Old 06-13-2005, 07:30 PM   #2506
Smojoe...I suggest you run the stock setup and try that first...I found it pretty good out of the box,The only mod I have done is to change to a locked center gear and a spool(from speedtechrc)I found this improved handing on the one concrete and one tarmac tracks I run on.As for the rest I havent tried those.
Barger is offline   Reply With Quote
Old 06-13-2005, 07:31 PM   #2507
Sorry almost forgot...The BD comes with center and front oneways
Old 06-13-2005, 07:38 PM   #2508
Originally Posted by smojoe
okay, I have a few more questions (I should be getting my BD in a few days)
what wt oil would you recommend for a roadcourse (the track in Ripon)? (carpet doesnt start untill october, so I guess I will just have to run it outside a little)
does the BD come with a center spool or a center one way?
are the wheels that come with the BD any good?
has anyone experimented with cutting every-other tooth off the front or rear belt on top of soaking it in WD-40, or does soaking it free it up enough?
The car comes with 450 wt oil and is just fine. We run 500 in the front and 450 in the rear most of the time. The Rayspeed springs that come with the car are also very good. The kit set up is great right out of the box.
The car comes with a one-way and a spool is available from Yokomo, and a solid steel one is available from Speedtech. I suggest you run a locked center pully if you are going to run a spool or front diff.
The wheels that come with the car are Super Precision Aero Dish TW-1012. They are very good for Ripon, if you go to Speedworld you might want to try TW-512 a little less brittle than the 1012s.
You can soak the belts in WD-40 over night and they will be a little softer, but you don't have too. The belts will break in on their own after a while.
I don't recomend cutting any teeth off the belts, I guess it helped on the Losi, long belt - more friction?
The car is very, very good right out of the box. Tires are the most important thing for the car at Ripon, check out what the fast guys are using at that track, you will need a very soft compond at night for the mains.
pops is offline   Reply With Quote
Old 06-13-2005, 08:09 PM   #2509
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Durability Testing
so i wanted to find out how durable the BD was.. so i went FULL THROTTLE into a parked nitro car when i had a 19T in my car... here's what happened.
how many broken parts can you guys identify? here's the first one...
1. bent suspension hinge pin (blurry in the pic)
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 06-13-2005, 08:28 PM   #2510
eeyan's Avatar
Send a message via AIM to eeyan Send a message via Yahoo to eeyan
2. A chair thrown by the owner in the parking lot? (not in pic but it was there I swear! )
TAOB Racing Team (1999 - 2011)
eeyan is offline   Reply With Quote
Old 06-13-2005, 08:36 PM   #2511
Thanks for the replies, guys. Guess I should just build and run the car to find out how to tune it rather then ask ahead of time, huh?
one more questions (for now)
do you need to sand and CA the chassis?
hebiki-
ouch, big time.
smojoe is offline   Reply With Quote
Old 06-13-2005, 08:48 PM   #2512
Ortiz's Avatar
Had a great showing at the Express On-Road Championships. I was the only Yokomo at all at the race and was able to sneak the car into the Show in stock!
Changes from the kit setup:
30wgt all around
short wheelbase
locked pulley
Yokomo Spool
Ran 100spur/29pinion 64p on a monster stock!
I wanted to go to 20wgt all around but was afraid to. I also need to buy some Rayspeed pistons to make the suspension a little bit softer. I was running the stock 3 hole pistons, but it still felt stiff. It made car car to reactive and made it inconsistent. I think i might try a softer setup when I get back to my local track.
Ortiz is offline   Reply With Quote
Old 06-13-2005, 10:27 PM   #2513
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by JayBee
Really? -JB
Somebody interested in it?
Old 06-13-2005, 10:33 PM   #2514
depends on how much. btw, do you know the guy that had the yok double for sale a couple of months ago, i was talking to him, trying to raise the money but stuff keeps coming up. i forgot his screen name and don't really want to go looking thru who knows how many posts to find it. thanks
Turtlemaster is offline   Reply With Quote
Old 06-13-2005, 10:38 PM   #2515
I'll let it go pretty cheap, someone just order me 2 CTX cell masters and I'll send you my Futaba with the thermo tray. The CTX's are pretty cheap in HK.
Old 06-13-2005, 10:44 PM   #2516
haven't check the hk price, but they are 199.95 at a lhs
and thats my problem, i too am looking for a couple of nice chargers, and with that and everything thing i have going on, purchase of my bd keeps getting pushed back, and the SDW is getting ran pretty hard in mod.
Old 06-13-2005, 10:57 PM   #2517
@ Hebeki: What are are these for Dog Bones ? Square?
darulor is offline   Reply With Quote
Old 06-13-2005, 11:06 PM   #2518
Hebiki's Avatar
chair is fine... i hate repairing cars.. rebuilding yes... repairing..
Hebiki Design Works
Old 06-13-2005, 11:06 PM   #2519
Matt Howard's Avatar
since they have the end of the dogbone ground down I'm guessing they're the yokomo hardened universals
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 06-13-2005, 11:07 PM   #2520
Hebiki's Avatar
those are the hardened universals from the MR4TC car. you have to grind down the ends (the ones that go into the drive cups.. and then they'll fit. they last forever and survived my "durability" testing against the nitro car.
Hebiki Design Works
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
