Old 06-09-2005, 01:58 PM   #2446
eeyan's Avatar
Send a message via AIM to eeyan Send a message via Yahoo to eeyan
From my experience, a center and front one-way combination makes the car more free, but also exhibits a little bit of understeer (but then, you can always compensate on setups). Taking off the center one-way and replacing it with a direct center pulley while still retaining the front one-way will have a more direct feel on steering (hence more aggressive steering). Again, this is from my experience... not sure how everyone else sees the difference.
TAOB Racing Team (1999 - 2011)
eeyan is offline   Reply With Quote
Old 06-09-2005, 07:47 PM   #2447
I agree with eean...but take it one step further,put a spool in the front as well as the locked center pulley,this gives you even more steering,more drive out of corners and you can use brakes!!!!!!
Great on tarmac.
Barger is offline   Reply With Quote
Old 06-09-2005, 10:07 PM   #2448
fai
Regional Moderator
fai's Avatar
Talking
Can anyone kindly tell me what's the hole size, in mm, of yokomo #2 damper pistion?! Thanks!
fai is offline   Reply With Quote
Old 06-10-2005, 01:14 AM   #2449
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Great on tarmac.
A locked center pulley and 1 way has had more steering than a locked center pulley/spool in all of my testing, actually by a large margin.
Old 06-10-2005, 08:24 AM   #2450
diesel's Avatar
Default Shock Assembly
Hi guys, I am at the stage of building my BD shocks. I can't seem to get the triangular piece part A-D to go into the shock body. Do I need to trim the triangular edges? Please help. Thanks.
diesel is offline   Reply With Quote
Old 06-10-2005, 08:35 AM   #2451
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Make sure all the axtra parts tree that is on the triangle is off and use a little bit of force to get them in. I just rebuild mine yesterday and they needed a bit of force. Just do cram it in there, use some fanesse. They should be snug that is a good thing.
Hope this helps,
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 06-10-2005, 08:37 AM   #2452
diesel's Avatar
Thanks very much Stephen.
Old 06-10-2005, 08:41 AM   #2453
Thats what we are here for....
Glad to be a service,
Stephen <><
Old 06-10-2005, 09:03 AM   #2454
diesel's Avatar
Stephen, I've got another question. Why do we need to put the black O-ring thru before screwing on the shock end? Any reasons or use for it? Thanks again.
Old 06-10-2005, 09:11 AM   #2455
I am assuming your are referring to the thin black O-ring. That goes in the adjustable threading spring holder downer thingy.LOL it goes in there so your adjustments on the preload don't adjust them selves. Hope this helps.
there should be clear O-rings that go on the inside & bottom cap, make sure the little black flanged thing gets into the bottom threaded cap.
Hope this helps,
Stephen <><
Old 06-10-2005, 09:14 AM   #2456
diesel's Avatar
Hope this helps,
Stephen <><
Stephen, I am referring to the thick black O-rings that your suppose to slide onto the shock shafts before threading on the plastic shock end. Sorry to have caused confusion here.
Old 06-10-2005, 09:18 AM   #2457
I don't use any black o-rings inside my shocks except on the bottom before the threaded cap goes on.
The thin black O-ring goes underneithe the adjustment proloader thingy to keep it from adjusting. Maybe the instructions say to put it on the threaded part of the shock before screwing down the preload adjustment thingy.
Let me go look at the instructions just to clarify.
Stephen <><
Old 06-10-2005, 09:21 AM   #2458
Matt Howard's Avatar
That's an uptravel limiter.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 06-10-2005, 09:24 AM   #2459
yes after lookign over the instruction Matt has it. I don't use them most of the time. But I thought they were there for there good looks....LOL
Now ask the big question, Matt chime in here as you know more about this than me....
What is the purpose of said uptravel limiter?
Stephen <><
Old 06-10-2005, 09:40 AM   #2460
They make the handling a bit "sharper" since they limit how much the car can lean in one direction.
RCTech #361
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
