36 PM   #2734
johnbull's Avatar
Took my Yokes down to play this evening after laying them off for a while as we were getting set for our endurance last weekend, which I did with a TC3.
It was nice to drive the Rayspeed SD and the BD again.
I have rebuilt the SD using my own 3.4mm chassis. I set all the suspension measurements up exactly the same as the BD, and it was brilliant. It's never been so good.
The Bd too was brilliant and in just 2 packs I was already running steady 16 second laps, which is what all the good guys are doing.
I run a spool up front on both cars.
johnbull is offline   Reply With Quote
Old 06-29-2005, 04:06 PM   #2735
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Yea Randy has me hooked on spools now...Darn you Randy....LOL
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 06-29-2005, 04:08 PM   #2736
I'll still be running 1 ways whenever I can.
Old 06-29-2005, 04:16 PM   #2737
Yea I think I am going to put mine back in at Camarillo. See what times she does then try the spool. I guess will all depend on the track..I hurd Chadwick likes the tight technical stuff so I might need the one way out. We will see. Let me know what is what Randy. I have never been there and I don't think I will even get a chance to practice that track...
Thanks,
-Shookie <><
Old 06-29-2005, 05:00 PM   #2738
Does anyone have a good starting gear ratio for the BD with a Trinity Monster Stock motor? Also, whats the biggest 48P spur that will fit on the BD without modification? (I fit a 88T spur, but had to remove the graphite bulkhead brace)
smojoe is offline   Reply With Quote
Old 06-29-2005, 05:06 PM   #2739
Hebiki's Avatar
Trader Rating: 26 (100%+)
84T is the biggest you can use.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 06-29-2005, 05:08 PM   #2740
Put back on the brace otherwise you will get tweak very easy.
I use 64pitch so all I know is 112t is the biggest and I use about 7.0 as a good starting point on most tracsk then go from there as to what feels right and the tempature and what not. I usally go a little lower at first to see if I am flateningout on the strait...
Just some advise put that peice back on now......go with the 84 and get the right pinion....
Just my opinions but what do I know....LOL
-Shookie <><
Old 06-29-2005, 05:21 PM   #2741
84T
That would explain why their gearing chart only goes that high
Seeing as I would rather stick with 48p then go 64, what other spur size(s) should I get in order to have a little more gearing options? 84 & 82 seem to have close to a .15 (more like .17, but close enough) difference from each other. Should I get an 84t and 82t (and maybe a spare or two of each)?
edit- and a good company/ place to buy the spurs...
Old 06-29-2005, 05:34 PM   #2742
Yes I get three packs of spurs from Steve Wang of Speedtech RC check the link in my signature....
He will also have your pinions also...It is always easier to change the pinion than a spur. I like going with the biggest spur and leave it there as I can find just about all the ratios that will work with out having to go to another spur.
-Shookie <><
Old 06-29-2005, 06:55 PM   #2743
s2
s2's Avatar
it tweek very easily with it on too but cone washers will solve this
to find out an equivelent size 48dp gear of a 64dp pitch, devide the 64dp teeth number by 1.3333 and vice versa for 48dp to 64dp conversion
smojoe;
for gearing, it will depend on track size?
it is often best to ask a fast local at the track you race at, i am sure they will help you out.
i dont know a US retailer, but PRS spurs are excellent, very precise, and straight
s2 is offline   Reply With Quote
Old 06-29-2005, 08:48 PM   #2744
cone washers? Like these?
http://www.horizonhobby.com/Shop/ByC...rodID=OFN10343
Before I forget to ask, can those little plastic spacers inside of the shock (you remember those, don't you? it was a tube with a triangle thingy at the end) be taken out or do I have to install longer shock ends to get my desired ride height?
Old 06-29-2005, 09:37 PM   #2745
Thanks,
-Shookie <><
Im not going to make that race, honestly it's just too far and I heard it can have a tendency to get really dusty on the track. Never been there though, so I dont know what would work.
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
