Old 06-15-2005, 05:08 PM   #2581
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by smojoe
is sealing the upper deck and shock towers recommended or just optional? (I dont like doing work that I dont have to do)
I seal every carbon part on my cars, they dont feel complete until I do. But about half the people out there dont seal a single piece. It's all optional, but definately gives a better finish, and no sharp edges.
Old 06-15-2005, 07:01 PM   #2582
okay, guess I will go ahead and seal everything then
Hebiki-
I noticed that you run the steering linkage on the underside of the steering rack. Is there a specific purpose for this or are you just trying to get the CG lower?
smojoe is offline   Reply With Quote
Old 06-15-2005, 07:08 PM   #2583
Originally Posted by Chris Brown
Has anyone tred or heard anything about the Yokomo mms motor checker. I am looking into a used one and am wondering if anyone has thoughts on it.
I have one and they are great. Lightweight, will break in brushes, check amp draw, RPM and condition of motor. Only downside that I have found is the sensor wires are weak at the plug. Mine wore out and broke after a year and a half. I ordered a new sensor and then I took some shoe goo and dabbed it around the wires to reinforce and protect the wires. I haven't had any problems since.
pops is offline   Reply With Quote
Old 06-15-2005, 07:13 PM   #2584
Originally Posted by Randy Caster
That looks really dialed, I didnt realize it had the CF print.
Yokomo makes a CF flexable sticker sheet that really looks like CF. I even added a piece to the transponder, small hole for the light to show.
Old 06-15-2005, 09:27 PM   #2585
JimmyMac's Avatar
Not a bad idea pops. I'll have to do that to my MMS. Looks like a good idea for the BCS temp probe too.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 06-16-2005, 12:19 AM   #2586
Hebiki-
Running the link on the bottom takes away a little bit of bump steering.
Old 06-16-2005, 01:53 AM   #2587
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Actually there is an ESC that doesn't get hot over the run, even with a 7T motor an 7,2 gearing :-) GM SX12 rulez :-)
I'm looking forward to getting my Yokomo in about 2 - 3 weeks.
But I'm a bit confused. Some say, steering links under the rack gives more turn-in-steering, others say it doesn't ... What's right?
Martin Hofer is offline   Reply With Quote
Old 06-16-2005, 01:56 AM   #2588
Matt Howard's Avatar
all the steering link under the rack does is eliminate bumpsteer, which gives the car more turn in steering. If you race on a wide open track then keep it up top so you can maximize your corner speed.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 06-16-2005, 02:12 AM   #2589
So: under the rack, more turn in steering, but less cornerspeed
on top of the rack, less turn in, but carries more cornerspeed
right?
Old 06-16-2005, 06:59 AM   #2590
right?
Yep
RCTech #361
Old 06-16-2005, 07:13 AM   #2591
johnbull's Avatar
The MMS is a useful piece of equipment.
I use mine all the time, and have never had any problems with it.
I recommend it.
johnbull is offline   Reply With Quote
Old 06-16-2005, 10:25 AM   #2592
Sleighty's Avatar
hi guys,
bin searching around in this thread but cant quite seem to come across exactly what im after,
What hop up driveshafts are the best?
I was looking at the rayspeed cvds on speedtechs site but wasnt sure if they would fit?
thanks
A1-RC.com
Team Scream
Xray
Sleighty is offline   Reply With Quote
Old 06-16-2005, 10:59 AM   #2593
iamramos's Avatar
rayspeed will fit the newer cars...sd and newer
iamramos is offline   Reply With Quote
Old 06-16-2005, 11:07 AM   #2594
pheyhoe's Avatar
R/C Tech Charter Subscriber
Could somebody post all the parts needed to make the ones that include some ntc3/tc4 parts?
Are these ones meant to be strongest?
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 06-16-2005, 11:17 AM   #2595
Originally Posted by Sleighty
hi guys,
thanks
We are running the prototype Ti Racing CVDs, they are made of aluminum, and after 6 month of hard racing every weekend from 19T to running a 7x1 they are showing no wear. You have seen the MIPs, how the pins and holes in the bell elongate and wear? These are not showing any wear, plus there are 2 additional holes, for when they do wear out. They are very strong and resist being bent. We have only bent 1 bone so far, racing on tracks with heavy boards.
I hope they put these into production soon, because everyone should be able to get these. The only problem we had at first was the fit of the wheel hex. It was too tight and I had to grind a little off the hex to make them fit like the Rayspeed type.
I am not supposed to say much about them, but I can't help it because these are such a great improvement over stock products and any after market products I have tried so far.
I think the next best thing is the Yoke hardend front and rear universals, you just have to grind the ball down on the front bones to get a fit. I wish I knew someone who could remove the pin on the front bones and install the rear bones on the front axles for a perfect fit.
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
