Old 06-16-2005, 04:55 PM   #2626
Trader Rating: 36 (100%+)
The Worlds arms are almost the same. The only noticeable difference to me was the front inner hinge holes are drilled about 3/8" outward, which brings the arms and wheels in more. The rear arms look identical.
EVILGRAFX is offline   Reply With Quote
Old 06-16-2005, 04:58 PM   #2627
iamramos's Avatar
the arms are efectively shorter but the suspension mounts are set wider sothe net effect is that the suspension stays at the same width, it just pivots from a different location
iamramos is offline   Reply With Quote
Old 06-16-2005, 05:03 PM   #2628
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I'm gonna get a set of those to try out, look pretty dialed.
Old 06-16-2005, 05:08 PM   #2629
iamramos's Avatar
Randy, You'll have to drill new holes in your BD to fit the new suspension mount. The Worlds car does have the holes drilled for the SD mounts though.
Old 06-16-2005, 05:10 PM   #2630
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
I belive thta EA's Chassis for the BD will have the options to use both front mounts from what I remember?
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 06-16-2005, 05:17 PM   #2631
stikman's Avatar
I see, thanks,
Maybe I'll try it out if I can get a hold of the World arms.
stikman is offline   Reply With Quote
Old 06-16-2005, 05:38 PM   #2632
JayBee's Avatar
Are the 'RED' prototype CVD's available to order? If not, where can I get the 'BLUE' of 'Ti-colored' ones? -JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 06-16-2005, 08:05 PM   #2633
The red ones are not available as of yet. Production ones will not be red I have been told. You can get the worlds ones which I believe is almost the same from the Schumacher web site.
pops is offline   Reply With Quote
Old 06-16-2005, 08:12 PM   #2634
JayBee's Avatar
Talking
Thanx pops!! -JB
Old 06-16-2005, 10:52 PM   #2635
-Dave
I think I suggested that to him, at least I hope I did.
Old 06-17-2005, 01:35 PM   #2636
Non-BD question for you guys, I'm looking for some battery plugs, the gold plated ones that each wire would have an individual one, and then they plug into the little tube that you solder onto the battery. I need 6 pairs of the male's, no female. I saw Speedtech has the Eagle Racing ones, but it doesnt look like they would fit 12 guage wire well at all. Anyone know of other companies that might have em?
Old 06-17-2005, 01:38 PM   #2637
i know trinity makes some, don't have a part number sorry. going to one hobby in a minute, if they have some you want them, let me know in a hurry leaving in 5 minutes
Turtlemaster is offline   Reply With Quote
Old 06-17-2005, 01:44 PM   #2638
Mach10_shooter's Avatar
Trader Rating: 37 (100%+)
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXTJ25
Mach10_shooter is offline   Reply With Quote
Old 06-17-2005, 02:04 PM   #2639
rc-zombies's Avatar
Randy
I use the small Euro plugs. can be soldered at 90deg angle or from the top.
12ga wires should fit with no problems.
http://integy.automated-shops.com/cg...31105050952.fc
http://www.rctech.net/forum/attachme...chmentid=74363
Old 06-17-2005, 02:14 PM   #2640
I take a dremel,with a cutoff wheel, notch the top and then solder @ 90 deg.
Works good.
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
