Old 06-03-2005, 08:45 AM   #2296
lem2's Avatar
Originally Posted by highwayman
is it the same height as the stock servo horn?
It's a little lower by about 3mm but no problems. I recomend it!
lem2 is offline   Reply With Quote
Old 06-03-2005, 09:10 AM   #2297
lem2's Avatar
Originally Posted by JayBee
I'm using a Kimbrough #114 for Futaba... I like the look of that Tamiya one though , who has a part#? -JB
TAMIYA,700YEN, part#51000 HI TORQUE SERVO SAVER (BLACK)
Old 06-03-2005, 09:13 AM   #2298
rc-zombies's Avatar
I didn't know that came in black... I like that one better than the white
one I purchased... may have to dye mine black this weekend.
Old 06-03-2005, 11:31 AM   #2299
Originally Posted by Hebiki
ive broken three servo horns on the car pretty good considering how much you hit me J/K. what servo saver are you using. i have a few of the 12th scale ones from socal. forgot what they are called. it has the white/red/black packaging.
btw..is this your primary car now? see you sunday at TCS
I don't actually have a servo saver on right now. That's part of the reason I didn't run the car at the Reedy Race. I haven't been able to find one the right size. The LCG comes with a servo saver. I want to see if I can get one for the BD. Right now my primary car is the XRAY. Looking forward to this weekend though. I need some redemption from last weekend.
DOTMAN is offline   Reply With Quote
Old 06-03-2005, 11:35 AM   #2300
Hebiki's Avatar
Trader Rating: 26 (100%+)
lots of people looking for redemption this weekend.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 06-03-2005, 11:39 AM   #2301
Yeah...for me it was all about motor. I think it was the same for Eeyan. This years motors didn't have the same punch as last year. They needed a lot more tweaking. I finally got some help from Steve and Teru Taka from Xenon racing. My car was fast for the third round but had some bad luck in my heat. Oh well...there's always next
Old 06-03-2005, 11:47 AM   #2302
if you use one of the corner holes and turn it a extra notch on the spines it will be a little closer to stock length. maybe a mm.
Turtlemaster is offline   Reply With Quote
Old 06-03-2005, 12:09 PM   #2303
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Having your horn shorter isnt a bad thing, I like to run them as short as I can, sometimes even slow the servo speed down a bit to take some twitch out of the car. You dont need to have the fastest servo in sedan, sometimes it can be just too much.
Old 06-03-2005, 05:43 PM   #2304
rc-zombies's Avatar
anybody have Masami's set-up from RROC?
Old 06-03-2005, 07:26 PM   #2305
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
No dought, I need that one for Ko Race...Same track just a different tire...Yea Ha....Come on Randy I know you went over and peaked at his setup sheet.
Give us the intel.....PLEEEEEEEASE....LOL
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 06-03-2005, 08:00 PM   #2306
JayBee's Avatar
Trader Rating: 31 (100%+)
Thumbs up
...nail on the head ie-S9550 -JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 06-03-2005, 10:34 PM   #2307
iamramos's Avatar
Randy C.-did you ever get your socal setup posted? if not what was it? if it wasn't you....dohhh!
iamramos is offline   Reply With Quote
Old 06-03-2005, 10:52 PM   #2308
Front
Speedtech spool
1.6mm swaybar
1mm offset steering block
4 degree hub carrier
1 degree camber
0 degree toe in/out
.3mm shim anti-dive
0mm spacers under susp. mounts
droop is 9.5mm measured from my setup board to the center of the hingepin, same as rear
4mm in front of arms
stock bladder and sponge
SSS body
Short shock end
62mm length
RS blue spring
450 shock oil
1.0 x 3 hole shock piston
1 o-ring bump stop
Bottom hole in hub carrier, shim on top of steering block
2'nd hole in on shock tower, middle hole on arm
0mm under camber link ballstud
4mm ride height
Rear
Direct pulley
1.4mm swaybar
.5 hub carrier
1.5 degee camber
2.5 degree toe block
0 degree skid angle
.5mm shims under both susp. mounts
Droop is same as front
4mm in rear of arms
62mm length
RS blue spring
450 shock oil
1 bump stop o-ring
bottom hole in hub carrier
outside holes on tower and arm
4.3mm ride height
Checkpoint 7x1
SMC3300
LRP QC2
112 spur 25 pinion 8.96 final
Yokomo Stratus E Type Stock wing
Inner body mount
That was my Reedy setup (based off Masami's) I think Masami's was the same except they went with 2x1.0mm hole piston and a Mazda 6 body, looked like an aluminum front spool.
Old 06-03-2005, 10:54 PM   #2309
FRONT
1 way
Silver Swaybar
0 offset steering block
1 degree camber
1 degree toe-out
0 degree skid angle
1mm under both susp. mounts
6mm droop
Susp arm pos 2mm front 2mm rear
stock shock bladder and foam
SSS body
short shock end
62mm shock length
RS white spring
AE 40wt shock oil (sub with Yok 450 for the sheet if you'd like)
#3 shock piston
1 bump stop o-ring
shock mount inside on shock tower and arm
0mm under inner camber link ballstud
bottom mounting hole on C-Hub, spacer on top
5mm ride height
REAR
Direct center pulley
black sway bar
.5 degree hub carrier
1 degree camber
2 degree toe-in block
.3mm shim for pro-squat
1mm under both blocks
5.5mm droop
arms spaced forward
SSS body
short shock end
62mm shock length
RS blue spring
AE 40wt oil
#3 piston
1 bump stop o-ring
suzuki hub carrier inside hole (3'rd hole in on stock)
2'nd shock mounting hole from outside on shock tower
outside shock hole on arm
5mm ride height
Sorex 36R, precision wheel, 039F insert, paragon additive
Checkpoint 7x1 SMC 3600, LRP QC2
108 spur, 22 pinion, 9.818 final
Stratus E body, stock wing, inner body mount
Old 06-03-2005, 10:54 PM   #2310
Now you guys got the hookup
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
