Old 05-26-2005, 07:12 PM   #2101
Local racer's Avatar
Default Set Up
Does anyone have agood starting point for the car on carpet
http://www.tqracing.net
Local racer is offline   Reply With Quote
Old 05-26-2005, 07:32 PM   #2102
Trader Rating: 4 (83%+)
Send a message via AIM to letitroll
Default Setup Q's
Just had a few questions. I noticed that Messami's LRP setup calls for the front C-hub to be mounted using the lower hinge pin hole. I tried this on my car but, the rim rubs on the suspension arm severely. Was this just a mistake on the setup or did he make any modifications. Also, when the front toe linkage is mounted upside down how many spacers should be placed under the front knuckle? Should you try to have the linkage parallel to the suspension arm?
letitroll is offline   Reply With Quote
Old 05-26-2005, 07:37 PM   #2103
JimmyMac's Avatar
To run the bottom hole on the chub, you need to also move the plastic spacer from under the knuckle to the top of the knuckle. This'll move the axle down to clear your wheels. I'm not sure about this, but you may need a different ball stud for the top of the knuckle? Not sure if it'll have enough tread to screw into the top of the steering knuckle with the spacer on top...
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 05-26-2005, 09:01 PM   #2104
highwayman's Avatar
Originally Posted by KilRuf
Okay, here are the pics of the SpeedRacing aluminum steering knuckles.
Hi... are these the ones that would fit the TC4 bones? have you tried them already with the TC4 bones? i had to "polish" the inner portion of the stock steering knuckles as they were rubbing a little witht the TC4 bones...
highwayman is offline   Reply With Quote
Old 05-26-2005, 09:27 PM   #2105
highwayman's Avatar
Originally Posted by flysti
how many of you guys use the battery brace? & do you think the brace would cause chassis tweak. the reason i ask is cause i've had a 415 tweak edition & always had this problem even without a brace.
i use the battery brace... we'hv never had tweak problems...
Old 05-26-2005, 09:37 PM   #2106
JayBee's Avatar
Trader Rating: 31 (100%+)
Hey guys what's the recommended range of SPUR GEARS to use? -JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 05-26-2005, 09:48 PM   #2107
ChadCapece's Avatar
. Just becareful not to over tighten the HPI ball studs. They break very very easily if you use too much torque when tightening them down. Ti ones would be alot better....
Has HPI not realease Ti ones yet? There was talk of them when I stopped running HPI.
Yeah, they break really easy. Be gentle when tightening them down on that aluminium. I had a few break with the plastic base on the Pro4. They are high stress, but low shear resistant.
ChadCapece is offline   Reply With Quote
Old 05-26-2005, 09:56 PM   #2108
ChadCapece's Avatar
What parts would transfer over from my SD to a BD? I'm looking to get a BD, but I have hundreds of dollars in SD spares.
Old 05-26-2005, 09:59 PM   #2109
Matt Howard's Avatar
The suspension, diff outdrives/internals, and shocks are the same. There's is quite a bit compatible between the two cars.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 05-26-2005, 10:11 PM   #2110
ChadCapece's Avatar
So everything but:
tranny,
bulkheads
gears
shock towers
Old 05-26-2005, 10:21 PM   #2111
rc-zombies's Avatar
Square make the Ti balls for the Pro4.
Old 05-26-2005, 11:13 PM   #2112
diesel's Avatar
Originally Posted by rc-zombies
I got my axles from Rainbow Ten in Japan.
Are those front axles made for the SD? I went through rayspeed's website...there ain't no axles made for the BD yet. Thanks.
diesel is offline   Reply With Quote
Old 05-26-2005, 11:16 PM   #2113
The Rayspeed aluminum CVD's for the SD will fit the BD since both cars use the same axle/driveshaft combo.
RCTech #361
Old 05-26-2005, 11:20 PM   #2114
highwayman's Avatar
biggest we've managed to fit in with minimal alteration to the bracket and a little chafering / beveling on the chassis is 120 (64pitch) ... If you plan on running mod... 120 is a good choice... If you don't like to dremel anything... 112 is the biggest.
all around spur for me is 108. stock, 19T and Mod.
Old 05-26-2005, 11:26 PM   #2115
highwayman's Avatar
So everything but:
tranny,
bulkheads
gears
shock towers
Although all the arms in the SD series are compatible with the BD, the BD comes with new HD (heavy duty) arms already...
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
